Question about GE Ovens
Need instructions for removing control board from double wall oven WB27K5210
Powerman
  • 68 Answers
SOURCE: ge double wall oven repair
You need to tell us the model number. I can then give you specific information.
Posted on Nov 18, 2007
SOURCE: CDA double electric double oven user manual
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Posted on Nov 07, 2008
SOURCE: instruction manual for Westinghouse wall oven
Obtained info from retailer
Posted on Jun 22, 2009
EllaWatson25
  • 725 Answers
SOURCE: i replaced the control board in a double wall oven
PF simply means a power failure and simply needs to have the breaker reset to accept the new board that you replaced. There are times when you may need to replace the breaker that controls you oven electricity.
Posted on Oct 21, 2009
SOURCE: how to remove the control panel on Whirlpool double oven Model RBD305PDS14
Emge & Associates is investigating gas and electric ovens manufactured by Whirlpool, including such popular brands as Whirlpool, Jenn-Air, KitchenAid and Maytag.
The firm is investigating reports that the electronic control panel on certain models is subject to failure after a limited number of uses of the appliance’s “self-cleaning” setting. While most foods are cooked at temperatures reaching 375 degrees, the “self-cleaning” setting raises the interior oven temperature to 1,400 degrees. Due to defects in the design and or manufacturing, the electronics contained on many ranges are damaged by extremely high heat. Repairs to damaged control panels typically cost in excess of $300 per replacement.
If you have experienced failure of the control panel in your range after using the “self-cleaning” setting, you can join this investigation by contacting Emge & Associates at (800) 629-3409 or (619) 618-2974.
Posted on Dec 19, 2009
I'm getting a f24 code on my lower wall oven...what to do?
Hi. Error code F24 indicates that the controller has failed to communicate with the lower convection fan and oven lights control board. If the error code persists, I would recommend connecting with an expert repair tech to assist further and the display board may need replacing.
Sep 26, 2014 | Electrolux ICON 30 in. Double Wall Oven
Ned's to know witch relay to replace wich f8 problem
Hi there! Typically for such an error code, F8 or F80, there is a communication error between the UI (User Interface) and the control board (often the microwave control board). Yes you have a microwave control board in a double wall oven. This will require either the main control board or the UI board being replaced by a professional for safety reasons. I would suggest to contact a professional that partners with your manufacturer. Contact your manufacturer first to see if there are any known issues or a limited warranty for your model.
Mar 30, 2013 | Frigidaire 30 in. Electric Gallery Series...
INSTRUCTION MANUAL FOR LEEB30T9FEA
Hello Brent Delong - I understand you are seeking a control manual for a Frigidaire Double Electric Wall Oven LEEB30T9FEA. You can download the manual to your unit here under the Timer Guide. I hope you find all the information that you need.
Mar 08, 2013 | Frigidaire 27 in. Electric Double...
Double wall oven F0 error code
The F0 error code means that the control board has detected a defect within the control board itself, the F0 code can be cleared by pushing the CANCEL/OFF button and if it goes away and returns all is well,however if a short time later the F0 returns the control board would need to be replaced.
GENE
Oct 04, 2011 | GE Profile 30" Built-In Double Electric...
Have JKP44GP double electric oven. Few months ago lower oven would not stay on-can set oven to bake, stays on for 1 minute then turns off. Today the upper oven is doing the same. Severe thunderstorm last...
It sounds like you are going to need a control board. You can look for a used one online part number WB27K5210. You can also send your board in to be rebuilt. Corecentrics and Fix your board are two reputable companies.
Feb 22, 2018 | GE Ovens
I got a GE double wall oven and when I turn the oven on code F1 comes on
Hi
F1 Error indicates a bad control board and the control board (electronic control) should be replaced to solve this issue. Hope this helps...please post back for further assistance.
Daniel
Aug 06, 2011 | GE Built-In 24" Double Electric Wall Oven
Using both ovens at the same time
Both ovens should be able to be used at the same time. Most likely problem is the control board or user interface. The oven should have a 1yr. warranty. Call your local authorized servicer but first please rate this post.
Dec 14, 2009 | Electrolux 30" Built-In Double Electric...
Jennair model WW2780 Double oven. Top oven will not heat. Turn on with controls and immediately just shuts off again. Assume it is the heating element. Not sure how to replace element and reading advise on...
This is not your heating element. If the element comes on at all, it is not out. This is your electronic control board that is going out.
We have parts and instructions on how to replace the parts on your Jenn-Air oven.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
and we will get the correct parts out to you asap.
We look forward to getting you cooking again soon!
Nov 07, 2009 | Ovens
Key board will not light up...Nothing....Oven light will come on......TTT
Whirlpool RBD305DQ15 Electric double wall oven, the control panel does not light up so you can't tell what you are doing. Do I need to replace the whole board or is there a fuse to replace?
Oct 05, 2009 | Whirlpool RBD305PD Electric Double Oven
Kitchenaid double digital convection conversion oven keypad went out. Any ideas on the problem. Electric panel circuit breakers are okay. Sharon C.
I think these use the same controller board as the Jenn-air units, they have a weak capacitor (C3) on the control board (Timer/control Display). Remove the top panel and look for a discolored or leaking capacitor (usually black about 1/2" high 3/8" in accross). Replace the capacitor and the problem goes away, until next time you use the self clean cycle which seems to overheat the control board and ruin the capacitor.
Sep 23, 2009 | Electrolux 30" Built-In Double Electric...
Ovens Logo
78 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
