Baud speed is set at 12000 i need to set it back to 19200
  • 61 Answers
Is this just the scanner? if so that shouldn't make that much difference you could leave it
Posted on Nov 08, 2012
Printing on TEC b-572 pauses
DEFAULT SPEED IS 9600 bauds, 8 data bits , 1 stop bit no parity.
Un fortunateley the best spped avaible is 19200 bds.
The pausing is due to too much data transfered trough the serial port.
To sole this, increse tehe baudrate and use internal fonts.
Aug 06, 2014 | Toshiba TEC B-572 Printer
Change baud rate on okifax 5050
The baud rate is automatically set by the machine when it connects to the remote machine. The machines start at the highest speed and drop down until both machines can send/receive without any errors then they send the pages. You can not manually set the speed.
Buddymc
Feb 27, 2012 | OKI Office Equipment & Supplies
I have cisco 1841 router stuck at Rommon> only IOS is ok,but still in this mode/.
what shows the following?
dir flash: If IOS is ok the follow the below step The router will guide you through changing the registry. You want to press y to chang the configuration. The only other change you need to make is the change to the console baud rate, set that to 7 (115200).
do you wish to change the configuration? y/n [n]: y
enable "diagnostic mode"? y/n [n]:
enable "use net in IP bcast address"? y/n [n]:
enable "load rom after netboot fails"? y/n [n]:
enable "use all zero broadcast"? y/n [n]:
disable "break/abort has effect"? y/n [n]:
enable "ignore system config info"? y/n [n]:
change console baud rate? y/n [n]: y
enter rate: 0 = 9600, 1 = 4800, 2 = 1200, 3 = 2400
4 = 19200, 5 = 38400, 6 = 57600, 7 = 115200 [0]: 7
change the boot characteristics? y/n [n]:
Configuration Summary
enabled are:
console baud: 115200
boot: the ROM Monitor
You must reset or power cycle for new config to take effect.
rommon 2>
3. When you reset the router in your console window you will see characters that you cannot read. You have to stop the session and set your baud rate to 115200. This will let you increase the speed that you use to transfer the file.
4. At the rommon prompt enter xmodem -c {filename}
5. When prompted, enter y to continue
6. From your hyperterminal prompt, click on transfter then send file
7. Select the IOS image then change the protocol to xmodem via the dropdown box then click send.
8. After the IOS has been downloaded, change the boot order by using the confreg 0x2102 command.
Dec 18, 2009 | Cisco (1841) Router (cisco1841)
Need to lower baud rate on my Brother 4100
The baud rate or communication speed of the Brother 4100 Fax is not selectible by the user. It is factory set to begin at 14.4 (the highest speed) and fall back in increments until reliable communication is established.
Oct 20, 2009 | Brother IntelliFAX 4100 Laser Fax
I need to change a baud rate to9600 for telephone line. can you direct me please.
How to change the baud rate....
Press Menu/Set, 2, 0, 1.
Press ▲ or ▼ to select Basic or
Normal (or High*).
Press Menu/Set.
Press Stop/Exit.
* High is available for FAX-2910, FAX-2920
and MFC-7225 only.
Note
Basic reduces the modem speed to 9600
bps. Unless interference is a recurring
problem on your phone line, you may
prefer to use it only when needed.
Normal sets the modem speed at
14400 bps.
High sets the modem speed at
33600 bps..
Jul 29, 2009 | Brother Office Equipment & Supplies
My system tell me that my serial port is running at 9600 bad. My motherboard is new enough to be running at top speed. What is the problem and is there anything I can do to fix this?
The mother board can be new enough to run at 19200 Baud rate or even more but most of the devices run at a baud rate of 9600. If the baud rate of the motherboard is increased then the communication between the device and the motherboard can become an issue.
If you still want to change the baud rate then the option will be available with the software you get with the device you are using with the serial port.
If I can know the device attached to the serial port then I can help you further.
Kindly Comment.
Jul 23, 2009 | Office Equipment & Supplies
I cann't connect to my switch
The primary connection method for those switches would be serial connection. In the box there should have been a DB9 serial to RJ45 cable. Hyperterminal default settings would allow you to connect.
Jul 25, 2008 | 3Com 4500 24-Port Ethernet Switch
How to configure the Zebra S500 using a USB to Parallel adapter?
The Zebra Stripe S500 has a RS-232 SERIAL interface using a DB-25 connector . You'll need a USB to SERIAL converter, not parallel. Be sure that the baud rate and data/stop bits are set the same on the printer and interface converter. Generally speaking, use the fastest setting possible (19200 baud) unless you encounter problems.
Oct 30, 2007 | Zebra Stripe S500 Thermal Label Printer
Advantech ADAM-4520 Serial Adapter
The ADAM-4520 is a converter between RS-232 and RS-485/RS-422
Look on this link for the FAQ for the ADAM-4520
http://www.advantech.com.tw/support/sr_detail.asp?SR_ID=1%2D1ZFWI0&SEARCH_TYPE=FAQ
But to answer your question about converting from 9,600 baud to  19,200 baud, I'm not sure I understand. The device should support those data rates. It all depends on what you need to do.
Oct 30, 2007 | Advantech ADAM-4520 (ADAM-4520-D2) Serial...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
