Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Why the vacuum shut off after 3 minutes and the plug is hot
  • 61 Answers
Sounds like the motor maybe clogged and over heating. if you can take apart the vacuum and find the motor. if you have a shop vac use that to clean out the dust and debris. put it back together and try it again. if this doesn't work i would replace the vacuum or get it repaired. i would NOT continue to run the vacuum if the plug gets hot after 3 minutes.
Posted on Nov 08, 2012
The beater bar works but the vacuum canister shuts off after a few minutes. Then the switch will only turn the beater bar on and off.
You may have a thermal reset in the vacuum motor that shuts the motor off if it gets hot. Clean the vacuum and replace the filters.
Feb 28, 2016 | Vacuums
Vax stopped mid vacuuming,as though fuse in plug has blown.checked fuse,OK.no lights lit.vax not working.
Most vacuums have thermal protection on the motor that will shut it off if it gets too hot. If you can turn it off, wait 10-15 minutes, and it works when you turn it back on, that's what is going on. Now, the motor shouldn't normally get that hot, so your next challenge is finding out why. Check for any blockages in the air flow or cooling vents, and if the motor also powers something like a beater bar, make certain that it turns relatively freely.
Feb 02, 2016 | Vax Vacuums
Vacum shuts off
If you have BISSELL vacuum, some of our models have a brush reset. Here are the instructions to turn it back on:
If something becomes lodged in the foot and the
brush shuts off, turn the cleaner off and unplug
from the outlet. Remove the obstruction. The
brush will automatically reset when the cleaner
is plugged in and turned back on.
Additionally, you could have dirty filters that are activating a thermal protector switch that shuts the vacuum off if the motor becomes too hot. If this is the case unplug the vacuum, clean any filters, clogs, or obstructions and wait 30 minutes for the unit to cool. Then plug the unit in and it should work. I hope this helps.
May 03, 2012 | Vacuums
I think my maxima got too hot and shut down. Is there a fuse that I may of blown that I can check or is the motor probably fried ? Thanks, Teri
The motor has a shut off when it gets too hot. Wait 30 minutes to an hour to turn it back on. The airway is blocked, causing motor to get hot. Check filter, clean it out, check hose for clog.
Aug 28, 2010 | Eureka 4700A Maxima Bagless Upright Vacuum
I have lux4000 vacuum cleaner. It started to shut down in brush mode vacuum in after 10 to 15 minutes. Motor seems hot when I touch the bottom part. It will start up after 10 to 15 minutes but shuts down...
It sounds like something is catching in the brush. Remove all foreign matter from around brush. Ensure belt is properly engaged. Ensure brush is installed correctly.
If these don't correct the problem, consider taking it to an authorized service center.
Aug 23, 2010 | Vacuums
Vacuum shuts down after 5-10 min of use
It may have a problem of overheating. If you havn't cleaned out the thing that holds all the dirt and dust, you may want to consider doing that. There might be a thermostat in it that shuts down whenever it thinks it's to hot.
Aug 20, 2009 | Hoover Company Wind Tunnel U53019 Upright...
Vacuums shuts off during use
 My guess is: Either a loose contact on the plug  or Intermittent electricial open  in the electric cord itself. To confirm. Try wiggling the cord and ends while running. If you find the place yo ucan either replace the cord or repair it.
Dec 22, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
VX3000c Keeps shutting down after a few minutes of use
it has a thermal fuse in the motor compartment. it is indicating a over heated motor. check the exhaust for clogs or feel the motor it should be warm but not hot to the touch
if its just warm, the thermal is lying to you and needs to be replaced
Nov 26, 2008 | Broan-NuTone VX475 Bagged Central System...
Lux Legacy shuting off by itself
i would say it is over heating but some times you cant tell because electrolux have a sensor so when the get hot the turn off till they gool down soo if you really like the vacuum get it look at by a vacuum repair man.
hope this helps
May 10, 2008 | Electrolux Lux 7000 Bagged Canister Vacuum
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
76 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
