Question about Ovens
Sauter oven door seal and brackets - Ovens
2 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: My oven door does not
There is no adjustment provided, ypou will have to replace both oven door hinges.
Posted on Sep 28, 2010
Trying to find piece of heat resistant fabric (don't know name - something like old asbestos) to replace degenerating fabric on light fixture gasket on otherwise perfectly working caloric electric wall...
If it would help you to find the model number, I would look for a way to remove the oven door. Usually there will be a release near the hinge bracket that you push in or push to the side to allow the bracket to release and you can remove the door to see the ID plate. Otherwise, I would suggest going to a wood stove dealer and looking at the door gasket material they have in stock. They usually have rolls of heat resistant gaskets for sealing doors and glass panels in wood stoves. Last idea would be exhaust gasket material available at Napa Auto parts. Good luck!!
Nov 04, 2013 | Ovens
Hygena Select 620 Diplomat oven
The last person who used the oven door as a shelf to rest a heavy roast has bent the bracket the hinges go in to.
A piece of dowel (broomstick) cut to the width of the oven and placed as a fulcrum in the hinges, gentle pressure when almost closed can bend it back into position, but that wont last.
>> Replace front frame or retention brackets
Oct 16, 2013 | Ovens
I have taken the door off the oven but how do I get the hinge into the oven section with spring loaded so tight?
When you say the spring is loaded tight I assume that you mean that the bracket is hard against the oven door. The brackets/arms have to point away from the door so they click into the oven. Normally when you pull the bracket down and away from the door you put tension on the spring. Once the bracket travels more that 180 degrees, probably to about 200 degrees the bracket won't normally spring back and should stay there by itself.
Feb 13, 2011 | Ovens
Took apart glass oven door on a whirlpool. Where
Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
#10
Read more: http://www.appliancepartspros.com/bd_whirpool_oven_parts.aspx#ixzz0pj5Z78oi
http://www.appliancepartspros.com .
Hope this helps.
Thanks
May 30, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool range RDE 6100N2
Instead of trying to place the bracket to the door from a lowered position at floor level, I positioned the brackets and from a standing position, placed the bracket into the slot, pushed in a downward position and the door went into place.
Feb 24, 2008 | Whirlpool RBS275PD Electric Single Oven
Put back smeg oven door
Yeah I was stumped with this for a short time as it isnt imediately obvious.
The bottom of the two brackets has a flip up catch, place these in the upright position and with some force hook the upper bracket into these catches (please ensure you keep your face and hands away from the direction of the spring)
Once you have the two brackets held open offer up the door at exactly 45 degrees (notice the notch on the underside of both lower brackets) locate this notch on the door hinge hole studs.
Once this is done and your certain it is in the correct postion lower the door from 45 degrees to 90 degrees, put some pressure on the door slightly past 90 degrees and carefully fold down the flip up catches that are holding the upper brackets.
Jan 28, 2008 | Smeg SE250XUK Stainless Steel Electric...
Ovens Logo
100 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
