I have grundig tm 245 reel to reel tape player make some noice o 1-2 ch. 3-4 ch is fine
  • 61 Answers
It could be a weak solider point inside the machine, or a poor connection on the outside. if it's a reel to reel it probably has some age to it.
Posted on Nov 08, 2012
SOURCE: akai reel to reel
I have a complete 1730d ss that I never use. Lots of tape too that's been in storage for ages. Make me an offer for the whole works at coopcab@yahoo.com
Posted on Apr 09, 2008
  • 319 Answers
SOURCE: reel to reel tape player akai gx-230D
If you email me, I will send you a diagram
Posted on Apr 23, 2008
robotek
  • 1512 Answers
SOURCE: TEAC reel to reel tape player
Hi jvanheul
You can get a belt kit from these guys for 15 plus some post. Fresh belts, good service Bob will help you out. Cheers. A FixYa for this would make my day :)
regards
robotek
Posted on Jul 19, 2008
SOURCE: Connections for a Grundig reel to reel tape recorder
Grundig TK23
Inputs at rear of machine. From Left to right.
Circle with line underneath. (Micro socket) - microphone, mixer (Grundig 607), telephone adapter.
Square with line on top - Radio input/Output. Record/playback radio. Record records if player is connected to radio for playback via a 3-pole amplifier unit. Re-recording to a second tape recorder. Connection to a Grundig Stereo-Mixer 608.
Reversed Q - Phono Input. Connection to a record player or a second tape recorder. (for re-recording records or tapes)
Squiggly lines - Outputs. - Connection to external speakers. Grundig Stereo Box. Connection to an additional amplifier (Grundig 229) for synchronous recording.
Square with line at right. - Earphones.
Loudspeaker switch - (At bottom) - In the "0" position, the internal speakers are shut off.
Posted on Feb 05, 2009
SOURCE: play back on Sanyo mr-929 reel-to-reel tape recorder is backwards
I also have an MR-929. The information that you need is in the 'Stereophonic 4 track stereo''. As stereo is only two tracks, there is another 2 tracks in addition to the one you are listening to. Wind the entire reel to the empty spool, and then play that. As you have to physically turn the reel over to do so, you should then hear the other tracks (or track, if recorded in mono).
I use my 929 to play my parents recording of my family from the late 60s, which were recorded on a valve (tube) Ferguson machine, which had a green "magic eye" level indicator, which as a child I found fascinating!
Howie
Posted on Apr 15, 2009
Need manual for Teac 3300 tape player
The TEAC 3300 made in 1972 is an extremely versatile tape deck, designed for the beginner through simplicity of design, yet built to the high technical requirements demanded by the semi-professionals and experienced audio enthusiasts.
The unit will operate at 7.5 or 15 per second and is available in 2 or 4 track configuration.
Specifications
  • Track system: 4-track, 2-channel, stereo/monaural system Motor: 2 x reel, 1 x capstan
    Reel size: up to 10.5 inch reel
    Tape speeds: 3 3?4 7 1?2 ips
    Wow and flutter: 0.06% (7 1?2 ips)
    Frequency response: 25Hz to 24kHz (7 1?2 ips)
    Signal to Noise Ratio: 58dB
    Total harmonic distortion: 1%
    Crosstalk: 60dB
    Input: 100mV (line), 0.25mV (mic)
    Output: 0.3V (line)
    Dimensions: 440 x 440 x 235mm
    Weight: 20kg
    Accessories: empty reel, reel holder, connection cord
Download your manual here: Login HiFi Engine TEAC 3300 Stereo Reel to Reel Tape Recorder HiFi Engine
Sep 18, 2017 | Teac Audio Players & Recorders
How can I set the channel BACK to CH 3 from CH 4
1) Set your TV to channel 3.
2) Insert a pre-recorded tape into this unit.
3) Press the OUTPUT button on the DVD/VCR so that the VCR OUTPUT light is lit.
• If noise appears on the TV screen, press the VCR/TV button on the remote control.
4) Press the PLAY button once.
5) After a few seconds, press the PLAY button on the DVD/VCR for 3 seconds.
• The RF output channel will change to channel 3 from channel 4 and you will see a playback picture.
• When a picture does not appear on the TV screen, repeat step [4].
6) Press the STOP button to stop playback.
Nov 17, 2007 | Emerson EWD2004
How do play both sides if what looks like a reel to reel tape that has a side 1 and side 2 ? My Akai 1722II does not have auto reverse . Thanks
You take the spools off and put the right spool on the left and the left on the right.
The link also explains, but i started on reel to reel in the late 60s. :>)
how do play both sides if what looks like reel to reel tape Google Search
Good video here
Reel to Reel Basics
Apr 25, 2017 | Akai Audio Players & Recorders
Hello there, I've purchased on eBay my Sony TC-200 Reel to Reel recorder. I've opened and cleaned it to best of my knoweldge and ability. I am able to hear sounds on both speakers when I connect my...
http://freeservicemanuals.info/en/servicemanuals/viewmanual/Sony/TC200 Go here. when the page opens, click on the TC200 to download the service manual. There are 3 tubes and one transistor in each channel. Test the tubes first. They fail with age. You can still get tubes. You just have to google the tube number to find a seller.
May 15, 2017 | Quantegy 456 Reel-To-Reel Recording Tape
I have a teac 3340 reel to reel recorder and believe it can only function in 2 speeds 7 1/2 ips and 15 ips. I have many reel to reel recordings that are 3 3/4 ips. Is there an adapter or gadget I can use...
In short, no. if you look closely you will see the Teac 3340 has a much larger/thicker capstan shaft than other Teac reel decks. This feature allows the faster tape speeds...7 1/2 and 15 ips. In order to slow down the Teac 3340 you would have to change the flywheel to one from another deck that was made to run at 3 3/4 and 7 1/2. Which is possible but some work..plus you would have to find a slower speed flywheel from another Teac deck. Also to maintain performance, the bias and Eq positions for the slower speeds would have to be readjusted from 7 1/2 and 15.
May 11, 2010 | Audio Players & Recorders
Can a 4 track reel to reel also playback 2 track stereo tapes?
yes depending on the machine it was recorded on tracks 1-3 will carry stereo sound if done on half track just plat it all four meters will come up
Nov 05, 2009 | Quantegy 456 Reel-To-Reel Recording Tape
Grundig TK23
Dec 30, 2008 | Audio Players & Recorders
Repair manual
Hi marykohles
What model do you have there?
regards
robotek
Jul 10, 2008 | Audio Players & Recorders
Harmon Kardon reel to reel tape player
I have a Harmon Kardon TD-3 that I'm looking to sell. It's not in its original cabinet, but in a smaller box that takes up less space.
Jan 12, 2008 | Audio Players & Recorders
99 people viewed this question
 Grubhead
Grubhead
