Question about Nordic Track C2255 Console (treadmill)
How do I access the motherboard on my Nordic Track C2255?
I have been reviewing the question people have been posting about the beeping issue with this treadmill. The responses seem to include accessing the motherboard to disconnect either the iFit or the SIM card cable. I see the small door on the back that I can remove but you cannot see/access the whole motherboard. How do I gain full access to this so that I can try and disconnect the cables. None of the answers included this step and I don't want to start unscrewing everything. Thank you in advance!
3 Suggested Answers
  • 34 Answers
SOURCE: Nordic Track Ifit Treadmill has power but walking pad not working
If everything on the display console is working correctly then we know it is either a problem with the wires from the console to the controller or the controller itself. In most cases this means you need a new controller. To verify, take off the motor hood and find the green circuit board called the motor controller. With the power on go into manual mode and push the speed up button to a slow speed. If you see an LED light with "spd ctrl" next to it flickering but the belt still does not move then we know the problem is with the controller sending the signal to the walking belt, in which you should check the wires that go to the motor. If they are connected correctly then we know a new controller is in order. If you do not see a flickering light then it means the speed signal never got there and the problem will be with the wires going from the console to the controller. This is called an upright wire harness.
Posted on Aug 18, 2010
ercupa190
  • 12223 Answers
SOURCE: BUYER BEWARE!! I purchased
Watch this video:
http://www.youtube.com/watch?v=E-q-uS4t6so
1. Power
o 1
Ensure that the treadmill is plugged into a grounded outlet using the correct surge suppressor. Use a UL 1449 suppressor listed as a transient voltage surge suppressor (TVSS). It must be rated for 15 amps and 120 volts AC. Secure the services of an electrician if the outlet is not grounded, or move the Proform treadmill near a grounded outlet. Do not use an extension cord.
o 2
Insert the safety key fully into the display. Treadmills with keys are designed not to turn on without the safety key in place.
o 3
Find the circuit breaker on the front of the frame and make sure it is not tripped. The circuit breaker is a vertical switch on the 540S and a horizontal switch on the 540 Interactive Trainer. Press it to the "Reset" position, which will be labeled.
2. Reed Switch
o 1
Unplug the treadmill and remove the safety key.
o 2
Move the upright base of the treadmill down with the help of another person and lift the uprights so that you can get to the underside of the console. Use a Phillips screwdriver with at least a 5-inch shaft to remove the screws. There are five hood screws on the 540 Interactive trainer and four screws on the 540S.
o 3
Remove the motor hood to get to the small reed switch by pivoting the hood off the frame. Find the reed switch and magnet, which are on the left side of the pulley for both models.
o 4
Turn the pulley with your hand until the reed switch aligns with the magnet. There should be 1/8-inch gap between the two. Fix the distance so that it is 1/8 inch by loosening the reed switch screw and sliding it to the correct distance. Tighten the screw.
o 5
Reverse the directions to put the hood back on and the treadmill upright in the original position.
Check too:Optical Sensor. If have it
Posted on Nov 08, 2011
I have a Nordic Track C2255. When I turn it on the motor run, but the belt won't move. I'm thinking that replacing the MOTOR CONTROL BOARD would solve the issue, but need to know before I spend the $.
You must observe 3 things:
Open the cover from motor
1) See if the Drive belt or belt for motor is Loose?
if does, adjust the 2 bolts for tension belt motor the deflection will be 1/8"
2) or Too tight loose the 2 bolts , and loose little until you have deflection for 1/8" and tight the bolts again, keeping the deflection for 1/8"
3) See if the belt is Cut!! replace it, by new one.
Blessing
cuadra2016@yandex.com
whatsapp:+50588611441
Nov 01, 2017 | Nordic Track Exercise & Fitness
Nordictrack c2255
Hi
I have Nordictrack c2255 having software issue. Display is showing upside down and I think it needs to be reprogram
Mar 28, 2014 | Nordic Track C2255 Console (treadmill)
Belt stops while using nordic track c2255
this happen to due the lack of maintenance according the schedule manintenance. see the video and proceed.However if after you did, the problem remain,is TIME to replace the old board deck. God bless you
Mar 26, 2013 | Nordic Track NordicTrack A2350 Pro...
How do I replace a Nordic Track C2255 drive belt?
The black shavings are normal on a treadmill. It may be that you need to tighten the walking belt. Try tightening the two bolts on the rear of the machine that hold the rear roller in place. You need to tighten each of them the exact same amount or you'll throw off the alignment. Tighten them three turns of the wrist and see if that helps. If not, try three more turns. If still nothing then replace the drive belt. That can be a real undertaking and you might want to consider contacting a professional.
Jul 14, 2017 | Exercise & Fitness
I have a nordic track c2255 - having belt issues when I run(i am 200 lbs and the belt skips) i think the tread is properly adjusted - I took the cover off and noticed two idler arm spring settings - a...
Hello there, Your are perfectly fine by making that adjustment. That is actually what it is for. When the belts get older and start stretching you can move that spring and get more tension. It does not harm the roller or the drive motor.
Godd Job! Tim
Jan 03, 2010 | Nordic Track /proform Treadmill...
Nordic track c2255 console displays FF and will not do anything
Hold down the speed up button and the stop button while inserting the operator key,if a bunch of numbers come up hit stop once, if nothing changed the console is bad.If the numbers change pull the key and reinsert it again, if nothing changes the console is bad.Also there usually is a tech sheet and test mode guide on the inside of the motor cover if you remove the screws and take the motor cover off you will see a white paper with lots of info.
Jul 25, 2009 | Nordic Track Exercise & Fitness
Nordic Track C2255 Console (treadmill) Logo
118 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
