Question about HP DeskJet 3650 InkJet Printer
The printer says it is out of paper but it is not
The printer will not work. I have tried trouble shooting. It says there is an error and the printer is out of paper but it is not.
5 Suggested Answers
nitinbabbar
  • 55 Answers
SOURCE: HP 1280 PRINTER TROUBLE SHOOT
are u sure that power supply is burnt n gone ,because i just want to share that if the back side door is not fixed properly ,the printer will not power on,so pls try if u have not
do revert
thnx
Posted on Jan 28, 2008
SOURCE: PRINT ERROR
page not dectect
Posted on Apr 07, 2008
  • 125 Answers
SOURCE: error load paper?? but already have paper!!
what i might do is to remove that application using control panel, add and remove software. uninstall the printer software disconnect printer from pc, reboot/restart, go to printers in control panel remove all printers listed, then make sure you have right software for your printer. shut down this time.reconnect printer cable and boot back up. reinstall the soft ware with printer on.
Posted on Aug 20, 2009
  • 20 Answers
SOURCE: Printer reading: Cartridge Error
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
djiu9o12
Posted on Sep 06, 2009
An error jut appeared on my laser-jet 4200 saying 50.1 Fuser Error and asked that the printer be switched off and then on but the error is still there and i cannot print. What could be wrong and how can...
A laser printer works by putting the dry toner ink onto the paper, and then using heat, via the "fuser drum", to melt the ink into the paper, permanently bonding the ink to the paper.
So, a "fuser error" means that the fuser unit is not heating up to its "operating" range of temperatures.
Take the printer to a qualified technician, for trouble-shooting, and repair.
It might be cheaper to REPLACE the printer, rather than paying the technician to REPAIR the printer.
May 09, 2011 | Computers & Internet
Printer was working fine, until it's outflow was accidentally obstructed. Obstruction removed, but now error light comes on immediately, and printer won't print. There is nothing blocking the paper path,...
Try this troubleshooting prodedure. Turn on/off, unplug, plug in2_bing.gif, should reset configs.
Take all the paper out, put half as much back in.
check the rollers to make sure no paper or particles are stuck preventing from accepting paper.
Go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
Go to web site of printer model and check site for trouble shooting if this does not work above. Hope this helps and good luck
May 31, 2010 | Brother HL-2170W Laser Printer
Officejet 6200 printer getting a error 0x841a255b what is it . also if i scan something it stop half way threw it the same with the fax. i try a second usb cable no good
turn on/off, unplug, wait a minute, plug back in, should reset.
take all paper out. check to see if any paper is jammed in the rollers
go to application folder for your computer, dbl click icon for make of printer, check settings, check to ensure everything is order. in same area, check scanner options.
lastly, check make of printer trouble shooting web site for more information, hp has an awesome site for trouble shooting this problem
hope this helps, good luck.
Apr 29, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Printer error message
Its paper sensor seems to something wrong with it.. try to clean with air blower with slow speed.
Jan 16, 2010 | Office Equipment & Supplies
Model - MFC-7420 - FUSER ERROR
Is the paper that comes out of the paper warm or cool?
If "cool", then the fuser is not operating.
The job of the "fuser" is to generate heat to melt the powdered-ink into the paper, to make a permanent bond.
So, take the printer to a qualified technician, for trouble-shooting.
Nov 18, 2009 | Brother MFC 7420 All-In-One Laser Printer
CRU FUSE ERROR
The "fuser" is the unit that melts the ink-dots into the paper,
to _permanently_ bond the ink to the paper.
That's why the paper always feels warm when being fed out of the printer.
If the fuser is not heating, you have a "fuser error".
Take the printer to a qualified Samsung technician, for trouble-shooting.
Oct 22, 2009 | Samsung SF 5100P Laser Printer
All lights on Dell 1710 printer panel simultaneously flashing.
do you or have you recently started using recycled paper. I know for a fact that recycled paper and Dell printers dont get along very well. It's the dust and it will block the hole for the sensor which could show an error or make the printer think there is a paper jam. Youneed a can of compressed air and thoroughly clean it out. If that does not work you can remove completely the software from the pc, let the pc reboot and reload the drivers and software. good luck
Sep 21, 2009 | Dell 1710n Laser Printer
Error load paper?? but already have paper!!
Aug 20, 2009 | HP PSC 2355 All-In-One InkJet Printer
Says no paper - but there is paper - was working fine now all of a sudden - have done all the trouble shooting and resetting.
Solved at last!!!
The problem isn't mechanical... I just realized that the "no paper" error posts when the software is trying to print to a paper size not supported by the printer. Go to Page Setup and make sure Paper Size is set to Letter.
In my case, the document I was trying to pring was set to Paper Size: Custom, probably because it was a scanned document and it didn't default to Size: Letter automatically. Hope this solution helps someone end their frustration...
Jun 26, 2009 | Brother MFC-8860DN Printer
HP DeskJet 3650 InkJet Printer Logo
46 people viewed this question
Seeker5211
Seeker5211
