Question about Dometic RM2652 Refrigerator
My dometic model #2652 has no electric,why??
    Top Expert:
  • Dometic Master
  • 9,472 Answers
Check the fuses on the lower back of the unit. There is a control board with them on it. If the fuses are good, you will need to replace the control board. Here is the manual for that unit.
Here is the control board in case you need to order it.
Posted on Nov 09, 2012
  • 19 Answers
SOURCE: Dometic RM2652 Refrigerator Problem
Check the flu at the back is clean
Posted on Nov 18, 2008
SOURCE: My dometic 2652 runs is not cooling on gas or
Is there a yellow powder substance on the coils, heating tube or anywhere towards the bottom? If so, you have a leak. The best thing to do is:
1-Find a replacement unit online( ebay is a good place to start)
2-unhook electric line and gas line from the access panel
3-remove the refrigerator from the inside and place doors down(its heavy and you will probably need another person to help)
4-remove cooling unit from back of refridgerator
5-make sure you have enough thermo-mastik for the unit/coil contacts
6-replace cooling unit and hook up everything in reverse
7-turn on and let it cool for a few hours. My unit stays below 32F and works great.
Found the first one listed on ebay just now for $399.00 with a five (5) year warranty.
Posted on May 27, 2009
SOURCE: light is not working in Dometic rv fridge.
the light switch was burned out. we orded a new one, thanks for the reply. judy
Posted on Jun 06, 2009
  • 127 Answers
SOURCE: Info on replacing drain hose on dometic model 2652
You will need to remove the fridge and set it on the floor or at least pull it forward enough to reach the top of the drain hose. There is clip that holds the drain tube to a nipple that sticks out of the back of the fridge that will need to be removed. Remove this clip and the drain hose should pull right off. Route the new drain hose down through the cooling unit coils to the door panel. Attach it back to the nipple with the clip and you should be good to go. The part number for the new drain hose is 2932749019.
Hope this helps,
Jeff
Rate me please!!
Posted on Jul 03, 2009
  • 9 Answers
SOURCE: need directions to remove and replace 110 element in Dometic 2652
Get to the back of the fridge. On the right hand side, there is a metal tube about 4" in diameter which starts at the bottom and goes up. This is a piece of thin sheet metal, which holds insulation against the refrigerant line that goes up the right side of the fridge. The 110 volt heater is located inside of that, near the bottom. The heater sits inside of a small tube, welded to the refrigerant line, and is easily replaced. To get to it, remove any flat sheet metal parts that block your view of the 4" tube (you will need to have a clear view of the bottom of it.) Then you can see the heater. It is on the left side of your 4" tube, metal, about 5/16" in diameter, has 2 wires attached, and sticks out an inch or so to the left. Trace the wires back to where they are connected on your fridge, and remove them, (probably with a small straight blade screwdriver.) It may be necessary to remove another cover or 2 to get to that connection, so remember where all your cover plates came from. Digital cameras are great ;-) . Then, on your 4" tube, unsnap and open the "door" (the metal piece which is a couple if inches wide and 7" or so high,) Grab a hold of your old heater, and pull it up. It probably wont come up all the way so you can lift it completely out, so you will have to unsnap some of your 4" tube above the door. When you remove the old heater, note its position relative to the insulation and refrigerant tube, 'cause the new one goes right back in the same spot. Pull the old one out, and put the new one in. You will know you have it installed correctly when it is snug in its own little tube (you wont be able to see that part,) and there is no side to side play. Then reverse the directions, and put everything back together again. When you re-attach the 2 wires to your unit, don't worry about getting it wrong, it doesn't matter which wire goes with what connector.
Posted on Jul 26, 2009
I have a Dometic 2652 , the electricity to it is good, but the refrigerator lights on top will not come on and nothing works!
Either there is no 12V going to the refrigerator or a fuse is gone in the electronic board on the rear of the refrigerator.
ArctiCold Refrigeration We keep it cold 25204865-k2m0naq5ofddvqgkm1ezk3hy-4-1.png
Oct 10, 2014 | Dometic RM2652 Refrigerator
How to convert 110v to 240v dometic 2652 fridge ?
Simple solution would be to step down the 240V to 110 V with a transformer .
Jul 01, 2014 | Dometic RM2652 Refrigerator
I have a Dometic RM 2652 LP gas/electric its hooked up to 120V but no gas. will it cool if so how long will it take to cool and how cold is it suppost to get it
I just saw where they have a recall on this model Dometic Refrigerator RM 2652. If you go to the www.Dometic.com and find the recall info you can type your Model and Serial Number into the boxes and see if your model is one of the ones recalled. Don't know if this link will work but try it first and it will bring you straight to that box I am talking about on their website. Its http://67.238.126.140/recall.php, if not go to the one above and find the recall information. Hope this helps.
Sep 12, 2010 | Dometic RM2652 Refrigerator
Dometic 2652 recall repair and now converter heats
you will need to get an adaptor for your plug as the electric volts in mexico are different than US.You can go to hardware store and they will tell you wich one
Apr 11, 2010 | Dometic RM2652 Refrigerator
Dometic rm 2652 fridge works on a/c. i get a check light on lp gas, i can light burner with flame, it stays lit
you may need to change the thermocople this cost about 12 dollars this is what make electricity to epen the gas valve thanks from gilles
Feb 25, 2009 | Dometic RM2652 Refrigerator
Hope this helps,
Jeff
Rate me please!!
Nov 10, 2008 | Dometic RGE400 Top Freezer Refrigerator
Oct 12, 2008 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
