Question about Whirlpool LTE5243D Top Load Stacked Washer/Dryer
Whirlpool Thin Twin Stopped Spinning at End of Cycle, H20 Will Not Drain
I own a stacked Whirlpool Thin Twin Washer/Dryer Combo. Yesterday I did a load of laundry, and the load abruptly stopped in the washer near the end of the cycle. When I checked on the laundry, it was ready to go into the final spin cycle, but the unit just made a humming sound and would not spin, nor would the water drain from the washer. The washer also had a "hot" smell. Upon further inspection, I found that a shirt had been caught under the paddles/center spinning mechanism. However, after pulling out the caught piece of laundry, the washer still would not work and sat idle in the cycle. I am thinking that perhaps a belt broke when the laundry became stuck. Your thoughts? Is this something that I can fix on my own, or do I need to hire a professional to come in? Thanks a million! Jen Meisner
  • 2 more comments
  • gorgona Oct 28, 2008
    How do you remove the agitator from the washer in order to remove something that is stuck underneath (and preventing the spin cycle from working)?? Any directions on how to do this??
  • Anonymous Mar 13, 2014
    Twin tube washer stop spinning
  • Anonymous Mar 16, 2014
    just want it to spin out so i can take them to laundry mat.
  • Anonymous Mar 22, 2014
    one piece of laundry spins good,2 or 3 pieces wont spin at all
  • 87 Answers
You have a sock caught in the pump, need to pull off outer case and remove pump and clear it out.
Posted on Jun 08, 2007
SOURCE:
Washer stops in mid cycle
This is probably normal. There is a natural pause between agitating and draining, and again between draining and spinning. Hope this helps!
Feb 04, 2009 | Whirlpool LTE5243D Top Load Stacked...
Water fills the washer during spin cycle
defective timer...a model # should be under the lid...or open dryer door and on front dryer panel right hand corner..onthejob
Jan 16, 2009 | Whirlpool LTE5243D Top Load Stacked...
My whirlpool thin twin wont agitate on any cycle or spin
broken motor coupling....if you need help replacing..im onthejob
Jan 03, 2009 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool washer-dryer has stopped washing
Remove the pump system like this off the Hotpoint wd640 . Remove any blockage inside and retry.
Nov 10, 2008 | Washing Machines
Whirlpool Thin Twin washer won't start, just makes humming sound
The belt is broken and needs to be checked for any other part that has failed causing the belt to burn.
May 26, 2008 | Whirlpool LTE6234D Top Load Stacked...
Not spinning
YOUR LIP SWITCH IS BAD REMOVE FRONT PANEL,TRACE WIRE FROM SWITCH TO JACK,UNPLUG,ON MACHINE SIDE CUT BOTH OUTSIDE WIRS AND WIRE NUT THEM TOGETHER,TAKE SURE UNIT IS UNPLUGGED FIRST,YOUR DONE,THANKS-MIKE
May 04, 2008 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool LTE5243D Top Load Stacked Washer/Dryer Logo
1,085 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
