Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
Fuse for power doorlock keep blowing when i push lock but not when i push unlock
    Problem Solver:
  • 16 Answers
You have a ground either in the switch or in the wire going to the lock solenoid.
when you push the button to unlock power goes thru the wire and the solenoid
then to ground on the other wire that is grounded. when you push the button to
unlock, power is reversed, and goes to the grounded wire then poof-- the fuse
blows.
Posted on Nov 26, 2012
The electric doorlocks don't function
anytime anything electrical suddenly stops working, check the fuse. if blown, replace, if blows again, find the short.
Feb 01, 2013 | 1995 Ford Taurus
94 cougar doorlock button on both doors will not unlock but it will lock
Seems like with a stroke of bad luck both switches went bad or u lose power to ur feed wire for the unlock side
Feb 27, 2012 | 2002 Mercury Cougar
1996 ford explorer- power locks clicking in the locked position.when unlocked it stops,also wont lock when hitting the lock button on the keyfob .is there a separate fuse for doorlocks that could be blown?...
sounds more like a relay for the door locks that is not getting a response back from circuit. keeps trying to lock and nothing saying it is locked.
Sep 18, 2010 | 1996 Ford Explorer
Power locks are not working
Check for blown fuses in the fuse box. If it keeps blowing when you replace fuse there is a short in your doorlocks. Warning replace with same fuse value not higher you may damage more wires.
Mar 27, 2010 | 2001 GMC Jimmy
Right door lock fails to work when unlock buttom is pushed.
take door panel offf check for power to the actuator. or just replace the doorlock actuator.
Jan 24, 2010 | 2002 GMC Envoy
Doorlocks keep locking even when out of the
Dave, it would appear that at one point one of the manual locks were forced either to unlock or lock and has now repositioned the nuetral point at a different location on the locking rod, hence, sending false readings to the control unit to either unlock or lock, I would try this, close all doors and manually lock them see which lock lever look unlike the rest in that position, this will be the culprit and have to be reset on the rod behind the door trim panel. This advice is as best as I can give without manually seeing the car. Drive safely
Jan 19, 2010 | 1999 Pontiac Montana
Power lock on passenger side will not work
the power lock acuator is probably bad, remove door panel, check for power and ground at acuator while hitting doorlock button.
Oct 03, 2009 | 2006 Honda Pilot
04 Escalade w / Valet Starter, all works but door locks
Hello 7suds,
Well, I'd go back and tell them about the doorlock problem. I know that 2 years is a little late to start complaining, but it's most likely a really easy fix.
The most probably causes are that the power doorlock output was either not programmed, programmed incorrectly, or it's not connected or improperly connected to the vehicle servos. Have the installer check the programming, especially the doorlock pulse duration. It's also possible that the remote is simply not sending the doorlock signal. Could just be a bad button. Have them switch the doorlock function to the right "AUX" button temporarily and see if that works. But in any case, the system needs to be tested to find out exactly what is causing the doorlock failure.
Hope this helps.
Jul 16, 2009 | Directed Dei Valet 561r Remote...
The auto door lock feature dose not work.
There is 3 relays in one of the fuse panels that are labeled doorlocks one of them is probably bad. Push the door lock button and find the one that is clicking this is the one that is back. This should fix your problem
Feb 28, 2009 | 2003 Chevrolet Impala
Keyless entry and door locks
Do you have he owners manual? instructions are in there for the keyless entry system. If not go to this link:
http://www.motorcraftservice.com/pubs/content/~WOTEXP/~MUS~LEN/41/96expog1e.pdf
Sep 21, 2008 | 1996 Ford Explorer
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
51 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
