Question about Maytag Washing Machines
I have a Maytag Performa Series MTW5740TQ0. The washer fills and goes through the wash cycle. It fills for the rinse cycle and then stops. Every time.
The washer fills and goes through the wash cycle. It fills for the rinse cycle and then stops. I have to move the control over for it to drain and then finish spinning out. what do you think is the problem.
    Top Expert:
  • Maytag Master
  • 9,472 Answers
Replace the lid switch. Here is the part to order.
Here is a video to show you how to make the repair.
Posted on Nov 11, 2012
SOURCE: Does not spin
Seems you need a lube job on the centrifical mechanical switch that fully engauges the spin cycle( part of the pully to shaft assembly)
Posted on Jul 08, 2008
SOURCE: Maytag Neptune stops during rinse cycles
Could yoy please explain what the "screen" is?
Thanks,
Carl.
Posted on Sep 14, 2008
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
SOURCE: Maytag Atlantis MAV6200AWW; Washer goes through
Maytag Atlantis washer goes thruout washing cycle,but dosen't simse or spin....
Posted on Jun 12, 2009
  • 249 Answers
SOURCE: Kenmore 70 series washer will not drain
sounds like the timer to me
Posted on Jun 16, 2009
I have a Maytag Performance series washer. Model MTW5740TQ0. It agitates during Wash cycle, but will not spin during after the Rinse cycle. It does this more times (95%) than not, but not everytime.
It may be falsely sensing water in the tub. Do you hear the pump running after the rinse (trying to pump out water that isn't there)? This would indicate a fault in the water level sensor. Does it seem to sense the water level correctly after the wash cycle? It could also be a timer problem.
Feb 01, 2017 | Maytag Washing Machines
My Maytag Performa washer loves to flood the house!!!!
sounds like pressure switch is bad or pressure hose is plugged or water valve is bad or drain overflowing
Apr 22, 2010 | Maytag Performa PAV2200
Maytag Performa Washer PAV1000AWW. Shakes when spinning out
My washer doesnt drain in the rinse cycle?? dont kno what to do
Feb 15, 2010 | Maytag Performa PAV2200
Maytag Performa model mtw5740tq0: won't fill up with water
There is an exit hose behind your washer, it has to be maintained a particular height (approx 30inches from ground) before it goes into the standpipe in the wall. The gap in the pipe should not be a tight fit. Another thing that could have occurred is that one of the pipes underneath the washer has come loose; you just have to check these things out. But plug off the mains socket first!
Feb 10, 2010 | Maytag MTW5700TQ Top Load Washer
Maytag washer stopped working at the rinse cycle
do you have the machine set for cold water rinse? if so, the solenoid that allows the cold water to come into the machine may be malfunctioning. try to see if it will fill in the rinse cycle with hot water? if so, you need to change the water inlet valve.
Oct 07, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Performa will not drain
If this is a direct drive washer (no belts) you have a bad water pump or a sock has gotten sucked in to stop it up. get under it look for two hoses going to a white looking valve. If you pull the hoses look out for all the water to flood out so be preped. Pull the pump out and ck for sock or fuzz in it then try to turn to trun by hand if its hard its bad. repost if need more help.
Jul 02, 2009 | Maytag Washing Machines
Maytag performa series washer
I purchased a Maytag Performa washer in 2003 and experienced the same thing. A service call found a loose electrical connection behind the switch panel. The washer has worked fine since.
Hope this helps.
May 28, 2008 | Maytag Performa PAV2200
Maytag Washer
Is the machine belt driven? Look under the washer and see if the belt is laying on the floor. If so, just get a new belt.
Dec 04, 2006 | Maytag Performa PAV2200
Washing Machines Logo
167 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
