Question about Roland VersaCAMM SP-540V
Why is my printer printing yellow and not red
When i try to print in color, the red prints as yellow..i am not out of ink
Most printers have 4 inks: Magenta, Cyan, Yellow, and Black. Red requires the printer to print both Yellow and Magenta. If your Magenta isn't printing, red will show up yellow. When you say, "I am not out of ink", you may actually BE out of Magenta, or your magenta ink nozzles may be clogged. I don't know what brand of printer or model you have, so I can't give you exact directions to clean the nozzles. The printer driver may have that ability.
Dec 17, 2016 | Office Equipment & Supplies
My Officejet 6000 E609n printer doesn't print the correct colors. The red is printing yellow and the blue and green are a lighter version of what is on the screen. I have cleaned the printer head
This is not a cartridge issue. IT is Printhead issue. Since you have done the manual cleaning, it is now time to replace the Printhead.
Regards,
Suhail
May 14, 2012 | HP Officejet 6000 All-In-One InkJet...
I am printing in red but output is yellow
Check the ink levels- it sounds like your Magenta is out- HP deskjets use CMYK to mix the colors- C = Cyan, M= Magenta, Y = yellow, K = intensity (black). Red is usually a blend of Magenta + Yellow- so if you don't have magenta ink in your printer, when you try to print out something in red- it will come out yellow
Jul 01, 2011 | HP Deskjet D2360 InkJet Printer
Printer will not print yellow or orange, but prints other colors correctly. Brand new lexmark cartridge.
Yellow is one of the printer's "primary" colours.
Orange is mix of "red" and "yellow".
So, an empty "yellow" cartridge, or clogged ink-jets would cause your symptoms.
Sep 17, 2010 | Lexmark Z705 Photo Jetprinter InkJet
My DCP-115C printer was missing red colour.
Yellow is one of the colours used to produce a shade of red.
I don't know how but ther must be a way to print a test page to see if the print heads need cleaning I've never used a brother.
Sep 26, 2009 | Brother DCP 115C All-In-One InkJet Printer
Printer prints colours in different colours
Either you are out of red ink or the print head is getting plugged. Most printers substitute the nearest available color when a color runs out or the head is plugged. As some shades of red are made with yellow mixed, it therefore prints only in yellow if red is unavailable.
Aug 30, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
The cartridsge printe red and blue fine. No yellow
The print head for the yellow color may be clogged. Check the manual to see how to turn on your print head's cleaning system. Run it until the yellow starts to print properly. If after running the cycle 4 or 5 times you still can't get any yellow to print you will probably have to take the printer to your local repair depot to have them diagnose the problem.
Jul 11, 2009 | Office Equipment & Supplies
Red ink problem
red is the combination of Yellow and Magenta toner, try printing one of each independently, if either is printing correctly yellow and magenta you should be able to print red. good luck
Jul 24, 2008 | Epson Stylus Photo R220 InkJet Printer
Printing Yellow instead of Red
The colours in the 3 colour cartridges are cyan, magenta and yellow. If you want to print "red", this requires a mixture of magenta and yellow. Thus if only yellow is printed when you should be printing red, it means the magenta is not printing i.e. faulty/empty magenta cartridge or faulty/blocked magenta nozzles.
Please post a new comment if you wish for further help with this problem.
Jul 17, 2008 | Epson Stylus C86 InkJet Printer
Pink teal lime
the printer cartridges have the ink Blue (light blue), red (pink) and yellow (lime).I think your printer printing fine do not worry all the printer have same ink........If you have the problem with color on print outs :you this link ::
http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:549:0:0&framed=&docid=ENUS25128&relevance=1
Mar 17, 2008 | Lexmark X5470 All-In-One InkJet Printer
Roland VersaCAMM SP-540V Logo
Top Roland Office Equipment & Supplies Experts
Michael Harrier
Randolph Tidwell
David Payne
David Payne
Are you a Roland Office Equipment and Supply Expert? Answer questions, earn points and help others
