Where is the pressure switch on a nordyne furnace modle number mmha 070abhr 05
I have a 2 blink code for the pressure switch on my nordyne furnace modle number mmha 070abhr 05 and i am not able to locate the pressure switch please help !!!!!! COLD IN HERE !!!!lol
gear001
  • 59 Answers
SOURCE: Troubleshooting Nordyne Furnace. Flashing LED
Your induce fan motor is burnt out or the senor is out. If the little fan is working its just the senor. Your going to need a repairman to find the senor or motor for you. You can replace the senor but I wouldnt recommend replacing the motor. www.fastacservice.com
Posted on Oct 14, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: furnace wont start. heil gas furnace. on initial
Yes, inspect the air intake, exhaust pipe, filter and condensate piping for blockage or moisture. Also check for a hole in the hose that goes from the small exhaust blower to the pressure switch or a bad connection on the switch or control board. You may be able to temporalily jump the switch for diagnostic purposes only.
Posted on Oct 17, 2009
  • 2976 Answers
SOURCE: Need to find the pressure switch on my goodman furnace
It's mounted onto the gas valve. It will be a button or lever that you have to push in or down, depending on the style.
Posted on Nov 20, 2009
SOURCE: I get the code 3 (3 blinks) on my Goodman
Goodman furnace new in 07 Red LED lite flashed the three code..It was frosted and iced over closing down air flow at intake and exhaust out side of house. Use a hot hair dryer if you can't dislodge.
Have had a lot of sub zero weather here.
The ignitor can be seen glowing in the top peep hole.
The Red trouble shooting LED lite is in bottom peep hole.
Posted on Jan 10, 2010
Therinnaiguy
  • 1420 Answers
SOURCE: 3 flashing light....Aire-Flo furnace AF80MPA100B5A
That control board is several hundred dollars. If I may make a suggestion, take a jumper and when the inducer fan starts, jump out the pressure switch. If it starts, it's not the board but a bad switch, hose or blocked exhaust vent.
Posted on Jan 15, 2010
Furnace will not stay lite, flashes pressure valve closed
Too much or too little pressure. Check for air blockage or an ice blockage inside or outside the house. Were flames good color when lit?
Nov 12, 2014 | AO Smith Miller / LSI / Home / Nordyne...
FURNACE WONT FIRE UP ,LIGHT INDICATOR SAYS PRESSURE SWITCH OPEN W/ INDUCER FAN ON
PROBABLY MOISTURE IN PRESSURE SWITCH OR SNOW OR ICE BUILD UP NEAR VENT TERMINATION . PROBABLY JUST A BAD PRESSURE SWITCH
Dec 17, 2013 | AO Smith Miller / LSI / Home / Nordyne...
Model m1mc 090a bw furnace pressure switch open. inducer motor is pulling .45 w.c . the intake pipe above inducer is only pulling .1 w.c. . checked for venting and intake blockages found non. removed...
did you check the hose from the inducer to the pressure switch? HAVE you unplugged the unit from the wall outlet to reset the board? DO you have a voltmeter? If you do you can run voltage across the switch and if you get 24 volts you are open.
Oct 23, 2013 | Coleman Intertherm Nordyne Miller Furnace...
MMHA-075AAHR-01 mobile home gas funace
Replace the pressure switch and/or hoses to the switch
Sep 24, 2013 | Heating & Cooling
I have a Nordyne FG6RA 072C gas furnace that does not start. I get three blinks of the red light which indicates the pressure switch is stuck closed. I replaced it with a new one, cleaned out the inducer...
Thes switches are very sensative to any air change. Check to see if you have any restrictions in the exhaust vent. Also check to see if you have any restrictions in the furnace side such as rust or soot. The entrance to the exhaust fans collect a lot of moisture and you may ahve to replace the intire assembly. Keep in touch Rus
Nov 25, 2009 | Heating & Cooling
Heating & Cooling Logo
119 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
