Question about Roland VersaCAMM SP-540V
My roland sp-540 is printing yellow instead of red. WHY???
I have a roland sp-540v, trying to print on banner material with black backing. Keeps on getting message to setup sheet while everything is loaded correct. The sensor is probably not picking up black.
Could you try
(1) Temporarily stick a white strip over the sensor where it detects the media or
(2) On the length of the media or
(3) Even staple same sized white media below the black one which you can un-staple after printing.
kindly ignore if these are (s) tupid answers
Mar 23, 2016 | Roland VersaCAMM VP-540i
Richo aficho sp410 dn proplem with red color printed as yellow instead
have you tried doing color registration under maint.menu? are drums clean maybe bad xfer assy (the big belt thing) -Carl
Apr 04, 2014 | Ricoh Aficio SP C410DN Laser Printer
I need a driver for Roland VersaCAMM SP-540V for windows 7
IF I CAN REMEMBWE YOU CAN DOWNLOAD IT FROM THE ROLAND SITE
Nov 17, 2013 | Roland VersaCAMM SP-540V
Roland sj 740 service manual
roland SJ-740 ink not filled, how to escape this setting
Mar 13, 2013 | Roland Printhead FOR SC-540 / SJ-540 /...
Roland fj-500 yellow dye ink printhead not printing
i have printer sj 160 st jet pro,problem in unrecovrable limit.and affiche ecran st jet pro sj???
Aug 02, 2012 | Roland Printhead FOR FJ-400 / FJ-500 /...
Roland Versacamm sp540v is not printing yellow or magenta. What could be causing this? We were out of town and it wasn't used for a few weeks.
your print head dry out, cause is: no use! you should detach the tube between the pump and the caps, the one of magenta and yellow, insert a seringe in the tube (that comes from the cap) and suck some cc´s of ink, .then atatch the tube again and run one or two powerful cleanings, then run the test. A smart advise is: never turn off the machine in the main power, the machine when in stand by, does automatic a check and a cleaning process from time to time if needed.
Jun 24, 2012 | Roland VersaCAMM SP-540V
Have a Roland SP 540 V Eco Sol MAx printer/cutter. Magenta/Yellow print head clogged (hadn't been used in a few weeks) can't seem to get the ink to flow in those heads! Any idea other than head...
you should have to use the syringe method to **** the ink before anything, then make a powerful cleaning, test, you may have to do it several cleanings and should be solved.
Jan 08, 2010 | Office Equipment & Supplies
Printer prints colours in different colours
Either you are out of red ink or the print head is getting plugged. Most printers substitute the nearest available color when a color runs out or the head is plugged. As some shades of red are made with yellow mixed, it therefore prints only in yellow if red is unavailable.
Aug 30, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Roland VersaCAMM SP-540V Logo
153 people viewed this question
Top Roland Office Equipment & Supplies Experts
Chas Peters
Level 1 Expert
Michael Harrier
David Payne
David Payne
Are you a Roland Office Equipment and Supply Expert? Answer questions, earn points and help others
