Question about Duplo Dp 430
Ink ran out, drum is dry. New ink added, drum won't re-ink or refresh. What is next step?
Cannon Pixma MP780 won't print. Just replaced black ink cartridge, do I have to replace all of them for it to print
Not normally but the black print head nozzles maybe blocked.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Mar 08, 2013 | Canon PIXMA MP780 All-In-One InkJet...
Printer was inactive now won't print
The ink might be dryed up in the cartridge, might need a new one.
Dec 29, 2012 | HP PhotoSmart C4480 All-in-One Printer ...
Ink won't dry
If you are trying to print on normal transparent film then the ink will not dry, it needs to be special transparent file for inkjet printers.
Jun 07, 2012 | Epson Stylus Pro 4800 InkJet Printer
Installed new ink and now won't print anything, not even a test page. says error. deskjet 4400 series
Each ink cartridge has a metal, thin Copper 'plate'.
In this 'plate' there is a series of VERY small holes. The holes are so small it's hard to discern their existence, with just the ***** eye.
The area on the printer's body, that the copper plate matches up to, also has matching holes.
After a given time the ink dries up in these tiny holes.
The dried ink needs to be removed.
Printer UNPLUGGED from power, printer case open.
I would suggest wearing dish washing gloves, and remove all ink cartridges.
Small bowl half full of distilled water as hot as you can stand it, dip a clean, lint-free cloth in it. (Distilled, because non-distilled water can leave hard water spots)
Squeeze all excess water out until the cloth is damp. (D-A-M-P) Wipe the area on the body of the printer.
I would suggest wiping in one direction only. Wipe, then go to a fresh, clean part of the cloth, wipe again.
Keep wiping until the cloth picks up No ink.
You may want to follow suit on the ink cartridge/s now, as they may have picked up dried ink.
Suggest use a can of compressed air for computers, and make SURE all areas are D-R-Y.
Allow the printer to set open to dry afterwards. May only take 30 minutes, or less.
Ensuring all surfaces are dry from the water, reinstall the ink cartridges.
Close the printer's case. Plug back into power, WAIT 1 minute, then turn on.
Regards,
joecoolvette
Dec 10, 2011 | HP Office Equipment & Supplies
Canon iP4000. Magenta ran out today, I pulled the cartridge and continued to use the printer w/o magenta cartridge. Picked up a replacement cartridge, installed it and now the magenta does not print.
Hi Todd
I'm suprised you got it to work without the cartridge in it.
You'll probably find that you've burned out the magenta nozzles. The print head works by rapidly heating ink to squirt it out of the nozzle and the incoming ink cools it down prior to the next squirt. It's happening at a spectacular speed and if no cool ink is coming in the nozzles get hotter and hotter until they burn out. Alternatively, they may just be clogged up with dried up residue. Remove the print head and run it under hot water for a while (take the inks out first). Dry it off. refit it and the inks and try again.
Jun 07, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
Kodak esp 3250 won't print black. Changed cartridge and still won't print black. Just installed new printer.
I fixed my ESP 3250 print problems by removing the cartridges and print head. Using a Q-tip and warm water, added drops of water to each of the print head ink wells until the water / ink from the wells bled thru onto a cleanex. Did this several times. Dryed the print head fairly well. Then added a drop of water to each cartridge for each color. Reasembled and ran an alignment and to my surprise, it works! I hadn't used my printer in a while, so the ink had dryed on the felt for both the print head and cartridges.......
May 15, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Have a Risograph RP3700 that we have not used for a couple of
try cleaning the dry spot with WD40 or penetrating oil to melt down the ink
Apr 08, 2010 | Riso RZ220 Duplicator
New cartridge won't print
  1. Make sure you removed the tape from the ink cartridge.
  2. Press the <Menu> button on the printers operation panel.
  3. Press the left [<] or right [>] arrow buttons to select [MAINTENANCE].
  4. Press the <Set> button.
  5. Press [<] or [>] to select the cleaning setting you want. Select [HEAD CLEANING] for normal print head cleaning. Select [HEAD REFRESHING] for deep print head cleaning.
    Note: [HEAD REFRESHING] uses more ink than [HEAD CLEANING], so perform [HEAD REFRESHING] only when necessary.
  6. Press <Set>.
  7. Print a Nozzle Check Pattern and perform at least two Head Refreshing if the pattern is not correct.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 26, 2008 | Canon MultiPASS F80 All-In-One InkJet...
No black ink print. Prints in light blue
Cartriges have a shelf life. It's printing in blue either because it has dried up or is out. Different cartriges have different timelines but if you haven't been using the printer often, it could have dried up or is simply out of ink. I would suggest first to try cleaning the head of the cartrige where the ink comes out with alcohol and a Q-tip and then if that doesn't work, buying a new black cartrige.
Nov 06, 2007 | Office Equipment & Supplies
Duplo Dp 430 Logo
Top Duplo Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Duplo Office Equipment and Supply Expert? Answer questions, earn points and help others
