Can't 'Launch Startup Repair' when Vista boots on Evesham Laptop
When I try to startup my Evesham Explorer 2007 laptop, Vista gives a "Windows Failed to Start" message and offers either "Start Windows Normally" (which does't work) or "Launch Startup Repair" options. When I select the 'Launch Startup Repair' option, several messages appear on screen but always finish with "Startup repair cannot repair this computer automatically". There appears to be a separate small partition on the hard disk (in addition to the Vista OS partition) which may be a recovery partition. Is there anyway that I can run a system recovery from boot up since the laptop wasn't provided with any recovery CD? Thanks - John Downes
  • john_downes Jan 08, 2009
    Pressing F11 at boot time doesn't do anything at all except pausing boot up until you take your finger off the F11 key. After repetitive restarts I managed to log in as the user and one of the choices was to go to command prompt. At the command prompt I noticed that the drive letter was X:\ which turned out to be the small recovery partition. When I typed dir I saw that there was a file named 'RecoverOS.cmd' and when I typed recoveros at the X:\ prompt a recovery sequence started which reloaded Vista back onto the C: partition. Please pass this on to any others who are having the same problem which I had. Thanks - John Downes
  • Anonymous Mar 15, 2009
    Same laptop same problem : CANT LAUNCH STARTUP REPAIR when Vista boots on evesham explorer 2007.
    Scholar:
  • 157 Answers
When you restart try to press F11 while booting..check
Posted on Jan 05, 2009
Dell-n5050 laptop; windows failed to start; code-0xc000000e; boot failed because required device is inaccessible. I have Dell OS media stick. and is there a free fix for this problem?
That code is a Windows boot error. I'm not sure what you can do with the Dell OS media stick but the traditional solution with a regular hard disk is to take a Windows 7 OS disk, boot with it, and run startup repair. Here's a link to Startup Repair: Startup Repair Microsoft Windows
Apr 01, 2015 | Dell Inspiron N5030
Dropped laptop, Error codes 2000-0142 and 2000-0123
Remove the HDD and test. Replace if necessary.
Nov 29, 2012 | Computers & Internet
Windows will not start up or launch start up repair
hi,
please insert your operating system disc in the drive and restart the computer .
Select the boot device as cd/dvd drive and save the settings in BIOS .
restart the system and boot it using the CD.
also, you can insert the disc restart the system in safe mode.
try to restore the computer using system restore.
May 21, 2012 | Dell Inspiron Mini 10v Netbook
When I turn on my laptop it goes to a windows error recovery page and gives me the options to launch startup repair or start windows normally. When I launch the startup repair my screen goes black and only...
Hello.
Sounds like the Windows Recovery Partition is corrupted or your hard drive may be faulty.
But, first try to boot your system in Safe Mode (press F8 repeatedly as it boots) and choose Safe Mode or Last Known Good.
If it still doesn't boot properly, try the diagnostics to determine if a hardware problem - boot your system and press F 12 (or F2) repeatedly.
Hope this helps.
Jan 11, 2012 | Toshiba Computers & Internet
"Windows failed to start. A
It sounds to me like the harddrive has errors on it. First, I would try completely reinstalling windows with the windows disk. If that does not solve the problem there are several pieces of software that are much stronger harddrive repair solutions than the built in Windows one. Try this one, it is free for 10 days. You will need another computer (friend's computer?) to download and burn this software onto a CD, then put the CD in your computer and boot to it by pressing any key when it asks you to.
http://www.ntfs.com/boot-disk.htm
Sep 03, 2011 | Dell Inspiron 14R Laptop Computer (Intel...
Mycomputer says my bootmgr is missing and to press ctrl+alt+del to restart. When I do this it just restarts and come up with the same screen
Are you running Windows Vista. Do you have the original windows disk that came with your laptop.Insert the disk in the drive and reboot the computer.
  1. Boot from the Vista install disk
  2. Choose your language settings and click "Next"
  3. On the bottom of the screen click the link "Repair Your Computer"
  4. Select the Vista installation to repair and click "Next" and it will launch WinRE
    • The "Load Drivers" button will open a mini Windows Explorer, which can be used to search for drivers in case they are needed to access disk drives or other components. This mini Explorer is also very handy to perform file copy/move operations and change file-attributes.
The following options are available in WinRE:
Startup Repair - It will repair the boot manager files and restore critical files required for booting Windows Vista.
Jan 17, 2011 | Toshiba Computers & Internet
Toshiba Laptop is having trouble booting up.
hi,
Please reinstall vista once.If the issue is not fixed this seems an issue with HDD
Jul 14, 2009 | Computers & Internet
Windows vista wont start
Ok,Try safe mode with command prompt,If you can get to the command prompt
Type these in one at a time and press enter ( let each one completely finish before typing the next one.)
Bootsect.exe /NT60 c:
Bootrec.exe /FixMbr
Bootrec.exe /FixBoot
Bootrec.exe /ScanOs
Bootrec.exe /RebuildBcd
bcdedit.exe /import C:\Boot\BCDBackup
May 21, 2009 | Toshiba Satellite A135-S2276 Notebook
Tom
You should go into the safe mode and try to uninstall or undo the previous work. Else use the system restore. But if it continues again with a blue screen error, then u should format ur pc, further if u experience blue screen error then u should note that one of ur hardware is damaged.
Thankyou...!!!
Feb 08, 2008 | Acer TravelMate 2300 Notebook
Acer Aspire 3693WMLi -Launch startup repair
Try to boot in safe mode. From a cold boot, hit f8 till it gives you several options including "safe mode". Do that and if you can boot to windows let it do it's stuff before restarting normally. Good luck
Aug 29, 2007 | Acer Aspire 3000 Notebook
Computers & Internet Logo
2,228 people viewed this question
David Payne
David Payne
