Hello, i purchased the bookkeeper 2009. installed on computer. followed all directions. 1st time i set it up iwould not allow me to use the password i had selected. ok, so i unistalled the program completely from all directions & started over again. i get through the setting up process & i be a wet dog the same thing happened. keeps telling me my password is incorrect????? what do i do?? thanks in advance for your time. kim
    Problem Solver:
  • 15 Answers
I hope the "password" you're trying to use isn't actually the CD key. If you're putting your password into the CD key column then it'll never work, check the side of your box for that.
If not, then make sure you're registering with the correct information. If you're registering with an email address then check it and see if there is a confirmation email. If not then make sure you're typing everything correctly.
Posted on Dec 29, 2009
What Does Bookkeeping Mean?
Recording monetary statistics or transactions in the books of accounts is known as bookkeeping. Bookkeeping is the essential segment of accounting.
Jan 19, 2016 | Retail Supplies
Tip
How to Reset Windows Server 2008 R2 Password When you have lost it
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 7.8 磅 0 2 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:普通表格; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Besides Windows 7.Windows Server 2008 R2 Operating Systems are the latest and more secured versions from Microsoft.
Windows Server 2008 R2 is a server operating system produced by Microsoft. It was released to manufacturing on July 22, 2009, launched on October 22, 2009. According to the Windows Server Team blog, the retail availability was September 14, 2009. It is built on Windows NT 6.1, the same core operating system used with the end-user oriented Windows 7. It is the first 64-bit only operating system release from Microsoft. Windows Server 2008 R2 is an updated operating system to Windows Server 2008.
For reseting Windows Server 2008 R2 password,I have used several methods,and this method is very easy and 100% worked on 2008 R2 servers. This is very quick, because it clears the administrator password straightaway. There are some products available to find out admin password, which takes lot of time to find.
Windows Password Key is the product you required to reset admin password.This is not free,you must pay $19.95 .But you can get it freely somewhere,You can free download from Lost Windows Password website.
How to reset Windows Server 2008 R2 password with Windows Password Key
Step 1. Burn a CD/DVD or USB Drive to reset Vista password.
Download Windows Password Key and install in a computer. And follow the step-by-step guide to burn a CD/DVD or USB drive to reset password.
Step 2: Set BIOS to boot from CD ROM or USB.
Insert the burned CD/DVD or USB drive in the computer you want to reset password, and then change the BIOS settings of the computer as follows:
1st. Start computer and press F2 or Delete to enter BISO setup during the initial startup screen.
Note: What key is pressed depends on the manufacturers, but in most cases it is F2 or Delete.
2nd. Use the arrow keys to select the Boot tab, and then select Boot Device Priority and press Enter.
3rd. Choose first boot device to CDROM or USB flash drive, and then press F10 to save settings. The computer will restart with the changed settings automatically.
Note: When you want to boot from USB, you should adjust USB to 1st Drive by entering Hard Disk Drives firstly before selecting first boot device to USB flash drive.
Step 3: Remove the forgotten Windows password under DOS.
1st. Choose the installation path of Windows, and enter the ID of the path
2nd. All the user names will be displayed for you. You can select one to remove its password by entering the ID of the User Name.
3rd. Enter y to confirm and continue, enter n to return to previous menu.
4th. After removing the password for the selected user name, you can enter y to continue to reset
passwords of other user names, or enter n to restart computer. And now you can log on computer without password.
We did. It's very simple and finished in less than two minutes.
Now you can regain access your operating system and create a new administrator password. The best thing of using this method is that you shouldn't lose any data on your computer. Furthermore, If you can't find a computer which has a CD/DVD writer or the locked computer have no a CD-ROM, You can burn the ISO image file into a USB flash drive and use the USB flash drive to recover your Windows administrator password.
Try these three methods the next time you have lost Windows administrator password, which you do not need to reinstall Windows system for getting back to Windows by removing lost or forgotten password.
on Sep 15, 2010 | Computers & Internet
Tip
How to Reset Windows Server 2008 R2 Password When we lost it c
4th. After removing the password for the selected user name, you can enter y to continue to reset passwords of other user names, or enter n to restart computer. And now you can log on computer without password.
We did. It’s very simple and finished in less than two minutes.
on Aug 19, 2010 | Computers & Internet
Connection to update server failed, error code 12152 for Bookkeeper updates
A lot of people seem to have had major problems trying to upgrade for this software. Some have spent many hours waiting on the phone, and decided to move to different software.
"Dog Lover" offers this guidance:
If you are updating your software follow carefully (1) first back up your database and email to yourself (2) wipe bookkeeper completely off your computer (3) download the newer software and install the tax tables (4) finish updating (because it downloads to a newer software version within 2011) the program. When everything is updated, (5) save your database to your desktop (6) open bookkeeper and restore your database. Then make another update with the upgraded database.
Lets hope it is still true for 2013/14
Jan 21, 2014 | Avanquest Bookkeeper 2009 Full Version for...
Bookkeeper software old version
Please go directly to Avanquest technical service:
http://www.avanquest.com/USA/aq-you/support/
Jan 22, 2013 | Avanquest Software Bookkeeper 2009
What is bookkeeping?
Bookkeeping is the recording of financial transactions. Transactions include sales, purchases, income, and payments by an individual or organization. Bookkeeping is usually performed by a bookkeeper. Bookkeeping should not be confused with accounting. ...
en.wikipedia.org/wiki/Bookeeping
Nov 24, 2010 | Facebook Social Network
How to install mcafee antivirus licesend copy
Follow the given instructions to install McAfee antivirus on your PC:
1. Purchase a new copy of McAfee Antivirus software from your nearest computer retailer or check online at the McAfee site for a downloadable version.
2. Load the software according to manufacturer's directions.
3. Go to "Start," "Control Panel" then "Add or Remove Programs." If the McAfee Antivirus Software is there, you will need to select "Change." The directions will allow you to put on the updated version. For a new product, follow the next step.
4. Place the CD into the appropriate drive. Select the installation button so that the program will load into the computer.
5. Restart the computer after the installation. Following the directions given, select the options you want to make your program user-friendly for your use.
6. Enable the system to select specific times to automatically scan your computer for viruses.
7. Start your computer to enable all of your changes to take effect.
Nov 01, 2010 | Mcafee Total Protection: Windows
Hello, ...My wife purchased a Windows 7 Home Premium 32 Bit Toshiba Satellite L455D-55976 laptop.it has been running well for this afternoon she went to turn it on by pushing power button to display...
is this a brand new system ? if so, bring it backl and have the correct the issue.. it is under warranty
if its used computer , did you get the CD recovery set ?
Oct 17, 2010 | Computers & Internet
Unable to install card studio 2009 has dvd-rom instead of cd-rom
Well, you have a couple of choices:
1) You can have a DVD installed in your computer. Usually around $50.
2) You can purchase a flash drive (thumb drive) of at least 4GB. Depending on the size of the files, you may need an 8GB. You can have a friend copy the entire DVD onto the flash drive. Then you can take the flash drive and copy the entire DVD from the flash drive to your computer and install the program or install directly from the flash drive. (It may auto start when you insert it into a USB port.)
If you install it from the flash drive you will probably have to insert it every time you run the program. If you copy the DVD to your hard drive you will not have to and it will run faster.
Thanks for using Fixya.
Nov 10, 2009 | Hallmark Card Studio 2009 Deluxe Full...
Bookkeeper 2009 running very slowly.
Interesting. It may be that software is using more memory; when your computer runs out of memory, it starts using your hard drive for temporary (memory) use, which is painfully slow. You haven't said anything about your computer. (e.g., is this XP with 512mb or less? Vista with 1gb or less?)
A suggestion, if I may: Before worrying about your hardware, just make sure your software is up to date. This support note here tells you how to make sure you've got the latest patches to that software. It's on a different topic, but the advice is right.
http://kb.avanquestusa.com/al/12/1/article.aspx?aid=3775&n=1&tab=search&bt=4&s=
Jan 21, 2009 | Avanquest Bookkeeper 2008: Windows
Computers & Internet Logo
David Payne
David Payne
