Question about Refrigerators
No power to fridge checked all connections and fuses
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 10, 2012
My 1993 model dometix RM 2611 fridge won't turn on no light's and doesn't make a sound.. wit could it be
Hi, This sounds like either a power supply issue or the ''fridge is completely knackered. Check that the power supply to the 'fridge is working. Check for an internal fuse in the 'fridge, if there's one there, is it working?
Jul 16, 2015 | Refrigerators
Fisher & paykel fridge e521t no power to fridge,not any power coming to fridge
Did you try an other electrical outlet? Can you test the outlet has any voltage?
does the fridge have an on / off switch? I don't think so, so if nothing works also check the cable and the plug going in the outlet.
Mar 17, 2015 | Fisher & Paykel Paykel E521TLX2 Fisher...
Not running. had power outage. perhaps power surge while crew was reaparing downed power lines. Is there circuit breaker/reset on unit. I have verified 100V at wall outlet.
well there is a fuse located near the place the power cord attaches to the refrigerator you need to find it.Just check there is a sticker at the back of the fridge with the wiring diagram the rating of the fridge will be written on it as it purely depends on the size of fridge.For a average fridge it is 5 ampere fuse
Dec 04, 2010 | Refrigerators
Dometic refrigerator RM 2652 is not working
The fridge needs a 12 volt DC source to operate properly, which should be connected at the back of the fridge, outside behind cover. Check all fuses in your fuse panel as well. The upper controls are powered by 12 volt DC system, and that's what tells the fridge what to do.. (battery or converter)
May 08, 2010 | Dometic RM2852 Refrigerator
Cant find the fuse for the refrig. no power
Check connection for 12 volts, at back of fridge behind vent cover .(outside) Make sure 12 volts getting to the lugs where they join. If you have 12 volts to there, unplug fridge at receptacle usually on left side by back of fridge, just to be safe. Remove cover on circuit board and look for a blown (glass type fuse in there.)
May 03, 2010 | Dometic NDR 1292 Refrigerator
No power to fridge but plug checked
there is a wrong connection from the connector.
Mar 06, 2010 | Admiral 26 cu. ft. Side-By-Side...
Please help my indesit ta 5 fnf s is dead with no warning. no lights no power nothing. its not fuse power or socket
Had the same problem with my TA5FNFS once you have confirmed as there is power in the wall socket and the fuse in the plug and cable are ok, I found as the PCB control board had burnt out costs about £60 for a replacement board
Apr 30, 2009 | Freezers
SUB-ZERO 700TC
Hi Richard,
The most likely cause of your problem is a loose wire in the plug connecting your fridge to the power socket - check the terminal screws that secure the wires into the plug, and of course check or replace the fuse with a known "good" one.
Also plug some other appliance in the socket that your fridge is normally connected to, just to make sure there is power at the socket itself.
I have never known fridges to have internal fuses, but there's always a first time :-)
Hope this helps - if not come back with a comment so I can try to help you further.
Cheers, D.
Jul 09, 2008 | Sub-Zero 700TCLH Bottom Freezer...
Relates to Maytag GC2228EEDB fridge freezer when the icemaker is making ice the water dispenser intermitantley depspeses water onto the floor . and now when connected to the mains power the fridge...
Trying to take the doors off Maytag GC2228EEDB and need to disconnect the water supply to the left door,the connector dosnt want to budge is there a nack to this??
Jun 04, 2008 | Maytag Refrigerators
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
