Question about GE Washing Machines
Find lint filter for a GE washer WBVH6240FWW
I would like to know if this machine has a lint filter I can clean.
    Top Expert:
  • GE Master
  • 9,472 Answers
Remove the front lower kick panel and you will see the filter.
Posted on Nov 09, 2012
  • 13 Answers
SOURCE: Washer Door will not Open
door lock blown motor problem for the noise appliance doctor
Posted on Feb 02, 2007
SOURCE: can't find Lint filter on a Whirlpool 8255e super capacity Plus Washer commercial quality top loader,
The Topload whirlpools are designed to take the lint out by reversing the water to drain out.any lint should be drained out.
Posted on Nov 01, 2008
  • 5 Answers
SOURCE: GE front load washer model #WBVH6240FWW leaks when
Check the big rubber seal around the door for any holes or tears. Had the same problem, my husband had a screw in his pocket that torn a hole in the gasket.
Posted on Sep 27, 2009
SOURCE: Lint Filter in Whirlpool Agitator washing Machine
I have a regular top loader and the lint filter is on the underside of the inner tub. You have to remove the inner tub to get to it. You might be able to find a service manual explaining this at appliancejunk.com.
Posted on Dec 09, 2009
  • 14 Answers
SOURCE: GE top load washer w/no lint trap leaves excessive lint
Are you sure there's no lint filter? For general advice on cleaning a washer lint filter, try eHow: washer lint.
Posted on Aug 09, 2010
GE washer, model WBVH6240FWW. runs a cycle until the rinse cycle then pauses. I've done alot of cleaning of various parts, but still have th the ie problem. currently have the pump out to see if there...
Don't take the impeller off if no clog there then check all hoses and filter. If not, there's a code you can check for by using the servicers book that should be located under the top. Remove the rear screws and slide the top back to remove and enter the top of the unit.
Sep 25, 2011 | GE WBVH6240F Front Load Washer
GE front loading washing machine model # 4 wbvh6240fww It won't drain. Don't know where the pump filter is, that everyone is recommending to check and clean. Where is the access panel for the...
The filter is hidden below the lower front panel (3 screws hold this in place) Turn the pump cleanout knob counterclockwise about 2 turns and be ready to mop up any water that leaks out as you remove it. To avoid spillage, you can pull the machine out and tip it backwards 45 degrees.
Jul 12, 2011 | GE WBVH6240F Front Load Washer
My ge front loader washer model number wbvh6240fww wont't rinse and makes a humming sound during the rinse cycle
I'm hazarding a guess- the sound MIGHT BE from the machine attempting to drain the water but cannot, therefore not going on to the rinse cycle. Just in case this is the problem follow my general (pre-typed!) guidance notes on filters and motors ;-0)
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Mar 03, 2011 | GE WBVH6240F Front Load Washer
Lint filter on GE wbsr3140dw
Open the door and lint trap is right in front, just pull up and it comes out. Clean and replace.
Sep 20, 2009 | GE WBSR3140DW Top Load Washer
Where can I clean lint out of GE front-loader washing machine
You don't give the model number, so I can not know for sure. That being said, on newer front load GE washers there is a filter access right on the lower side of the very front of the machine. On many slightly older GE front load washers you will have to take the lower portion of the front panel off to find a filter access. On them, it is usually a bit to the right side, about an inch and a half round removable plug with filter attached. Be advised that when you take it out the remaining water from inside the machine and it's pump and hoses will also come out, so be prepared.
Feb 01, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Remove lint holder on ge front loader dryer
I have the exact same problem. I am amazed at had been the engineering is for such a simple process. The user guide just says to clean the lint filter. Even when doing so, there is still an excessive build up of lint beyond reach. There are no instructions that mention how to clean this part. It is obvious that GE did not test this part of the machine.
Jan 30, 2009 | Zanussi ZWF1440 Front Load Washer
Most US-sold washers made after the mid 1980s don't have lint filters. The manufacturers weasel-word around it by saying that the lint "goes down the drain", leading people to optimistically assume that there is a self-cleaning filter in there somewhere. There usually isn't and whatever lint doesn't go down the drain is filtered by your cloths (but whatever does might clog your septic system). As a result of this scam, it's much harder to hang-dry or iron-dry clothes that haven't been hand washed. And, if you think spending $2000 on a pair of matched "front-load" style machines will solve this, you might be wrong; many of those washers still have no lint filter.
Jan 08, 2009 | GE WBSR3140DW Top Load Washer
Front load ge washer does not finish cycle
This model does not have a drain filter. There are filter screens inside the inlet valve where the hoses attach onto the machine. Take hoses off and look inside where the water goes into machine to see screens. Also, take the other end off hoses to make sure there are not screened hose washers in either end of the hose which may need to be cleaned or replaced.
Oct 18, 2008 | GE WSXH208A Front Load Washer
Wont spin
I found the solution to clean the lint filter on the GE Adora. Go to http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
I just did this and my washer is now running instead of the flashing start/pause and door unlocking. It was fairly easy. Make sure you have towels and a flat pan to catch the water if you don't have the machine on a riser. There may be water inside so a wet vac may be helpful too. Once my washer finishes what was in it, I have these funky towels to clean. You'll be very surprised what you find in the filter! Best of luck!
Sep 17, 2008 | GE WSXH208A Front Load Washer
Washing Machines Logo
137 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
