Question about Refrigerators
QUESTION ABOUT DEFROST TIMER
HOW CAN I NOW IS THE DEFROST TIMER IS DEFECTIVE. IS THERE ANY WAY TO TROUBLESHOOTING THIS PART?
THANKS AGAIN FOR YOUR HELP
  • harleypapa22 Apr 27, 2009
    IS HER A KNOB ON THE DEFROST TIMER LOOKS LIKE MY GE DOES , ITS UNDER THE FRONT LOWER PANEL
    Scholar:
  • 58 Answers
I'm not sure what kinda timer you have there are two, one is a timer you can cycle yourself on or off the second is a defrost board does the same-thing you just can't force a defrost with it. but the way to know if it working is (defrost timer) cycle the unit in to defrost try to hear any sizzling if so your heater and defrost t-stat are ok i would replace the timer. now on the defrost board since you can't cycle it i would check the defrost element and defrost t-stat with a meter you should read a closed circuit if the heater is good, and if the coil is frosted up you should also read a closed circuit on the t-stat again replace the board. Hope this helps you
Posted on Jan 08, 2009
The freezer still goes but not the fridge part.
You have a unit whose defrost cycle isn't working properly. The defrost element is either controlled by an actual timer motor or it may be controlled by a circuit board. Either the defrost element is defective, the defrost timer is defective or the circuit board is defective. A very remote possibility is the defrost termination thermostat could be 'open'.
If you TOTALLY defrost the freezer compartment, your unit will work decently for about three days until it freezes solid again. The evaporator coil in the freezer is covered by the interior and inaccessible without removing the freezer shelving and the rear of the freezer interior. If the element is defective, it is located behind this cover and is imbedded within the evaporator coil itself.
Feb 20, 2015 | Refrigerators
GE model gth16dberww top mount freezer. Freezer is iced over. Removed rear cover and coils are also iced over. Poured warm water into drain and water immediately exited to drip pan. not sure where to
Sounds like the defrost timer is not functioning, or a defrost element is burnt out.
#1. After an accumulative "run time", typically the timer will initiate a defrost cycle. At that point the defrost heaters are energized and the compressor is turned off for the duration of the cycle. The defrost time cycle varies from manufacturer to manufacturer and can be as low as 15 minutes to as much as a half hour. If it is defective, it could be stuck in the cooling position not initiating a defrost function.
#2. If the defrost heater element is burnt out, the timer functions normally and will cycle the defective heater on, but there will be no heat generated to defrost the ice.
#3. A more remote possibility is a defective "defrost termination thermostat" which is wired in series with the defrost element. If defective, it will keep the element from energizing on a call for defrost.
At any rate, unless you are extremely handy AND have access to a supplier of repair parts, it sounds like a service tech needs to be called.
Oct 17, 2014 | GE Refrigerators
I have an Amana Model ARB2214CB Refrigerator with the bottom freezer. The unit runs fine but the last three months for about a week it stops cooling and the freezer stops freezing. You can hear the fan...
That sounds like a defective=> 67001036 Defrost Timer
slowing down and sticking in it's defrost position on the timer cam. The defrost timer can be found inside the fresh food section behind the controls. See=> ARB2214CB Controls location #12 in the photo HERE Questions? Thanks John Tripp Appliance 911
ARB2214CB User Manual
Feb 20, 2014 | Amana ABB1927DE Bottom Freezer...
Bypass defrost timer
Just turn the defrost tmer clockwise to cause defrost or run conditions. If you bypass the defrost timer you will have problems like shorting of wiring or loss of the timed defrost. Why not replace the defrost timer if you know it is defective? What is the model number of your refrigerator? Thanks Sea Breeze
Jul 16, 2013 | Refrigerators
Ge tfx25pr
There are a couple reasons why this is happening and they are either a defective defrost timer found inside the fresh food compartment behind the control panel. Location number 257 in this photo HERE Using a flathead screwdriver turn the timer clockwise slowly until the compressor and fans stop running. Leave like this up to 40 minutes to see if this will cause defrost to take place. If this causes the defrost to happen simply replace the defrost timer.part number Click Here=> WR9X489 Defrost Timer If compressor and fans do not restart on their own then again turn the timer slowly until they do. The other reason for defrost failure and the evaporator icing over is a defective Click Here=> WR51X443 Glass Tube Heater Same part can also be found HERE It is a good idea to change the=> WR50X122 Defrost Thermostat while the rear panel of the freezer is removed WR50X122 can also be found HERE I am here should you have questions, Thanks Sea Breeze
Jun 03, 2013 | Refrigerators
I have a kitchenaid superba s by s. About every 3 days the freezer quits running and then after about 4 hours the freezer starts working again. What may be the problem?
Are you sure your model number is KSRD22FKST ? Sounds like the defrost timer is defective yet the model number you have above your post shows a W10351625 Defrost Control Board
In the fresh food section above the top shelf the control panel has either a defrost timer or an electronic defrost control. Unplug refrigerator and remove the face of the control panel so you can examine the timer or electronic defrost control for burn marks or signs of heat. The timer or defrost control is most likely what is causing the problems you describedand changing will more than likely solve this problem, Let me know what you find, Thanks Sea Breeze
Post the correct model number if possible, Thanks John Tripp
Sep 25, 2012 | KitchenAid (KSRD22FKST) Side by Side...
The freezer keeps freezing up, where is the defrost timer located?
Sorry to hear about your problem. Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
You should call a service company to resolve your issue.
I suggest you call a service company. your model is not listed, you may have a electronic or mechanical. defrost timer
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Dec 21, 2010 | Refrigerators
Kenmore elite 596 73503201 no cooling in top compartment
if the freezer is getting cold the problem is due to the cold air from the freezer not getting into the refrigerator. There are several things that can cause this problem. The coils in the freezer icing up and not defrosting properly is one of the things that can cause the refrigerator not to get cold enough. Another problem is the fan that blows the cold air from the freezer compartment into the refrigerator, not working. When the compressor is running open the refrigerator's door and push the switch that makes the light go out. You should hear the fan blowing the cold air from the freezer into the refrigerator, when this switch is pushed in. If the fan is working then you will need to find what is blocking the air flow. Iced up coils are a common problem. The icing problem can be due to a defective defrost timer or something defective in the defrost circuit. Click here for more information. Check for these problems and let me know what you have found.
REFRIGERATOR TROUBLESHOOTING
#1 Refrigerator side getting warm Freezer still cold
Evaporator fan motor not running.
Defective defrost timer. See Defrost Diagnosis Procedure
Defrost heater defective. See Defrost Diagnosis Procedure
Defrost thermostat defective. See Defrost Diagnosis Procedure
Airflow blocked from freezer compartment.
Freezer control turned to "coldest" setting blocking air flow to refrigerator side. On most refrigerator/freezers, the freezer control closes a baffle when turned to coldest setting, and this blocks off the air flow to the fresh food compartment.
Fan blade broken.
Defective door switch on older models.
Light staying on with door closed.
2 Refrigerator & freezer compartments both are getting warm
Make sure refrigerator is plugged in and has power.
Condenser fan motor on bottom under refrigerator not running.
Condenser coil clogged.
Defective defrost heater. See Defrost Diagnosis Procedure
Defective defrost thermostat. See Defrost Diagnosis Procedure
Cold control defective.
Compressor overload defective.
Compressor relay defective.
Compressor defective.
Low on refrigerant. #3 Freezer compartment getting hot.
Defrost timer stuck in defrost cycle.(replace)
Defrost thermostat stuck.(replace)
Ice maker stuck in harvest cycle
Light staying on with door closed. 4 Ice maker not making ice
Defective inlet water valve.
Freezer temperature not cold enough. (see problem # 2 & 3 above)
Defective thermostat in ice maker.
Defective drive motor.
Water inlet tube clogged with ice.
Defective module in newer style icemaker. 5 Refrigerator sweating around door edges
Door gaskets leaking air.
Defective case heaters.
Energy saver switch not set to reduce exterior moisture
also if require more help click the link http://www.applianceaid.com/refrigerator.html please do rate the solution .thanks in advance.thank you for using fixya.
Mar 27, 2009 | Refrigerators
Help
HI thanks for your question the timer does two functions advances the fridge defrost cycle defrost the freezer for specefied minutes & go out of defrost &start to cool again I your fridge does that its ok while your working on the fridge vacuum it out THanksTHE APPLIANCE DOC
Sep 13, 2008 | Frigidaire FRT18B4A Top Freezer...
Refrigerators Logo
279 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
