Cameras Logo
A
Anonymous Posted on Nov 08, 2012
Nikon d3100 r07 error
2 Related Answers
Andy
  • 262 Answers
  • Posted on Apr 22, 2011
SOURCE: Could you please tell me what r07 error in my
This is not an error, it is telling you how many pictures can be taken in quick succession and stored in RAM, for writing to the memory card at the card's speed. It's described at the bottom of page 36 in your manual, I looked it up.
Anonymous
  • 214 Answers
  • Posted on Jun 04, 2011
SOURCE: "Error. Press shutter release button
hiit is not easy to tell what exact problem. It has quite of causes in your case. But I can only tell most common cause that it is sequence unit fail. It could also other like shutter fail, mirror box mech fail, motor fail, control pcb fail, and so on...etc...I recommended you bring to your local service place or Nikon service center which is helpful to you.
1helpful
I'm using a Nikon D3100 with a kit lens & my 55-200mm lens. And most of the time I encounter a problem every time I press the shutter button due to r07?
  • The "r07" message on a Nikon camera typically indicates the number of available shots in the camera buffer. It's not an error but rather an informational message. The number "r07" means that there are seven shots available in the camera buffer before it fills up. This is a normal part of the camera's operation and doesn't necessarily indicate a problem. It's more noticeable when you're shooting in continuous or burst mode. If you experience issues beyond this, it's advisable to check your camera settings and consult the camera manual. https://caranddriver.com/
1helpful
I encounter a problem r07 using my Nikon D3100 with 18-55mm kits lens or my 55-200mm lens. How can I fix this? Thank you.
On Nikon cameras this isn't normally an error code. Have you got a memory card in the camera? Check that it isn't nearly full.
r07 common comes up as an information prompt referring to the memory space in the camera. '07' being 7 shots remaining.
If the card isn't full try this. Turn the camera off. Remove the battery. Remove the memory card. Leave it like that for at least 15 minutes. Connect the memory card to a computer or a laptop and check you can still look at and move the images that are on there. This is to check the memory card isn't corrupted (developed a fault).
2answers
I just bought a sigma 70-200 f2.8d ex apo hsm for use on my Nikon D3100 yet and it won't work despite the seller saying it works on his same model, it managed to work for about three pics then nothing and...
R07 is just the number of shots remaining in the camera's image buffer. It is not an error number.
The Sigma EX 70-200mm f/2,8 APO HSM DG Macro is listed a compatible with the Nikon D3100.
Did you check the AF/M switch is set to AF?
I hope this helps in some way.
Oct 08, 2014 • Cameras
Autoexposure error
Needs a new aperture base plate, Can only be put in by camera repair person, Major work, At least $ 145.00
Nikon d3100 error
Could you be a little more specific? Exactly what does the error message say? What are you trying to do when this happens?
2helpful
Error in D70s
The r07 is just a display that tells you how many pictures you have memory for in the buffer. It's not an error code at all. It will change when you change resolution, since pictures at low resolution take less memory than at high resolution. On the D70s this number will go from about r04 to r11 as you go from RAW down to low resolution.
1helpful
R07 Message When Shutter Release Is Held Down Halfway
The r07 is not an error. It's simply telling you how many more shots you could take in burst mode before the buffer fills up.
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
