Question about Philips 60PP9352 60" Rear Projection Television
I have no control on the tint (faces are green & cannot adjust)
I have put this unit on a color bar gen. The tint has no control at all, I have checked all connections to no avail. I would appreciate any help in this matter.
  • hesco Jan 20, 2009
    there is no glycol on the board as I have stated there is no control at all with the tint control it shows that the range is adjusting with the remote, but to no avail.
    I have found no referance in the digital set-up. I have been a Electronic Tech. for the past 40 years, and I do know about electronics with a very extensive background in the Television Industry.
  • hesco Jan 22, 2009
    the gray scale is fine the on screen display for the tint shows the values changing but the tint does not change at all.
  • Philips Master
  • 8,617 Answers
The first thing that comes to mind is that the coolant needs replacement in the CRTs especially the blue and the green. remove the rear panel and while the set is playing look directly into the lens of the Blue and the Green CRTs. You will notice right away if the coolant is comgealed or has bacterial growth in it. The red is hardly ever affected. My quess is that the coolant will need replacement.
Posted on Jan 22, 2009
  • Philips Master
  • 19,396 Answers
This is a rear projection CRT TV, on this kind of set a convergence problem can easily be confused with RGB gain problem.
If you cannot set up RGB using color bar generation, ensure that all CRTs are working, and test the STKs and pico fuses on the convergence board.
If convergence and CRTs are OK, then test RGB circuit.
Posted on Jan 21, 2009
    Sergeant:
    Scholar:
  • 199 Answers
Either can be the effect of the magnetic field causing this.this mostly causes if its placed near to any such electronic device thats breaking the megnetic effect on the tv screen.keep it away from all the other electronic devices for two three hours and then check.keep the tv on for that 2-3 hoursbut away from the devices. if that does noit solves the problem.then it could be the inner main circuit board problem.the stk ic must be checked and replaced.
Posted on Jan 20, 2009
  • 10,594 Answers
I do not have schematics of this TV, Philips, 60PP9352 but what comes to mind, does TV show green tint in Color or in gray scale picture (colors off)
If TV gives green tint in colors, then it can be problem of Burst signal, reference signal from fly-back (H-pulse) in color decoding circuit.
If green tint in gray-scale (colors off, black n white) then its problem of white balance adjustment. Requires RGB gain adjustment.
I need service manual or exact model number of this TV to go further in diagnosis.
    Scholar:
  • 160 Answers
It indicates problem with stk ics on the board.replace them to solve the problem
  • chapli Jan 20, 2009
    It needs to be degaused,it is caused by the earths magnetic force, or could be caused by if you have un-shielded speakers too close to it, the magnets will cause it.
    Brigadier General:
  • 8,619 Answers
Hi!
I will say that you probably still have the clear liquid (Glycol) still on the board. I recommend cleaning with a degreaser spray and brush it off with a clean 1inch paint brush. You can get the spray at Radio Shack The glycol is hard to remove and is conductive to electricity.
  • Rylee Smith
    Rylee Smith Jan 20, 2009
    Also, check user convergence adjustment is set up per user instruction manual.
  • Rylee Smith
    Also,contaminated coolant in front of green CRT would be another reason for green tint. The coolant can be replaced seperately from tube saving on repair cost.
    Thanks
    Rylee
When I take pictures now with my A85 the tint is green, my pictures have more of a green tint. is there a way of adjusting the color.
Sounds like the camera was adjusted for flourescent lighting. The PowerShot should have a menu with various Lighting scenarios such as natural, outdoor, nighttime, sepia, etc. I would check this first. It should be easy to find. If you can't adjust the color properly with these pre-set options, there may be an RGB adjuster although I doubt it. You can certainly use a photo editor on your computer easily as well to adjust the color balance easily. If you don't use Photoshop there are free online photo editors such as http://www.gimp.org. You want to look for Color Balance and an RGB slide bar, it is quite fun to play around with.
May 10, 2011 | Canon PowerShot A85 Digital Camera
I can't seem to correct a tint problem. The tv turns on and the tint doesn't change. A friend says it could be a vidoe card?
Go to menue on controller, then Picture, then adjust Color and Tint to you taste. The color ajusts Blue and Green move left more blue move the slider right more green. The Tint controlls red. More red move right less left. Also chech Color temp setting.
Nov 08, 2009 | Akai PDP4225M 42 in. Plasma Television
Cannot adjust color
Have you turned the controls from one of the presets? Presets are Vivid, Movie, etc. Most sets have to be in Custom or Customize to adjust the controls, likely on-screen with one of contrast, brightness, color, or tint selected. If those are horizontal bars then up/down selects which and right/left select decrease/increase or red/green for tint. Start with 50% if no reset (0% for R/G) or start with the non-Vivid settings. Consult AVS forums for you model to get better settings. Rules of thumb: Brightness should be as dark as possible without losing gray scale at lowest part. Contrast should not be so high that whites bloom or make it hard to see. Color should not blow out any color nor be unnatural. Tint is best judged on flesh tones. -Ken
Jul 15, 2009 | Insignia NS-L32Q-10A 32 in. HD-Ready LCD...
My vizio hdtv color is off and i need help adjusting it
We had the same problem (for about a week) and finallly realized that the kids had played with the cords in the back of the TV and one connection was loose.
Mar 26, 2009 | Vizio VW32L 32 in. LCD HDTV
Zenith Model SY2551S 1996 27" - Green Tint
The core problem with the green tint is the aging of the picture tube, and can be compensated a bit by using either the green drive control usually located on a printed circuit board on the neck of the picture tube or on the main chassis. There will be 3 main controls which will adjust the red and blue as well. If these controls are not present then you will need to get into the service menu and adjust it from there. Don't adjust anything else as you can make the set much worse. Also remember that in order to make these internal adjustments while watching a black and white picture (turn the color all the way down) you will have your hands and arms near live circuits that could shock you and cause injury to yourself as well as break parts inside the set when you pull back after being zapped (voice of experience here) Of course if you can do all this by the service menu then you won't even have to remove the back of the TV.
Sep 08, 2008 | Zenith C27A24T 27" TV
G2 alignments?
Hello YankeeTwidgt,
Here we go you will need a schematic diagram (You may already have one but I thought I would mention it ), an oscilloscope, a TV signal generator (NTSC color bar, RGB purity screens, and pattern screen), and a voltmeter (I would prefer you have a VTVM, but a digital meter with high impedance (>=10M) will be ok).
First turn all of the color and tint controls completely down (This includes the main color and tint and the pre-amp color controls if you have access to them).
Then turn the RGB pots fully counterclockwise.
Once this is done connect the signal generator set to channel 3, and set to the specifications on the schematic, use the color bars, what you should see at this point are bars of various shades of gray.
Then turn the generator to the purity setting and set the pattern to red.
Once this is done your screen should be dark or dark red, gradually adjust the R pot until the screen is pure red and the voltages, and signals match what is seen in the schematic (mark this point on the pot and the return the pot to fully counterclockwise).
Do the same for the Blue and Green Controls (Blue first and then Green).
Once all of the pots are marked and turned to counterclockwise, set the pattern to gray purity, and turn the pots back up to their marked positions, the screen should be gray. switch to color bars and the screen should have the proper colors.
This is a course adjustment, and you will have to do a fine adjustment using the schematic, and the test tools, but this will put you way into the ball park.
The reason these pots are not talked about in gray scale adjustments is because they usually don't have to be touched. That's why it is important to get them back to specification using the voltmeter and oscilloscope to set the signals up properly.
I wish you success,
Shuttle83
Jul 27, 2008 | Philips 51PW9303 51" Rear Projection...
Green tint I can't seem to fix
Hopefully someone on here has a manual and can tell you exactly where the tint controls are. Also need to try adjusting the color level, turn it clear down so you have a black and white picture.
Is the picture still green over the screen with the color control
set clear down to black and white? If it does, you might
have an issue with the green gun going out or problem in the
circuitry to it.
By the way, the best way to adjust the picture settings on a
tv are to first turn the color control clear down, then adjust
brightness and contrast for best black and white picture, then
bring up the color level to where it should be and adjust the
tint for best red/green ratio.
May 20, 2008 | Mitsubishi CS-27205 TV
Red tint is gone
It sounds like the red cable on your component input is bad, one way to check this is press menu and see if the menu bars and letters are the right color. if they are then you may have a cable issue, if they are bad you may have a bad DG board in the unit. This will probably require a service technician. Hope this helps
Apr 03, 2008 | Panasonic TC-32LX20 32 in. HD-Ready LCD...
Green tint
Adjust the color temp, it worked for me. I had to turn mine off but now the color is perfect.
Jan 24, 2008 | Dell 3200MP Multimedia Projector
Blurry Images
Hello paulaspec,
You have a problem with the three factors, and they are screen voltage, focus voltage, and control (focus 2) voltage. Basically these voltages have to be adjusted since the components in this section have aged some. These controls are usually located in the television on the IHVT (Integrated High Voltage Transformer) or as it is also called the flyback transformer. these controls must be adjusted together, along with the color controls. Here is how the adjustment is done (You will need a schematic diagram, a DC volt meter, and a color bar generator to do these measurments):
1) turn color and tint fully counter clockwise until you have a black and white picture.
2) connect the color bar generator to the TV (ch 3) and turn it on, you should see bars in various shades of gray
3) adjust as best as possible the color and tint controls to obtain the color bars on the screen Red Green Blue.
4) measure the voltages on the focus, screen and control grids of the CRT and match them to the schematic digram measurements.
5) adjust the focus screen and control grids to match the ones on the schematic diagram
6) once this is done then you adjust the color controls once again to obtain the red green and blue bars on the TV screen.
This should help if the CRT (picture tube) electron guns are still good and if the flyback transformer voltage supply is working.
However if you do not have a background in electronics please take the TV to a shop for repairs.
I hope this helps,
Thank you,
Shuttle83
Oct 16, 2007 | Sony KV-20M20 20" TV
Philips 60PP9352 60" Rear Projection Television Logo
66 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
