Question about Speed Queen Std32dg 30lb Stack Dryers
I want to replace the ignitor - Speed Queen Std32dg 30lb Stack Dryers
    Top Expert:
  • Speed Queen Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 09, 2012
One of the oven ignitors does not work
Most likely replacing the ignitor will fix it. I usually replace Viking ignitors with Maytag ones, part number 12400035 (you'll need splice wires and use included wire nuts to connect those, though). Those have a little shorter base, which does not affect anything. Replace both bake ignitors if you can, otherwise, one of the burners will ignite slower and shut off faster, resulting in uneven bake.
Jul 17, 2010 | Viking VGSC306-4B Gas Kitchen Range
The oven will not cook on bake
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Apr 24, 2010 | Maytag MGR5750 Gas Kitchen Range
Oven
Mar 28, 2010 | Kenmore 73422 / 73424 / 73429 Gas Kitchen...
The oven wont turn on the gas range works the broiler works but i cant use the oven to bake i t says pre heat and does nothing
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. Amperage should be 2.5-3A. If less than 2.5A - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Ignitor part numbers : WB2X9154, 4342528, SGR403, 5304401265;
Those ignitors are interchangeable, if you can splice the wires. If not comfortable splicing wires - replace it with the first one in the list, should be direct replacement.
Feb 26, 2010 | Hotpoint RGB790SEHSA Gas Kitchen Range
My ge gas range wont work on BAKE but everything else works model JGS905SEK2SS
Find the bake ignitor (you may need to remove bottom drawer or oven cavity floor to get to the ignitor). Turn on the bake. If the bake ignitor comes on (starts glowing after a few seconds) - check the amperage on the bake ignitor wires when it's on. Should be 3 - 3.6A. If less than 3A - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Part numbers, the first one being the direct replacement: WB13T10045, 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Those ignitors are interchangeable, if you can splice the wires, if not comfortable splicing wires - order the first one.
Feb 09, 2010 | GE Profile JGB900 Gas Kitchen Range
Gas oven, cleaning works, but oven won't bake
If the bake ignitor comes on (starts glowing) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. If there is a line voltage on the ignitor and it's not coming on - replace.
Dec 13, 2009 | Maytag MGR5755QD CleanDesign Gas Kitchen...
Oven glow plug not turning on to bake
Nov 13, 2009 | GE Spectra JGBP35 Gas Kitchen Range
Ignition for the bake lower burner not lighting up
Sep 15, 2009 | Hotpoint RGB745 Gas Kitchen Range
Ge gas oven does not heat on bake
Sep 07, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
KitchenAid GST300FWO  Range works Broil works Bake does not get any gas no blockage from gas control to tube What needs to be replaced?
Part numbers, the first one being the direct replacement: 9751123, 5303935067, 786324.
PS Ignitors are fragile, handle with care, don't bump or drop one.
Jan 31, 2009 | KitchenAid KGST307 Gas Kitchen Range
Speed Queen Std32dg 30lb Stack Dryers Logo
21 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
