Question about Homelite Garden
Won't prime the carburator to start
  • 430 Answers
If the primer buld is hard to push or wont return to shape like its supposed to then there is an obstruction in the carb. If it just wont move fuel then there is a hole in the fuel line or the fuel line is rotted off in the tank.
If the primer bulb itself is discolored ( should be clear not brown) it should also be replaced.
Posted on Nov 12, 2012
Toro Power Clear 418 ZE Snow Blower won't stay started
The main jet of your carb is clogged and you need to open carb and clear the obstruction - spray carb cleaner on the bolt that holds the gas container to bottom of carb - also spray all the innards along with any tube that protrudes into the gas can.
Then using air compressor blow the sucker out and reassemble. That should do it.
Dec 06, 2012 | Toro Garden
My blower sounds like the carburator or something is loose and it won't start easily and when it does it won't stay on or doesn't have good power
With the unit off, grab the carburetor and see if anything is moving. Sound like the cylinder may be loose. Before tightening cylinder screws check if the gasket is damage. If yes then change gasket.
Nov 12, 2012 | Craftsman 2-Cycle 27cc Handheld Blower/Vac...
Pool won't hold prime. I cleaned the filter & basket. Prime is slow to come up but then surges up and immediately drops back down.
check top seal make sure its not damaged if ok check to see if intake union is tight if still bad check impeller for debris
Sep 06, 2012 | Pentair 1.0 Hp Whisperflo Pump
Brand new Briggs & Stratton lawn mower Model 90000 E series won't start.
trry a shot of starting fliud see if it wont start then make sure your getting a spark to
Jun 13, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
Hi everybody , i've got a carburator issue on a Husqvarna 24c trimmer it just won't start , gaz don't reach the engine. The problem is that the gaz just don't get out of the carburator to...
Check there is no damage to the fuel line. and that the carb 'primes' I can send you the manual but i need to know the exact model.
Oct 17, 2011 | Husqvarna Garden
Won't start, appears to be getting gas, primer bulb full.
HELLO. DO YOU HAVE THE USER'S MANUL.? IF NOT HERE IS WHAT YOU CAN TRY.(1) FIRST . TAKE OFF THE AIR CLEANER. AND CLEAN THE FILTER.. USE A LITTLE DISH SOAP LIKE DAMW.DISHSOAP AND WATER. ONLY. WASH & RINCE OUT.! THEN DRY IT OUT. (2) THING TO DO IS PULL THE SPARK PLUG OUT. AND REPLACE WITH THE SAME AS WHAT IT IS IN IT. (3) OR U CAN CLEAN IT WITH A TOOTH BRUSH & A LITTLE GAS ON IT. OR STARTING FLUID ON THE BRUSH .CLEAN IT THEN LET IT DRY OUT. AFTER THEY ARE DRY. (4) PULL ON STARTING ROPE WITH OUT THE PLUG IN IT. 3- 4 TIME'S . THEN (5) WITH THE AIR CLEANER OFF & THE CHOKE OPEN. LOOK IN THE CARBURATOR AND PUSH THE PRIMER BLUB. TO SEE IF IT IS GETTING TO THE CARB.? YOU SHOULD SEE IT OR HEAR IT OR SMELL IT.? IF THERE IS TO MUCH.&. IF THERE IS.! THEN PULL THE STARTING ROPE AGAN 3 TIME'S . (6) THEN PUT A VERRY SMALL AMOUNT OF GAS IN THE PLUG HOLE AND PUT THE SPARK PLUG BACK IN. & WITH THE AIR CLEANER OFF PUT THE CHOKE TO THE STARTSPOT.. PRIME IT 2-3 TIME'S WITH YOUR PRIMER BLUB AND TRY TO START. IT. IF NOT (7) PULL THE PLUG OUT AGAIN , AND PULL THE ROPE AGAIN 3 TIME'S . (8) THEN GET STARTING FLUID AND SQUIRT SOME IN THE PLUG HOLE & PUT THE PLUG BACK IN. ..THEN SQUIRT A LITTLE IN THE CARB & TRY TO START IT . IT SHOULD WORK. . IF YOU DO THE SOLUTION'S FOR THE PROBLEM YOU ARE HAVING THANK YOU . REMBER TO VOTE FOR ME THANK U.?
Jun 08, 2011 | Mantis 2-Cycle Tiller
HI there, I got a lawn mower mtd yard machine briggs ans stratton 4,5 hp, it start pretty well but won't stay running, I change the spark plug, oil, gas brand new, clean the carburator, clean the air...
There could well be a build up of sediment and debris in the main jet to the carburetor. It is easy to get to and clean. It is the brass bolt that holds the lower float bowl onto the main body of the carburetor. To clean it, drain your gas. Remove the bolt and external washer UNDER the carburetor bowl. Clean out the bowl of any sediment and/or water. To clean the brass bolt, use no metal objects. Carb/Choke aerosol spray cleaner will do the job. Pay close attention to the hole in the bottom of the bolt and the very small holes about 2/3 of the way up the bolt. Clean till shiny with holes cleared and reinstall. Your fuel flow problem and shut off condition may be solved.
Jun 05, 2011 | Mtd 22" Yard Machine Push Mower
Starts but after of running a while will not restart the more i prime the pump it starts and runs nothing else wrong with it
There is no priming of anything
If your talking cycling the key to start the
fuel pump,then maybe the fuel pump
is worn & not building pressure, to always
start the car quickly
The TPS Sensor moves a you push the gas
pedal. It may be worn
There is no corrolation to your foot & fuel issues
Those where the carburator days over 25 years ago
May 23, 2011 | Kia Sedona Cars & Trucks
Garden Logo
329 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
