Question about ADI Corporation MicroScan 5P (White) 17" CRT Monitor
Adi microscan a701 - ADI Corporation MicroScan 5P (White) 17" CRT Monitor
Where can I find a manual for the A701 food mixer
They do not have a manual for the Kenwood Chef A701. However, there is a manual for a Kenwood Chef A701 available for download see www.kenwoodservice.co.uk/instructions/UK/instructions-A701.pdf. There is also some discussion on Martin Lewis' Money Saving Expert Forum see forums.moneysavingexpert.com, about instructions for the Kenwood Chef. I hope this is of some help to you.
Thank You.
Mar 09, 2011 | Kenwood Food Processors
ADI monitor , model 937g, power supply dead , fuse is ok ,what could be the problem ?
replace 100uF/63V condesator and check transistor
BUT12AF if this is ok? check resistor 470k ohm and 1.2M ohm if the value is correct
Feb 11, 2010 | ADI Corporation MicroScan 5P (White) 17"...
ADI GD-166G SCREEN HAS GREEN COLOUR DISPLAY
hope u r a professional..as u r handling chip-level repairing of monitor, knowing itz hazardous n dangerous..
however, check thoroughly for dry soulderings..(esp. at the crt base)..[this chance is maximum]..
see if the base is loose or faulty..
yes, it can b the 'chroma ic'..but don't ignore the associated components..(esp around the base)..
check video amplifier n sub section..
the colour diodes, transistors n resistances at the base..
for better supervision contact ur system admin/vendor....
Nov 11, 2009 | ADI Corporation MicroScan 5P (White) 17"...
ADI Microscan repair manual
http://www.mediafire.com/file/taanzydizgi/adi schematics.rar
here I got some schemes for adi ..monitor ...and I also put a reader cause the files came in djvu file format ..I hope this is what you was looking for ...
I also located another repair manual but Im afraid is not free they do want a few bucks on download...I will put a link just in case...
http://www.spotbit.com/main/magazine.php?&prod=1721
Oct 07, 2009 | Computers & Internet
Adi microscan monitor 17 green screen
this is a loose cable from the monitor vga. please make sure the cable is secure from THE monitor side
It is a connection somewhere. It can be the cable, monitor, or video card. If you another input on the monitor i.e. DVI try that with a different cable. If there is another output on video card try that. Mix them to test. trial and error.
Odds are there are some smashed pins.
Jul 18, 2009 | Computers & Internet
Better/higher Colors for ADI CM900?
sounds like the CRT is on it's way out. open it up and check what brand the CRT is, if it's a samsung. chuck the monitor.
as good a manufacturer samsung are. they can't make a CRT display for S@#$
Apr 26, 2008 | ADI Corporation MicroScan M900 (White) 19"...
ADI A905, No Display, but appears to get signal
I have the same problems as you. I found the only fix is to physically unplug the monitor from the wall outlet, and then it plug back in. Sounds like an internal design flaw.
Oct 02, 2007 | ADI Corporation MicroScan A905 Black 19...
ADI Corporation MicroScan 5P (White) 17" CRT Monitor Logo
Top ADI Corporation Computers & Internet Experts
David Payne
David Payne
Are you an ADI Corporation Computer and Internet Expert? Answer questions, earn points and help others
