Can the under-oven light switch be isolated and replaced or does the entire control board need to be replaced?
SOURCE: Underneath Light funtion stopped working on Kenmore 62642 model
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: Although I have changed the light bulbs, the
We see (and repair) this
by mail for $39.95 postpaid with a one-year guarantee.
At
our Web site, you can get details of our
service, plus we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
The lights can can be
inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly
affect the fan operation or inside light, too.
Testimonial: "Thank you for your prompt reply! You have confirmed what I had suspected and I will pass this onto the rental management company and your part fix. "
SOURCE: Have an old Kenmore 1000
Sound liek a problem with your hi-voltage system has gone bad. The noise you are hearing is the
hi-voltage transformer. This has taken the magnetron which does the
heating out.
If I dont mistake, the magnetron has a five year warranty on it, the rest of these parts only have a year on them. If your microwave looks and sounds normal but isn't producing any heat,
you should check the internal door switches, the high voltage circuitry
and the circuit board for problems. You will need a certified technician
to help you make these repairs.
Hope this helps.
