Question about KitchenAid Refrigerators
Kbfs25ewms5 vibration noise last stops if I stand in front of the fridge, but starts up again when I move away
  • jkong04
    jkong04 Nov 10, 2012
    the fridge makes the noise like a buzzing sound if I stand anywhere in front of the fridge even across the kitchen
  • jkong04
    it stops making the noise if I am infront of it but as soon as I walk away it starts buzzing again.
    Master:
  • 366 Answers
Check the feet are level by adjusting them until the buzzing/vibration stops ie make sure there is no slack between the feet and the floor.
Posted on Nov 10, 2012
  • 1314 Answers
SOURCE: vibrating noise from freezer/fridge?
take the cover off the fan in the freezer section and see if the fan blade is loose or hitting ice the blade just pushes on make sure the mountings are tight its probably the blade but you might need to replace the motor if i reamber correctly on the cover there is a screw at the bottom you remove then slide the cover up and its on hooks plastic hooks built on the cover ok
Posted on Mar 28, 2008
docjohn174
  • 943 Answers
SOURCE: Kenmore side-by-side stops cooling
hi thanks for the question if you turn the controls and then it starts i would replace the cold control if this part fails it will allow the fridge to get cold but not come back on just tapping the control will get it going again replace the cold control thanks the appliance doc
Posted on Sep 22, 2008
  • 30 Answers
SOURCE: ge side by side refrigerator problem
Sounds as if the compressor may have given out. You probably need to hire a professional to repair this unit. It is possible that the start relay is broken but without a model number I can't tell if you have a packaged start relay or if it is an easily obtainable standard overload and start relay kit.
Posted on Feb 01, 2009
whytfang
  • 170 Answers
SOURCE: Whirlpool Fridge Making a rattling noise
There are 2 areas it could be in....The upper area where the evaporator fan is....or the lower area where the condenser fan is..
If it is in the freezer...when you open the door there should be a button that the door connects with that you can hold in manually to make the fan engage..and listen for the noise..the odds are if it were ice build up....your thumping the fridge would not make it stop ..since the thumping would not remove the Ice...it would continue to build up and the fan would eventually stop completely and everything would warm up. It could be a loose stap that holds evaporator lines in place or a motor mount that is loose ..
Or it could have to do with the condenser fan..where the compressor is.The compressor and condenser coil are located underneath the freezer section of your refrigerator. There is some tubing connecting the compressor to the condenser coil. There is also a condenser fan to cool the condenser. To access these parts the refrigerator has to be pulled away from the wall. If you pull the refrigerator out go slowly and watch the tubing that connects from the water valve on the back of the refrigerator to the water cut off at the wall.
Remove the power from the refrigerator. Remove the lower panel on the rear of the refrigerator. Look inside for anything loose. Locate the condenser fan motor and blade. These are the areas to stay away from when power is applied. Plug the refrigerator back in being careful to avoid the condenser fan motor and blade. Wear gloves to prevent burning yourself on the hot refrigerant lines and try touching tubing and lightly pushing and pulling to see if you can cause or stop the noise.
Generally a rattle or hum is caused by a refrigerant line touching part of the cabinet or base pan. If it is not repaired it may rub a hole in the refrigerant line causing the refrigerant to leak out. If you don't feel comfortable trying to correct it, you should schedule service and let a technician repair the refrigerator.
I hope this helps...please rate me ...thanks The Fang
Posted on Mar 27, 2009
  • 259 Answers
SOURCE: Noisy Fridge !!
is the fridge on a level and solid surface ?? hope this helps regards Jim
Posted on May 10, 2009
Brand new Sharp Fridge Freezer Clicking noise
Make sure that the unit have adequate ventilation at the back , move the unit forward a few inches ( in your direction , standing in front of it) Make sure the unit don't touch anything surrounding it ..
Dec 03, 2013 | Refrigerators
Brand new Kenmore mini fridge is making an annoying whistling noise
If Sears did suggest a solution for the symptom you describe it would probably be to replace the fan.
Nov 21, 2013 | Kenmore Refrigerators
My car is making an awful groaning grinding noise noise when it starts. The noise stops after it starts. Put my foot on the brake it starts again. put thr car in reverse no problem put it in,drive it...
It's your exhaust mounts or broken exhaust bolts. It does it in drive st idle n under load because the motor is sitting in rubber mounts made to dampen vibration. Therefore the motor tilts to the left in reverse pulling the exhaust away from your under carraige, and to the right in drive causing the loose exhaust to vibrate against something. Check your heat shields also. They fall apart n do the same noise. Piece of cake.
Sep 24, 2012 | Cars & Trucks
How do I stop the loud knocking noises coming from my refridgerator?
Pull the fridge away from the wall and inspect the compressor. Your description sounds like the compressor is hitting something. It is rubber mounted and usually can be pushed away from whatever it is hitting.You do not want to jamb something to stop the noise, as the compressor needs to move freely. Many compressors shake during start up and shutdown, and this is considered normal. Abnormal if the compressor hits something during this movement.
Feb 05, 2012 | Kenmore Refrigerators
From a stand still if you accelerate hard vehicle starts vibra
Well, kind of short on description, issues typical in this complaint are misfiring and U joints.
To emininate the engine, does the vibration happen on power braking, without the vehicle moving?
May 24, 2010 | 2000 Chevrolet Blazer
Frigidaire side by side making a vibrating/humming sort of sound
When a fridge is first installed it is important it is adjusted to stand level and firm. If it was transported upright and hadn't been laid down it could then be switched on but if it had been laid down during transit or during installation it should be left to stand before switching on - some authorities say four hours and others say longer.
Failure to do either of these things can cause accelerated wear of the compressor and that could be the reason for the humming noise and vibration.
A friend has the same problem with his fridge and he freely admits it was never properly levelled. It began vibrating years ago for a short time when it starts but apart from that it continues to work quite well.
Just to be on the safe side of fairly sure, it would be a good idea to check the security of the compressor and fixings...
Apr 18, 2017 | Frigidaire FRS26H5AS Side by Side...
Vibration/Humming/Grinding noises when stopping or turning left.
when turning left vehicle distributes weight to right front wheel bearing causing load. since u describe a noise in right front while driving straight i would suspect failed right front wheel bearing. see if your noise changes/goes away while turning right that should tell u 4 sure
Nov 15, 2009 | 2004 Chrysler Town & Country
Noisy Fridge !!
May 10, 2009 | Refrigerators
2000 subaru outback/ clunk when i put it in reverse
Turn off engine . get the vehicle on level ground. try to move driveshaft back an forth or,by rocking in twist motion,,, try to hear a knock,,,this would indicate a worn universal joint.either front or back, if you are good enough to discern which one is making the klunk, change both to be on the safe side. think they may be about 20 dol apiece.
May 14, 2017 | 2000 Subaru Outback
Refrigerators Logo
118 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
