Question about iRobot 5800 Scooba Vacuum
Battery door will not open
New Roomba 3800 - battery door will not open.
You have to push down on the plate to open the door. Make sure Scooba is on a flat surface, then push down. If the door doesn't release, try again. It sometimes takes a few tries, but that should work. If not, call iRobot Support. They are great and have helped with everything. I love my Roombas and my Scooba!
Posted on Jan 16, 2009
Amber flashing light while on home base. New, pulled tab, placed on dock. First time said charge err1, took out battery and replaced. Now just flashes amber. Is this correct?
Your manuals are here. Flashing lights must be covered. A quick look at the site says flashing red is bin full. In fact, I found it. Flashing Amber is CHARGING.
Roomba 600/500 Battery and Charging Overview On some robots, the CLEAN light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged . overview LabeledSupport ... clipped from Google - 12/2015 iRobot: Customer Care - Roomba 700 Anatomy images?q=tbn:and9gcss8oogw3vmcv_uom0z_pxoi9q5tq9n4aqrcwbsxn0zd1blfvnacictdbyn iRobot: Customer Care - Roomba 700 Anatomy Solid Red = Battery Discharged; Amber Pulse = Charging; Solid Green = Fully Charged; Quick ... The battery indicator blinks when there is a charging issue. LabeledSupport ... clipped from Google - 12/2015 iRobot Roomba 500 Series Battery Maintenance iRobot Roomba 500 Series Battery Maintenance Roombas "CLEAN" light should pulse red/amber while charging. ... Green - fully charged; Amber - partially discharged; Red - nearly discharged; Flashing Red - ... LabeledSupport ... clipped from Google - 12/2015 Roomba 400 Series/Discovery Battery and Charging Overview charging-overview Roomba 400 Series/Discovery Battery and Charging Overview Your Roomba's POWER light should pulse red/amber while charging. ... Amber - partially discharged; Red - nearly discharged; Flashing Red - discharged. charging-overview LabeledSupport ...
iRobot Owner Manuals and Quick Start Guides
Dec 31, 2015 | Roomba Vacuums
My robot wont work even with a new battery
Once of the problems with batteries is they tend to corrode the metal contacts. Try lightly scraping on the metal battery contacts inside the Roomba and also on the battery with a small screwdriver...this creates a clean surface and allows conduction between the battery and the Roomba.
Dec 24, 2014 | iRobot Roomba 560 Robotic Vacuum
I have iRobot Roomba 4210 and I have a problem with charge battery. The battery is new. When I charging a battery in other iRobot Roomba the battery was full charged. When I charging in my iRobot Roomba...
The charging circuit on the main board is fried. This is a common issue. You need some good electronic repair skills, and equipment, to replace the problem components
Nov 23, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
I have got a new battery and a new charge for my
Customer calls IRobot Customer Service (No Parts or Service Literature is available)
Customer Service at 877-855-8593
Nov 04, 2009 | Roomba Robotic Floor Bagless Vacuum
Our roomba 560 wont charge have replaced the battery Tested the charing unit with another roomba that all seems ok put the uncharged battery into another Roomba but im guessing it now has a memory as this...
Try cleaning the battery contacts with a little rubbing alcohol or contact cleaner on a foam swab, or a bit of paper towel. Take a litle time, it doesn't always dissolve instantly. (Don't use a pink pencil eraser, it would scrub off the plating that prevents corrosion) Clean both contacts on the battery pack and both of the contacts in the Roomba. Make sure the battery is oriented correctly when you put it back in. Also clean the charging base contacts and the corresponding contacts on the Roomba itself.
I'm not sure entirely sure what you're trying to recover - the new battery pack, the old battery pack, or the Roomba itself - but since you can swap parts back and forth, you can clearly isolate the problem. The old battery pack might be rehabilitatted if you have the equipment to recondition it, but if it may not work. The new battery shouldn't have been harmed that easily.
Oct 25, 2009 | iRobot Roomba 560 Robotic Vacuum
I have the irobot roomba and the battery does not hardly hold a charge and now it won't go forward just backwards and around
The Roomba has a rechargable Battery. The Roomba battery like any battery will eventually ware out after so many charges and discharges. Mine lasted about three years and then is would hardly hold a charge. I purchased a new battery and then it worked fine after that.
As for not going forward. That is usually due to a dirty bumper sensor. You have to take the Roomba apart for cleaning that. You can take it to Sears and they will do it for you.
Oct 01, 2009 | iRobot Roomba Discovery SE Bagless Robotic...
Model4210battry won't recharge, is it worth ordering a battery?
don't buy a new battery yet. you can reset the battery by charging for 16 hours, if this does not work, you need to take the battery out, push and hold the power button on your roomba for at least 15 seconds then reinstall the battery. plug in the charger directly to roomba not the docking station and charge until the battery light on the roomba is green. do not interrupt the battery charging cycle. after, leave the roomba charging for an additional 3 days or 72 hours. after, run roomba in max mode and run it till the battery is completely depleted. this will improve the battery overtime by charging again for 72 hours and depleting the battery. do this 3 or 4 times. and the battery should get better
Jun 28, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Roomba red battery
on the ends of the battery are two yellow clips. push these towards each other and pull up at the same time.
Jan 10, 2009 | iRobot Roomba Red 4100 Bagless Robotic...
Roomba 4200 Scheduler
The best for the battery if (NiMH). Discharge completly, than charge full (charge more even the charger indicates full charge)
Clean every part, maybe a hair slow down the wheels and thats why need more power.
Here some tip from the web:
With proper care, one iRobot Roomba battery can last for hundreds of cleaning cycles before you need to replace it. Here are some things you can do to extend Roomba's battery life and keep Roomba cleaning at peak performance:
Use your Roomba frequently. Your Roomba is powered by a rechargeable nickel metal hydride (NiMH) battery, which lasts the longest when you use it regularly.
Keep the brushes clean. If the brushes and brush axles get clogged with hair and other debris, your Roomba will strain to spin them, using more battery power than normal. In extreme cases, the battery can even be damaged. See How to remove and clean Roomba's brushes
Keep your Roomba plugged in when not in use. If you have a Home Base®, keep your Roomba docked in the Home Base and plugged into the charging brick. If you don’t have a Home Base, keep your Roomba plugged into the APS Fast Charger.
Make sure you are charging your Roomba correctly. When your Roomba is plugged in correctly, the solid green light should be illuminated on the charger or on the Home Base.
Plug your Roomba in as soon as possible after using Max Mode. Leaving your Roomba unplugged for more than 24 hours can damage the battery.
Place your Roomba and the Home Base on a smooth, hard surface when yourRoomba is plugged in. Make sure your Roomba and the Home Base have plenty of space for ventilation. Do not charge your Roomba on a carpet or rug.
Charge and store your Roomba in a cool, dry place. Keep your Roomba out of direct sunlight and away from sources of heat such as windows, radiators, heating vents, and large appliances.
Remove the battery when not using your Roomba for a long period of time. If you will not be using your Roomba for more than a few weeks, fully charge the battery, remove it, and store it in a cool, dry place. When you want to use your Roomba again, insert the battery and fully charge it. Leaving your Roomba plugged in for weeks when it is not being used can damage the battery.
You can purchase a second battery or replacement online at the iRobot Store.
Nov 11, 2007 | iRobot Roomba 4210 Bagless Robotic Vacuum
iRobot 5800 Scooba Vacuum Logo
130 people viewed this question
Top iRobot Vacuums Experts
Shehu Pro
Shehu Pro
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
