Question about Sharp AR-M237 Copier
How to reset Sharp AR-M237 to factory defaults
Just installed a used board AR-P17 to allow access to photocopier from the network. The photocopier gives out the error code A0-01 and stops working (that's what it seems to do). Service manual says it is a security incompatibility and we need to match the board with the photocopier. However, there is no clue as to how this is done. Does anybody know anything about this ?
Cogz
  • 1326 Answers
SOURCE: Reset Code
Did you do a PM on the copier? Or do you just want it off the display? You need to get in to service mode with pressing "#" "Interrupt" "Clear" "Interrupt" then enter 24 "Start" then go to sub code 04 then press OK to clear count. To exit press "CA" Good Luck
Posted on May 15, 2008
  • 148 Answers
SOURCE: F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
Posted on May 26, 2008
  • 3 Answers
SOURCE: Code: E7-10 on Sharp AR-M237
Your lsu or laser scanning unit is deffective that's why E7-10 appears. it should be replaced
Posted on Mar 12, 2009
  • 120 Answers
SOURCE: how to reset u2-40 for sharp AR266 photocopier
Since this appears to be a non-US model I can only base my response on the closest US body type AR-M237.
U2-40 means the countdown (CRUM) chip in your toner cartridge either broke or went to zero. If you can put in a fresh CRUM chip in your cartridge, that's great, otherwise you'll have to replace the toner cartridge.
L4-01 means main motor lock, probably due to a brownout or otherwise missed timing. You can probably get by with a power off and on. Not sharing your copier with other devices on the same outlet will also help here.
To reset error codes, put the machine in test mode with the four-key combo: # - * - C - * ... 16-Start clears your U2 trouble, 14-Start and 17-Start clear the rest. Then hit CA and allow your copier to reboot. Good luck!
Posted on Jul 09, 2009
Sharp Tech
  • 63 Answers
SOURCE: Sharp AR-M237 EXPANSION MEMORY 8MB: AR-MM9 installation procedure
You are needing the installation manual for this. Please contact me so I can e-mail you the pages that you need. administrator@aokoffice.com
Posted on Oct 15, 2009
AR-M237 PRINTS BUT DOES NOT SCAN
You may have a problem with the physical board connected to the machine, try re seating the card with the machine off and unplugged. Its a data issue over the network, it may be the board itself. Try re seating it first.
Mar 23, 2010 | Sharp AR-M237 Copier
Please i need to reset my sharp ar-m236 password how do i do that
You can reset the nic card password by ressetting the nic card to factory defaults, custom setting, key operator, 00000 , print settings , network settings, reset the nic, default password is Sharp
Mar 15, 2010 | Sharp AR-M237 Copier
How do you reset the admin password for web login access on the Sharp AR-M237?
You must delete the printer and all software and reinstall. maybe a Tehnician can be PERSUADED to give you the default passwords.
Oct 23, 2009 | Sharp AR-M237 Copier
Oct 08, 2009 | Sharp AR-M237 Digital Copier
How to reset u2-40 for sharp AR266 photocopier
Jun 02, 2009 | Sharp AR-M237 Copier
Error Code E1-15 - can I fix this myself?
Most messages that state "call for service" are for instances where the unit is not running to prevent damage to the unit.
You should call an autherized or certified technician to work on the unit.
Apr 24, 2009 | Sharp AR-M237 Digital Copier
Sharp AR-5316 photocopier & printer driver
Sharp AR-5320 photocopier/printer is in share network. for each printing command ,its asking to install driver.and its taking more time for printing..
Dec 01, 2008 | Sharp AR-5320 Black and White Copier
Sharp AR-M237 Copier Logo
128 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
