Question about Amana Dryers
Amana Commercial Quality Dryer Model #ALE643RBW getting hot but not drying clothes
The dryer seems to get hot because when you open the door the heat pours out, but the clothes just don't seem to ever get dry on the first pass. You've got to run them through 3 or 4 times before they get dry.
SOURCE: dryer gets hot but wont dry clothes
should the top of my 10 year old Maytag dryer feel almost hot to the touch
Posted on Oct 11, 2009
techline
  • 39 Answers
SOURCE: the gas dryer is not getting hot enough to dry
In light of everything you checked, it sounds like you have a bad set of coils on the gas valve. When they go bad, it can take a long time between cycles. Hope this helps!
Posted on Dec 08, 2009
Testimonial: "thanks-the hunt continues"
jsrock516
  • 5911 Answers
SOURCE: Dryer has to be ran 2 to 3 times to completely dry clothes.
If your dryer is heating, but you are experiencing longer dry times and poor drying efficiency, the following link can give you some items to check before you assume there is a malfunction with your dryer:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
The number one cause of dryer heat related problems is poor exhaust ventilation. If not vented properly, a dryer will not dry efficiently, will take longer than required to dry, and will cause the heating circuits to overheat to the point of failure. The dryer will actually seem hotter as the heating circuits begin to overheat. This is also the source of many fire hazards if not resolved. Read through the link provided and review some of the potential causes.
If you have any questions, please post back and let me know. Please include your MODEL NUMBER (if it is different from the one you listed this question under), so I can determine how your dryer is configured. I hope you find this information is helpful.
NOTE: If you thoroughly check everything and still have problems let me know. The problem could be related to a thermostat beginning to fail.
Posted on Feb 08, 2010
  • 45 Answers
SOURCE: Dryer not heating up - Amana Model # ALG643RBW
Heating element
Posted on Apr 28, 2010
SOURCE: Dryer heats up but clothes won't dry
I have an amana electric dryer. Changed out thermal fuse and cleaned out vent. Thermal fuse is blown again, but I noticed that it is not cycling. The dryer is very hot on the outside on top.
Posted on Sep 11, 2011
My dryer is running hot but doesn't dry the
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 05, 2011 | Whirlpool Electric Dryer Heating Element...
I have a amana dryer ale643rbw that wont get hot and wont shut off.. do you know what the prob could be?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
May 16, 2011 | Amana ALE643RB Electric Dryer
Regardless of settings, my Amana Commercial Dryer does not stay hot all the time whilst drying. Sometimes when I open the door, the air clothes are cool to the touch. Then some time later they are hot...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 26, 2010 | Amana Dryers
Dryer tub doesn't spin - motor runs and hot air comes into the tub area but the tub itself has quit spinning. Could this be the belt since the motor is running and the dryer is heating up? This is an...
Unfortunately you will have to search for thebelt with auto stores to see if any of the models will match. Check to see if any machine spares shops can help, get intouch with industriaal spares outlets to help you.
Sep 23, 2010 | Amana DLE330RAW Electric Dryer
Amana dryer does not heat sufficiently
The problem is the dryer coils are failing. They tend to fail as they heat up. They are inexpensive and easy to replace. Here is a link that should help http://appliancehelponline.com/gdryertroublevideo.html
Jul 27, 2010 | Amana ALG866SB Gas Dryer
Amana dryer not advancing on auto
Make sure the vent from the dryer to the outside is clean.
Reduced air flow can cause your symptom.
You can remove the vent hose from the dryer and operate the dryer in the automatic cycle.'
If the timer advances you know the vent needs cleaning.
Clean the lint filter housing also.
A flashlight helps to see all the way down the housing.
Jan 20, 2010 | Amana ALE643RB Electric Dryer
Sounds like to me, that you need to check the vent going outside from the dryer. I had the same problem, and found a birds nest in the dryer vent on the outside of my house restricing air flow. If that doesn't fix the problem, look into a new heating element and or thermostats for the dryers. The old ones could just not be getting hot enough anymore. Good luck.
Apr 08, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
29 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
