Question about HP DesignJet 1050c plus InkJet Printer
Solutions for error 0b000d 0000000a on hp designjet 1050c plus
2 Suggested Answers
antiochpc
  • 1314 Answers
SOURCE: System Error 0B000D 0000000D on display, nothing prints
Hello.
From the service manual:
System Error: 0B000D
Problem
Description:
24 V source test failure.
Corrective Action: Replace the Electronics Module
HP Part number: C6072-60146
I just looked up the pricing and it's not cheap. Let me know if I can be of further assistance.
Posted on May 28, 2009
System error 0B000D 00000005
Hi, I believe this error occurs when there is no 24 volt supply to the PCB. Go back and check you have plugged all the connectors back in correctly.
Thanks
Sep 29, 2014 | HP DesignJet 1050c plus InkJet Printer
Designjet 1050c system error 0A0050
0A0050 indicates a leak in the tube system has been detected. Can be caused by condensation, but more likely the tubes are leaking and need to be replaced.
Sep 01, 2014 | HP DesignJet 1050c plus InkJet Printer
0b000d 00000012
Hello. 0B000D error during start-up indicates a 24VDC failure. This is generally caused by a failed DC power supply. There are 2 types of power supplies - 1 for the 1050C series and 1 for the 1050C Plus series. They can both be found at: HP Designjet 1050C 1055CM repair parts
Oct 11, 2013 | HP DesignJet 1050c plus InkJet Printer
What is system error 0B0006 on Hp design Jet plotter? I have replaced the power cable but no luck
The Trailing Cable has been incorrectly connected OR the fuse in the Electronics Module has been burned.
Corrective Action: Turn the Printer OFF and disconnect the trailing cable. Check that the ends of the Trailing Cable are flat and are not damaged or bent. Reconnect the Trailing Cable correctly, making sure it is pushed in firmly. Do the resistance test. Power ON the Printer and check if the Error Code disappears. If the Error Code continues, replace the Main Logic Board
Note: The logic board is a direct replacement for the Designjet 1050C Plus and 1055CM Plus. If the plotter you are repairing is the Designjet 1050C (not Plus) you will also need to replace the memory and the firmware.
If you are repairing a Designjet 1055CM (not Plus) you will have to replace the Hard Disk Drive also. The firmware is identical for the 1050C Plus and 1055CM Plus
Note: The aerosol fan is not used in the Designjet 1050C Plus or 1055CM Plus. Coil the cable out of the way or completely remove the fan.
WARNING TAKE CARE WHEN CONNECTING THE TRAILING CABLE TO THE ELECTRONICS MODULE OR CARRIAGE. INCORRECT INSTALLATION WILL BURN THE FUSE IN THE ELECTRONICS MODULE, CAUSING THE COMPLETE FAILURE AND REPLACEMENT OF THE LOGIC BOARD. 100 OHMS OR HIGHER MUST BE SEEN AT THE TEST POINTS. CONSULT THE SERVICE MANUAL FOR CORRECT PROCEDURE.
Continuable and Non-Continuable Error Codes
Some of the Error Codes are continuable, which means you can press Enter on the front-panel and continue working with the Printer. Non-Continuable Error Codes do not allow you to continue working with the Printer, in this case power the Printer OFF and ON again and see if the System Error disappears. If the Error Code reappears, then the Printer requires service in order to resolve the problem.
System error codes are hexa-decimal based numbers generally caused by internal system errors. Only try one recommended action at a time and check if the error code has disappeared.
thanks and regards
kindly rate this solution
Feb 12, 2011 | HP DesignJet 1050c InkJet Printer
HP DesignJet 1050C stops printing - no error message
check all connectors on main pca. check trailing cables on carriage assembly. main pca may be bad.
Sep 08, 2009 | HP DesignJet 1050c plus InkJet Printer
Error code showing on my HP 1050c plotter
The error stands for : 24V source test failure.
And i'm sorry to say but the service manual then tells you to try the following:
- Replace the scan-axis motor assembly.
- Replace the paper-axis motor assembly.
- Replace the service station assembly.
- Replace the main pca.
- Replace the ISS pca.
- Replace the power supply unit.
- Replace the electronics module.
(only replace one component at a time)
Yeah then you have to guess which part to start with.
Maybe anybody else on this forum knows more about the error and has a better idee about the part you should start with.
Just take a good look at the machine, and check which sections of the start up works before the error is prompted.
e.g. If the carriage moves then you could say that the scan-axis motor is probably ok.
Good luck....
Sep 07, 2009 | HP DesignJet 1050c plus InkJet Printer
Configure of hp designjet 1050c
Manuals for the driver and plotter setup can be found here:
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=24023&lang=en&cc=us
Jul 24, 2009 | HP DesignJet 1050c plus InkJet Printer
Hello.
Problem
Description:
May 28, 2009 | HP DesignJet 1050c plus InkJet Printer
System Error 060308000008 on HP Designjet 1050C plus
that error show a problem with the pintheads
Remove ALL the Printheads and clean the flex contacts on the
Printheads and in the Carriage Assembly, if that dont solve the problem change printheads, if after that have the same problem call HP, was a hardware error.
Apr 30, 2009 | HP DesignJet 1050c plus InkJet Printer
HP DesignJet 1050c plus InkJet Printer Logo
146 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
