Question about Geovision GV-800-16 Video Capture
Key pro for gv800 - Geovision GV-800-16 Video Capture
I need a pc optimizer pro id and license key for free
Clean Up PC in Just Couple Clicks is much better than pc optimizer. I've used it both.... Check it.
May 27, 2012 | Computers & Internet
Gv800 software v8.3 after install into win 7 32bit pro with no problem,but when i login can not see anything , only the black image, why ??
You could try this in either order
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they might be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error If your computer came with a motherboard disc the drivers could be on it or you might have a dirty graphics card remove the graphics card and clean the socket
hope this helps you
Aug 17, 2011 | Geovision GV-800-16 Video Capture
Quick heal antivirus pro 2011 product key
quick heal antivirus pro 12.00(spi) product key
Feb 22, 2011 | AVG Anti-Virus & Firewall 9.0 (2...
I have a Geovision GV800 8.3.2, 16 channels and have 4 cameras installed. I tried to add 3 more cameras but they don't appear on screen, just on the Camera Record Setting, where the recording is ok. I've...
Hello
Have you tried at "Camera/Audio Instal" Menu?
Click the Configure button and select Camera / Audio Install to bring up the dialog box:
Click the Activate button and specify the cameras to be viewed
Hope that help.
Jan 09, 2011 | Geovision GV-800-16 Video Capture
Dear Sir, We would like to ask problem of my View Sonic monitor GV800, since yesterday the screen is totaly disappered. Thank you and we are hoping to receive a favorable reply from you. Best...
I am not sure how far you will want to do DIY repair works.
Most common failurs are due to bad caps, blown fuse or transistors in the power supply/inverter circuits.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Oct 16, 2010 | ViewSonic VG800 18" LCD Monitor
Geo Vision gv800 want to add more cameras
stop recording, go to the general configuration, cameras, click on the activate tab and then check the camera numbers that you want to activate
Nov 02, 2009 | Geovision GV-800-16 Video Capture
Gv800 16 camera keeps rebooting
It reboots because you probably have cameras that have a lost video. Disable these cameras and it will not reboot
Sep 17, 2009 | Geovision GV-800-16 Video Capture
GV800 software keep rebooting, anyone has any idea what's the problem is?
sounds like one of your cameras lost connection and the system is rebooting because of that. check the general configuration screen and make sure the reboot on exit is not checked, also check all of your camera connections to make sure they are all ok and receiving video on all channels.
Jun 24, 2009 | Geovision GV-800-16 Video Capture
Geovision GV-800-16 Video Capture Logo
78 people viewed this question
Top Geovision Televison & Video Experts
Rommel Balcita
Mark Magill
Mark Magill
U-Spy Store DBA Pro...
Level 1 Expert
Are you a Geovision Televison and Video Expert? Answer questions, earn points and help others
