Question about Milwaukee Drills
Adjusting clutch on screw shooter 6798-1
How to adjust clutch on milwaukee screw gun 6798-1
5 Suggested Answers
  • 142 Answers
SOURCE: Milwaukee magnum hole shooter drill cat #0234.1 chuck removal
counterclockwise
Posted on Jul 25, 2009
rowdy45176
  • 2176 Answers
SOURCE: Slipping clutch on low switch with Milwaukee 2601-20
this tool has a 5 year limited warranty so I would try and have repaired under warranty. I looked at a breakdown and it doesn't specify how the chuck is on but I would to think it is threaded. the clutch is an assembly and there are no replacements parts other than the assembly available. Let me know if you need more assistance.
Posted on Jan 31, 2010
  • 9 Answers
SOURCE: need to know how to operate milwaukee screw gun?
I hope you're talking screw gun and not drill/driver. Screw gun used specifically to set screws in drywall. Make sure you have proper tip in gun (usually #2 phillips). There should be a rotating collar on the gun to control screw depth. The screw should only "dimple" the drywall. It should not tear the paper but should be below the plane of the drywall. To check depth run a putty knife over the screw heads. If you hear it hit, screws need to go a bit deeper. To work quickly; lock the trigger on and place the screw on the gun. Apply steady pressure and let the screw walk into the board until gun breaks free. Takes a bit of practice but pretty soon you'll be flying.
Posted on Mar 04, 2010
FixYaSteve
  • 57 Answers
SOURCE: I am having difficult adjusting the Depth settin
Operator's manual is here.
To seat the screw deeper in the workpiece, you turn the adjustment collar to the right. To seat the screw higher in the workpiece, you turn the adjustment collar to the left.
If you've been using it a while and turning the collar is difficult, you've probably got some plaster dust, dirt, etc. built up in the threads for the collar. It's probably worth breaking that chuck and collar down, giving it a good scrub with an old toothbrush and putting some dry lube on it. I'm partial to Dupont's Multi-Use Teflon spray. It doesn't attract sawdust or dirt.
In the event you need it, exploded diagram with parts list is here.
If you don't want to mess with it, a Dewalt service center can clean your drill up for you pretty reasonably. I was in one in early June, 2010 and they had some 10% off service coupons sitting on the counter.
If this answer was helpful, please vote. Thanks!
Posted on Jun 14, 2010
My drill slips under high torque
check clutch adjust,put it in drilling mode
check if speed selector is in right position
after that if it slip aggain,you need a gearbox
Nov 04, 2012 | Milwaukee Tool Milwaukee 18V 1/2 In Hammer...
How do I fix my motor on my Milwaukee glue gun?
not sure if you're talking about a caulking gun or a heat gun, but click this link
http://www.manualslib.com/brand/milwaukee/
and download the manual for your model gun
Jan 30, 2011 | Milwaukee Tool Crafts & Hobbies
I have purchased three milwaukee screw guns in the past year and a half and all four of my batteries will not charge. when my first set stopped working i had to purchased another screw gun and within six...
The same thing happened to me. There is normally a 2 year warranty on the batteries from Milwaukee. You can't return them to the Home Depot, you have to send them back via a local repair center.
You won't be able to exchange the batteries at the repair center. The repair center sends them back to Milwaukee and Milwaukee will send replacement batteries. You will probably be able to find the closest repair center on line.
Sep 15, 2010 | Milwaukee Tool Garden
I have a Milwaukee band saw model #6225. There is too much clearence in between the rollers and the blade slants at an angle. I'm not sure if there is an adjustment or not. It seems when you thread the...
the bearing is on a cam bolt to adjust for various width blade thickness
there should be a lock nut to lock in position once the bearing is in the correct position
Sep 03, 2017 | Milwaukee Tool Milwaukee 6225 Portable...
Clutch problem on drill??
or it could be as simple as it became loose, open the chuck all the way , look into the hole in the middle,, you'll see a screw head,, tighten it
Aug 03, 2010 | Milwaukee Tool Milwaukee General Purpose...
Need to know how to operate milwaukee screw gun?
Mar 02, 2010 | Milwaukee Tool Drills
Slipping clutch on low switch with Milwaukee 2601-20 drill/driver. Can't separate clutch housing assy from drill. Is it pressed on? Same for chuck. I've removed the screw in chuck, still won't separate.
Jan 28, 2010 | Milwaukee Tool Drills
How does the adjustable depth drywall bit work? The bit inside keeps spinning and does not drive screw into sheetrock?
It's not the tip, but the screw gun itself. The screw gun has a clutch on it that allows you to set the screw at different depths. You must adjust the screw gun to the desired depth. The deeper you want the screw to go, the less the clutch will slip.
Jim
Jan 03, 2010 | Dewalt Drywall Screw Setter 50 Pk Part No....
Drills Logo
209 people viewed this question
Top Milwaukee Drills Experts
Jim Thurston
Mike
Are you a Milwaukee Drill Expert? Answer questions, earn points and help others
