Question about Hotpoint Washing Machines
Hotpoint wlw1500b washing machine
Knob won't turn
Buffalo12980
  • 625 Answers
SOURCE: HotPoint Top Loader model # WLW1500B
if you hear clicks then I'd have to say it was a mechanical timer. the timer has a small motor on it. a complete timer including its motor will run you about $120 but a replacement timer motor will be about $35.00
Posted on Sep 22, 2007
  • 6277 Answers
SOURCE: I have a Hotpoint Aquarius
(no promises but try this!)
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and general guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on May 07, 2011
marka19
  • 1430 Answers
SOURCE: Washing machine won't stop filling the tub when I
The problem is the pressure switch has failed or the hose is plugged up, has a hole in it. These are usually inexpensive and are very easy to replace. Here is a video this will walk you thru testing and replacing a pressure switch. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
Posted on May 20, 2011
  • 6277 Answers
SOURCE: my hotpoint wd 860 washing machine won't spin and
Indesit (Hotpoint, Ariston) 'F05' decodes as 'pump'blocked'.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
John C
Posted on Jul 29, 2011
  • 414 Answers
SOURCE: Hotpoint Ultima washing machine won't work
Communication Error, basically the module is not sending message to component to activate...see linkhttp://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Posted on Oct 07, 2011
The knob just spins round and doesn't catch. It received a bash and it now won't accept a wash cycle. Any thoughts?
It seems that the timer has failed and needs a replacement. If this seems to turn around without clicking and if there is no action when the program cycle is initiated, this seems a failure of the timer controller unit. This happens in cases when it is turned around in reverse order or violently.
Jan 14, 2013 | Zanussi Washing Machines
My hotpoint washing machine won't turn on and when turning knob to on position a strong odor of burning plastic comes out from under it
The burning plastic smell sounds like your belt is worn and the drive motor is heating up to the point where it is melting the plastic. You should make sure the power is off and check the belts, transmission, clutch, and drive motor.
Jul 04, 2012 | Hotpoint Washing Machines
My hotpoint wd 860 washing machine won't spin and
John C
Jul 29, 2011 | Hotpoint WMA13 Front Load Washer
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
How old is my Hotpoint model # WLW1500B not having a problem, just want to find the age of my washer to see if it is time to purchase a new one
I see elsewhere on the web that it is from 1988. Mine is still working, but it's time to update to a new energy saver. They don't make them that compact anymore, sad.
Jan 01, 2011 | GE WBSR3140DW Top Load Washer
Can you remove hotpoint bwm 12 washing machine filter
Hi, yes it is. Hotpoint bwm12 is a built-in washing machine, the filter is located at the bottom (black round knob). Undo the filter by turning it to the left (please be sure there's no water inside the machine, or getas much as possible out before opening the filter).
Cheers
Feb 19, 2009 | Washing Machines
Sep 21, 2007 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
78 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
