Question about Danby DWM5500W-1 Energy Star 1.69 Cu.Ft. Front Load Washer
Danby 5500 front load washer grinding noise when turning drum. metal piece found in lint trap. how to dissasemble to get to inside tub and inside tub supports/bushings
The drum turns with great difficulty. a bushing or support has failed on the inside drum. The motor and belt are fine. how do you disassemble to get to the inside tub? do you have to remove the entire tub and disassemble the entire machine above the tub? Thanks.
  • 12 Answers
SOURCE: horrible noise during fast spin
nail washer to floor or strong glue it to the floor
Posted on Dec 26, 2008
SOURCE: Danby front load washer Will not spin motor runs
If the "Spinning Off" button is pushed in you will get this problem.
It happened to my wife last week.
If the drum is turning the belt is OK
Posted on Feb 07, 2009
  • 574 Answers
SOURCE: danby twin washer/spinner
should have a belt idler or tensioner between the motor and the drum
Posted on Sep 13, 2009
Samyfam
  • 379 Answers
SOURCE: Danby front loader becomes very loud during spin cycle
Most likely this will be the drum bearings.
Bearings normally last quite a long time but some will fail sooner than others. Quite often bearing failure is due to a faulty drum shaft seal which allows a small amount of water through and in to the bearings. The bearings then start to rust, which then accelerates the wear on the bearings.
Replacing the bearings needs well above average DIY skills to do, so unless you feel confident to tackle the job, can get hold of a tech manual, and can get hold of new bearings, it's time to call an engineer.
Posted on Sep 30, 2009
localwonder
  • 6784 Answers
SOURCE: Danby DT4229 Top Load washer. the washing mecahism
HI. If the timer dial dose not advance, this will indicate that the timer motor has failed. Generally, this will require you to have this damaged timer mechanism replaced, asap. Unfortunately, these mechanisms are not designed to be repaired. The entire device must be replaced, if possible.
Posted on Jan 19, 2010
Washer stopped working with low humming noise
Belt may have broken or come off, or idler seized or main support bearing siezed or even motor bushings may have seized. Best access is from above to check.
If you can spin the drum with ease from the inside, the belt broke or is off. If it will not turn, the motor bushings may have siezed, or the main bearing siezed.
Apr 12, 2012 | Kenmore HE2 Plus Front Load Washer
Dryer heats, but won't tumble. Suggestions?
Either there is no tension on the belt or the motor is not running. If you don't hear the motor, the first thing to check is whether any air blows out the vent. If you have air moving, the motor is OK and you can check for a broken belt or a problem with the tensioner pulley mounted on the motor bracket. First, reach inside the dryer and try to turn the drum by hand. If it turns very easily, belt tension is definitely the problem. If you can't turn it at all and the dryer was previously making a lot of noise, the drum has crashed due to a bad bearing or bushing pad. A stuck drum can also ruin a belt.
On most dryers, you can remove the panel under the door to look at the motor and belt tensioner. Usually you have to take off the floor trim piece way down at the bottom, then remove the screws holding the panel. The top of the panel is commonly held in place with spring clips.
On some models you have to undo screws at the back near the top, then tilt the top up like the hood on a car (there are spring clips holding the front of the top; you may need to pry with a thin piece of hardwood or a screwdriver with tape wrapped around the shaft to protect the paint on the dryer). This gives you access to clips and screws holding the front onto the dryer. If you have a broken belt, you'll need to remove the front (door assembly) anyway to replace the belt or drum bearing. (Some models have a drum bushing on a center pin in the back of the dryer; you can get at these by removing a plate on the back).
If the tensioner pulley has a lot of slop in the bearing, fix this; otherwise the belt may wobble off it again. You'll be surprised by how much quieter the dryer gets.
If the motor is not running, check for a failed starter capacitor (located inside the control panel), a bad centrifugal switch (inside the motor), bad contacts in the timer (control panel), or an open thermal fuse in the motor.
CAUTION: unplug the dryer before doing any work inside.
Jun 06, 2011 | Dryers
HI MY AMANA DRYER HAS A HARD TIME STARTING AND AFTER A FEW MINS. STOPS
I am a little puzzled! Normally the difficulty is with startup rather than stopping after starting. Are you sure that the drum actually turns or maybe it just sounds like it is turning? If it never actually turns then it is probably the belt or the motor. You can make sure by placing only a few items in the dryer (try a couple towels or different colors) place the towels inside, (pay attention to where they are) begin the cycle, open the door to see if the towels have changed position. If the drum has been rotating then try adding a few more items to see if things change.
If the drum does not turn at all it maybe the drum belt. If, as you increase the load, the drum has difficulty starting then it is probably the motor or a control circuit. Hope this helps...Good Luck. Douglas
Jan 28, 2011 | Amana Dryers
Hotpoint dryer was moved, now only clicks, won't start
Rough handling may have the drum belt to get binded. Try turning the drum by hand to see if it turns free or is locked. This may align the belt to the motor or may just take off the belt altogether from the motor. You will have to get inside access to see whats up. Once inside realign the belt to the motor and pulley assembly. Then CHECK ALSO that no wire connections inside came apart during moving. Good luck
Jul 10, 2010 | Hotpoint NLL113EYWO Electric Dryer
Motor/Drum doesn't turn/spin & belt appears to be OK
With the belt off can you spin the motor freely by hand? If no then the bearings are froze and the motor has to be replaced. If yes and the motor will not start when power is applied then the motor needs to be replaced. If it starts without the belt on but not with, then the drum is bound somewhere and has to be freed.
Eric
Jun 11, 2010 | Kenmore Dryers
My drum will not turn on my dryer. how do i fix it?
the belt may be broken, it wraps around the drum and the motor. See if you can turn the drum by hand, it should turn with little difficulty. Start dryer and listen for motor, if you hear motor running the belt is broken.
Mar 10, 2010 | Estate TEDS740JQ Electric Dryer
Dryer belt squeaks
Maytags have two rollers that hold the back of the rotating drum in place. The bearings may be going out. with the door open, reach in and spin the drum by hand see if you can hear any indication that the drum rollers may be sticking, stuck, etc.
You can pull the front of the dryer off, then remove the front drum cover and carefully slide the drum forward (while leaving the drive belt in place) you can expose the rollers to see if they are worn or frozen..
You can also check the tensioner pulley on the motor to make sure that's not the culprit as well.
If a roller is bad, I recommend changing them both.. they're cheap and you're already inside the machine...why not?
Good luck...it's not that hard of a job..
Oct 17, 2009 | Dryers
Washer won't spin, motor sounds like its working, belt is fine...what do I check or do?
The belt may look fine, but if the motor is spinning, then the belt isn't transferring the motion to the drum.
First, make sure you can turn the drum by hand. Turn off the power. Reach inside the drum, grab the opposite sides and turn. If it moves more than a few inches, then it isn't the drum that's stuck. Possibly the belt tensioner has slackened and needs to be adjusted.
Jun 25, 2009 | GE WBSR3140DW Top Load Washer
Samsung dv4006 dryer belt
Possible replacement belt quality problem for the Samsung DV4006 / DV4006J / DV4015J / DV665JW and the Maytag MDE2400AZW dryers:
The original belt for the Samsung DV4006 / DV4006J / DV4015J / DV665JW dryers is a Megadyne 1975 H7. The part number is DC66-00121A, but when ordered, a Dongil 7PH1975 belt may be shipped instead of the original Megadyne. The Maytag MDE2400AZW dryer uses the same belt. The part number is 35001010, but when ordered, a Dongil 7PH1975 belt may be shipped. It seems that the Dongil belts are inadequate for these dryers. They delaminate and may fail prematurely. Even new, they cause a thumping sound each time the seam goes over the motor pulley. Other than Megadyne, another good belt is the Hutchinson 1975H7. The appliance part number is 1258288107.
Where to get an original Megadyne 1975 H7 belt:
eBay member 'appliance-parts' in Colorado, USA has emailed me that their Samsung DC66-00121A belts are Megadyne. Website: http://appliancefactory.com Email address: partsonline@appliancefactory.com
eBay member 'ladydi1975' in Ohio, USA has emailed me that their Maytag 35001010 belts are Megadyne. eBay store: Discount Appliance Parts.
Where to get a Hutchinson 1975H7 belt:
eBay member: 'zodiac300_0' in Brighton, United Kingdom. I have ordered a 1975H7 belt from them and received a Hutchinson.
Other possible causes for belt failure:
--Motor pulley designed too small. The belt may be flexed beyond it's minimum rated radius.
--Excessive heat in the dryer due to lint in the vent line or vent line too long. The Dongil belt may be less heat resistant than the Megadyne.
--Worn drum bushing DC66-00062A.
--Metal burrs on the steel motor pulley. Deburr by inserting a small screwdriver in each groove while the motor is turning without the belt.
--Belt on the wrong track. The motor pulley has nine grooves and the belt has seven ribs. The belt must be in the middle. It's easy to place it one groove forward or backward by error.
--Small scratches on the drum where the belt contacts it. The scratches may be like small knives and damage the belt. Sand with a fine sandpaper.
--Idler pulley damaged or bearing worn.
How to replace the belt:
--Remove top cover.
--Remove vent panel (in back).
--Unclip door switch from front panel.
--Disconnect wire harness from door switch.
--Unscrew panel left of control console (from behind the panel).
--Unclip panel left of control console (from behind the panel).
--Unscrew control console.
--Unclip plastic panel on bottom, front
--Remove screws behind door. Remove door.
--Unscrew large front panel, remove.
--Inspect vent line for lint buildup, drum bushing (back of dryer) for wear, motor pulley for burrs and debris, drum for scratches, and idler pulley/bearing for damage.
--Vacuum all lint.
--Install belt around drum, idler pulley, and motor pulley. The ribbed side of the belt contacts the drum. The flat side of the belt contacts the idler pulley. Press on idler pulley to stretch the spring, and line up the seven belt ribs in the center of the nine motor pulley grooves.
--Reassemble.
Nov 06, 2008 | Samsung 7.3 Cu. Ft. Electric Dryer
Clothes dryer ran ok an hour ago - not now
you may have a bushing problem on the drive motor due to dirt or flint. you can check that by removing the belt and try rotating the motor manually. see if it is easy to turn or not.check also the bushing if you can move the shaft sideways..if it has a slack then its a bushing problem. replace the drive motor.
Feb 03, 2008 | Dryers
Danby DWM5500W-1 Energy Star 1.69 Cu.Ft. Front Load Washer Logo
49 people viewed this question
Top Danby Washing Machines Experts
shaun taylor
Samyfam
Samyfam
Mike
Are you a Danby Washing Machine Expert? Answer questions, earn points and help others
