Question about Xerox Phaser 7300DN Laser Printer
Xerox phaser 7400 fuse cut error
Customer just put in a new black imaging unit now it give's this message.
  • 208 Answers
SOURCE: Black Imaging Unit
If the machine calls for a new unit, a new not used cartridge must be installed to clear the message
Posted on Dec 07, 2007
SOURCE: Phaser Imaging Unit install error
Worked like a charm! Thank you for the detailed information. The step by step instructions were right on target.
Posted on May 20, 2008
  • 110 Answers
SOURCE: Phazer 7400 Black Imaging Unit Error
https://www.office.xerox.com/partners/SBSF_Docs/SB710.pdf Hopefully this can help you.
Posted on Oct 29, 2009
  • 87 Answers
SOURCE: Technical Black Imaging Unit Replaced,Error message still shows
Check out the details about this issue on my web site :
http://michelsplace
Posted on Mar 03, 2011
StevenC82
  • 160 Answers
SOURCE: xerox phaser 7400 giving error
Did it specify a color you should replace? The machine has 4 image units (CMYK) each with a different part#. Replacing them is easy, no tools required. Open the top door, lift out the entire image unit, move the toner over to the new unit, and lower the image unit. Here are the part #'s for the 7400 for each color. Iteminc.com has these online.
C - 108R00647
M - 108R00648
Y - 108R00649
K - 108R00650
Good luck, hope this helps. Thanks for using FixYa!
Posted on Aug 11, 2011
I have tried using a new fuse to cause an imaging unit to reset on a Phaser 7400 but the fuse will not blow.
If the unit is remanufactured or if you know how, you will have to disassembly the imaging unit and replace the fuser that blowns or simply just solder it. http://www.uninetimaging.com/downloads/technical/xerox/english/Xerox_Phaser_7400_Reman_Eng.pdf
Graphic 27.
Mar 30, 2014 | Xerox Phaser 7400/DXF Laser Printer
Can I print to the edge with Phaser 7400
No this is phisically impossible, try a larger sheet of paper and cut it
Mar 17, 2013 | Xerox Phaser 7400DN Laser Printer
Xerox Phaser 7400 U28 error message
The Service manual says:
The Drum Phase Sensor for the named Imaging Unit indicates that the drum is out of position.
Initial Actions:
Reseat the indicated Imaging Unit.
Cycle the printer's power.
after these steps it gets a lot more detailed and you would need to be an experienced tech to understand everything and follow the steps within a timely manner, if reseating the cyan imaging unit doesn't fix the problem, then you will have to call for service.
Hope that helps
Christopher
May 20, 2012 | Xerox Phaser 7400/N Printer
Xerox Phaser Printer has an error message cyan imaging defected, the unit was replaced with a new one, still getting message
There is a list of different parts that can be causing this error.
The first one is if its not seated properly. You can take it out and put it back in to make sure it is seated. Having bought a new one means that this is the only simple solution to this problem.
Here are the different parts that may need to be replaced as per the service manual states:
the imaging unit sensor board
the CTG0 harness
the engine control board
imaging unit motor
the lift uplink
the motor driver board
the low voltage power supply
!! that't a lot of possibilities and there are a series of electrical and mechanical tests that must be performed. You will have to call for service. Unless its seated incorrectly.
Xerox phaser 7400 giving error - replace imaging unit- what solution now?
C - 108R00647
M - 108R00648
Y - 108R00649
K - 108R00650
Aug 05, 2011 | Xerox Phaser 6350/YDT Laser Printer
What is error code 941 on a Xerox Phaser 7400?
www.support.xerox.com -phaser 7400- support -fault code-941 says cyan or magenta toner failure, but the solution says to
1. remove & reinsert the cyan or magenta imaging units.
2. replace imaging units .
check out the site to see if helpful
Jul 01, 2010 | Xerox Phaser 7400DN Laser Printer
Xerox phaser 7400 replaced yellow toner, but still getting replace toner error. I've reseated it twice, reseated the imagining unit and tried turning it off.
You can try do a NVRAM reset. If after that you still have the error message then I would tell you to contact the Xerox team as you might have a wrong consumable (defected/wrong CRUM) information.
NVRAM reset: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=36,E=0000000002092637520,K=9394,Sxi=5,Case=obj(3085)
May 16, 2010 | Xerox Phaser 7400/N Printer
These units are automatically reset with a fuse. When you put the imaging unit in it will completes a connection which resets the count then simultaniously blows the fuse. Sometimes the fuse blows before the reset, which is what it sounds like happened here. The machine should print normally but the error will persist until the unit is replaced with a new one. Is the the imaging unit an OEM unit or remanufactured? Whoever you got the unit from should replace it as defective free of charge. If it is OEM you might have to go through Xerox to get it replaced. I don't know if the Big Box stores will.
Dec 04, 2008 | Xerox Phaser 7300DN Laser Printer
Black Imaging Unit
Mar 27, 2007 | Xerox Phaser 7400DN Laser Printer
Xerox Phaser 7300DN Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
