No power can't open door
Washing been fine, then today went to do a wash..... Door won't open and no power on machine it seems
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
What is the model number?
Posted on Nov 09, 2012
  • Michelle w Nov 09, 2012
    Miele novotronic w 827
  • 1382 Answers
SOURCE: Door will not open
Remove the top cover, and release the door catch from inside the washer, you will probably need a screwdriver or similar to do do this.You will need to replace the door catch and spring, and possibly the door lock, as it may break when you force the door open.
Thank you !!
Posted on Jul 01, 2010
Testimonial: "Thanks for advice top already off and washing freed"
Macmarkus
  • 2605 Answers
SOURCE: I've an Asko Front loader W600 bought in 2001.
Hi, welcome to FixYa.
I'll start by addressing the later part of your post first, and that is by saying I wouldn't run out and buy a new washer...not yet anyway.
You should be able to get the garments out of the washer by way of manually unlocking the door. The door can be opened manually, see below for instructions.
**Watch for lots of water if it hasn't drained though...see below for manually drain as well**
Usually if the door won't open it's due to the unit not draining sufficiently (this may explain the "shuddering" as well if pump has debris within it) or perhaps a fuse tripping, thus no power. Just to be thorough you should check the pump to insure the filter isn't clogged, in my opinion, or do you know where it is and how to check it ?
In the event the pump, filter or hose is clogged or obstructed, will prevent the door lock from releasing...potentially causing a fuse to trip.
This is by design, but it's easy to confirm or dismiss.
Check as follows...
Let me know if any of this isn't clear and I'll attempt to help you move forward by way of possibly emailing this info to you.
Once you've cleared the pump filter or ruled out it was indeed blocked or not, you can now pull the manual door lock release located in the same area.
i.e.
Once that has been done, I'd now check the fuses in both the washer as well as the dryer...if yours plugs into the dryer as most Asko do. To do so is as follows...
CHANGING THE FUSE
1. Remove the fuse holder insert with a screwdriver (1/4 turn).
2. Replace the fuse. (The fuse must be a 250V, 15amp slow-blow fuse.)
3. Fit the fuse holder insert with the fuse into the fuse holder.
Let me know how you make out. Thank you for choosing FixYa and good luck. Please take a moment to rate the info provided for you here today at FixYa.
Regards,
Macmarkus :)
Posted on May 31, 2011
Testimonial: "Thanks so much for your help. We'd been researching new Askos ... so you saved us a lot of money, even if it's just short term. We owe you a beer! B"
bunnydawg
  • 5158 Answers
SOURCE: My door won't open on
unplug the machine for about ten minutes and then try to open the door after you plug it in. If the plug is not easily accessable, locate the fuse in the fuse panel for it. i may add after you have interupted power to the machine, you may want to try opening the door then.
Posted on Jun 12, 2011
  • 6277 Answers
SOURCE: Our Haus hw50-1010w washing machine
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jul 03, 2011
  • 6277 Answers
SOURCE: Hi my beko 5100 washing machine is stuck wit
John C
Posted on Jul 07, 2011
HNL 6146 door won't open
Has it emptied all water out ??
Jun 18, 2013 | Hoover Washing Machines
GLTF1240ASO Front Door Won't Lock/Close
Most probably your door lock is damaged. You are not supposed to force it open, you have to wait for at least 2 minutes (or till the lock sign is off) after the wash is over to open the door, never force it.
You can just google your model number and search for parts to obtain it. It is quite possible you can change it yourself. See that the line is disconnected from the mains.
Jun 04, 2013 | Washing Machines
W6444 washing machine door won't close
Try some WD40 spray on the door and lock. Just a bit. Try closing and opening the door. The machine should be in the <off> position.
Mar 16, 2013 | Asko W6021 Front Load Washer
LG WD1470FD won't open
You will need to replace the door lock assembly. If remove the top, you can reach down and manually open the door. Below is a video to show you how to replace the lock. Here is the lock to order.
Dec 04, 2012 | Washing Machines
My servis m6011 5kg washing machine door won't
Possible that the door lock has jammed and so is not working.please check this link: door lock
Jul 03, 2012 | Washing Machines
Door will not open after cycle finishes
I had similar problem, but never found the cause, ended up spinning washing again and again until I could open door. Control system replacements are expensive , almost as much as a new machine.
Mar 11, 2017 | Zanussi ZWF14070 Front Load Washer
Maytag maxima door locked
Similar problem here - pump was set for a 58 minute normal cycle, I look in and see it is now showing 67. Hmm. Attempt to shut it off because it is just sitting there pumping and pumping. Power shuts off but pump keeps running and add garment light flashing red. Cannot open door (to add garment or not) Unplug the unit and the door will not open. Anybody got a clue what's up? I have a wash in, service is closed due to a storm today. Just bugs me that it is 6 months old and seems to act up a fair bit electronically.
Dec 09, 2011 | Maytag Washing Machines
My magtag 5000 series washer is flashing error code F21, It was in the middle of a wash cycle and now the door is locked and it won't open. How do I at least get the door open. I have unplugged the
Unplug the washer. Then plug it back in and press the button that turns it off. This should unlock the door. Same thing happened on mine and there was a kink in the drain hose. Once I unkinked the hose, unplugged it, plugged it back in, turned it off, then I was able to run a drain & spin cycle to get the water out of the load that was in the washer. I then ran a full wash cycle (they'd gotten stuck in the first drain & spin cycle of a wash) and everything seems to be fine now.
Dec 04, 2011 | Maytag Washing Machines
My mother accidentally pulled the door open on the washing machine when it was still locked. Now it won't do anything. It would not even finish the cycle. We were able to get the clothes out and...
Due pulling of the door forcibly the door interlock switch has damaged. So the door cannot lock properly &r the door lock switch is not functioning. Replace the door interlock switch.
Aug 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a Samsung DC68-02683A washing machine. It was working perfectly fine earlier and now will not turn on - there is no power. I unplugged it and left it off for upwards of an hour. It will not power on...
Hi
Check the power supply/fuse in the first place. If the supply is right then the problem is of the door. Try to push the door a bit hard and try to open the door. When the machine is switched off the door has to open, find out if it is not stuck. Finally if things dont go your way call a mechanic.
Regards.
PLZ. dont forget to rate my suggestion.
Jul 27, 2011 | Samsung Washing Machines
Washing Machines Logo
16 people viewed this question
Top Washing Machines Experts
