Question about KitchenAid Kitchen Ranges
KIthcen aid Model KDRP463 Burners not igniting
All four burners will not ignite. They are clicking but do not ignite. Will finally ignite after about a minute of turning on and off. Oven is working as is top grill
james klgr
  • 362 Answers
SOURCE: Kenmore Gas Range - burners won't ignite
its possible your gas regulator is bad or the gas line to the ignitor is stopped up look at the line and see if some type of food has blocked the outlet
Posted on Dec 08, 2007
bestdarngood
  • 3037 Answers
SOURCE: oven won't light
Well, the igniter needs to be replaced. They go bad after a lot of use, if you replace it and it's still not sparking, let me know but 99% of the time replacing the igniter will fix the problem.
If you have any further questions, just ask, I would be glad to help
Posted on Jun 03, 2008
rickzilla
  • 706 Answers
SOURCE: ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Posted on Sep 01, 2008
SOURCE: Tappan oven not gas flow or ignition
Right rear burner will not ignite without assistance (a match or lighter). What is the problem?
Posted on Feb 13, 2009
SOURCE: Amana gas oven not working
SOUNDS LIKE U HAVE A WEAK BAKE IGNITIOR REPLACE THE BAKE IGNITIOR IT WILL SOLVE THIS ISSUE
Posted on Aug 31, 2009
On a 4 burner Gas cooktop - all 4 burners get gas but why does the igniter only work with the front 2?
Usually that's caused by clogged holes in the burners. I clean it out using a toothpick.
May 02, 2015 | Jenn-Air Cooktops
Spark igniter problem
The igniters probably should be replaced. You can order new ones for about 15 - 20 dollars each. They are easy to replace and sears parts direct will show you a printable schematic.
Jan 02, 2014 | Kitchen Ranges
JGBS20BEW2AD, the stove top four cooking burner constantly clicks.
The igniter switch(s) has most likely failed shorted. Fairly common with gas ranges with spark ignition.
Mar 06, 2012 | Kitchen Ranges
When one burner knob is turned to ignite all four burners turn on.
What do you mean by "all four burners turn on"
Some electronic ignite systems turn on on all the burners, But just the SPARK not the gas part of the burner.
Is this what you are describing?.
Jan 11, 2011 | Jenn-Air JGD8130 Gas Cooktop
My DCS range burners with electric start.
Very likely the spark module. All four are supposed to click when one is turned on, however they are supposed to stop when the burner ignites. Replace the module and test. Good Luck, Appliance Specialists
Jan 03, 2010 | DCS 36-6-1 Gas Kitchen Range
Igniter on Wolf Stove clicks continuosly
Depends what Wolf model you have, if you have model AS48KI and the flame looks really high, (it supposed look like a flower), most cases the top burners are misaligned, you can try to re align the burners by turning them around. afterward if the burners are still clicking it may be ignition problem. Have fun.
Aug 14, 2009 | Wolfgang Puck BTOBR0040 Toaster Oven with...
Igniters do not spark on one side of cooktop
Is the gas able to flow freely through and out of the bad burners? Sounds like they may be clogged somehow
Jul 11, 2008 | Jenn-Air JDS8850AAS Dual Fuel (Electric...
Stove-top burners
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
bvn
Jul 10, 2008 | Belling 27 in. CTC465 Electric Cooktop
I have a kitchen aid model kgcg260sob3 front burners wont light without a match
it could be the electrodes or the burner itself. get a technician to check it.
Dec 16, 2007 | KitchenAid KGST307 Gas Kitchen Range
Spark igniters on the burners fire continuously
Had The same problem. I removed the top of the control panel to find out that one of the ignitor switches had turned when I replaced the four large plasic nuts on the control panel. Make sure the switches (block) are aligned, and kept aligned, when re-installing the top of the control panel. Startwreck.
Jul 15, 2007 | KitchenAid KGST307 Gas Kitchen Range
Open Questions:
Kitchen Ranges Logo
20 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
