1995 Pontiac Grand Prix Logo
Posted on Sep 11, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 2003 gr. prix GTP.. my fuel gauge started acting weird(works/does'nt work) then dash lights started doing the same and now headlights have stopped working.daytime lights work but if i tu
Bill George
Level 3:
  • Pontiac Master 2,517 Answers
  • Posted on Sep 11, 2017
Bill George
Pontiac Master
Level 3:
Answers
2517
Questions
Helped
544097
Points
7493
Have your battery tested or first clean the terminals and cables. Check the ground cables, not just the one on the battery but frm engine to body etc etc.
5 Related Answers
Anonymous
  • 491 Answers
  • Posted on Oct 11, 2008
SOURCE: replace headlight bulb
inside the engine compartment directly behind the headlight it unscrews and pops out. then put it back in and retighten.
Anonymous
  • Posted on Nov 24, 2008
SOURCE: 2002grand am daytime running lights
99 - 04 grand am.
I had the "service vehicle soon" light come twice with in 1 year. First the heald light bulbs were gone. Replaced the head light bulbs and after 2 starts the "service vehicle soon" light was gone.
The second time the DRL - #194 amber bulbs were gone. Replaced these and the "service vehicle soon" light was gone after 2 starts. The DRLs are housed in the headlamp housing, the tiny bulbs beside the head light.
hangfire0425
  • 58 Answers
  • Posted on Jul 15, 2009
SOURCE: 2002 Pontiac Grand Prix GTP / Multi-function Switch
i have the sameproblem. Dealer part was quoted to me at $510.00. All after market parts stores were $350- 450. Try moving the emerg. flasher button while you step on the brakes and someone else watches the lights. I jammed paper beside the button and they work until I can fix it.I had to order the multi-function switch. and you have to pull the air bags to replace it.
Anonymous
  • 20 Answers
  • Posted on Apr 03, 2010
SOURCE: My daytime running lights are not working
no he is def wrong it means one of your bright lights are out
JOSHUAJBARTH
  • 57 Answers
  • Posted on Jul 11, 2010
SOURCE: 2004 Pontiac Grand Prix GTP front pass turn signal doesn't work
you would need to buy a blinker relay
3answers
I have a 2003 chev silverado. The fuel gauge quit working then started working again on an off. Then my radio would go out and the fuel gauge would start working. Now my AC is not working. It's like...
It may seem like the problems are related, but they most likely are not at all, unless it's an actual battery power issue. Your fuel gauge consists of 2 parts and wires to connect them, the sending unit, which is in the gas tank connected to your fuel pump on your truck I believe, and the gauge itself inside your dash. It is most likely your sending unit/fuel pump which sucks cause that's like $350, altho easy enough to replace yourself with very little gas in the tank. As for the radio check fuses, and AC I have no idea...
Fuel gauge indicator not working
You might have bent the gauge pin when changing the pump there is a lever that is easly bent you might need to take it back out of ther tank and fix..
This really an emergency I don't have money to fix my car right now. My car on the way to work started acting unusual. The dash lights stayed on while my gauges gave no readings and my radio completely...
The first thing you can do it to CHECK THE TERMINALS OF THE BATTERY< CHECK THE GROUDN CONNECTIONS TO THE CHASSIS.
If this seems corroded then clean and reset the terminals.
Secondly check the ECU, if the car seems to experience problems in the engine you must check the errror codes.
Finally the fuse box, relay box and the dash cluster must be checked for loose connection.
3helpful
2answers
HELP!! Having electrical issues with my 2005 Pontiac
electical is hard to diagnose with out being there. i would treat each problem seperately. first you will need to test the engine temp gauge sending unit. in a dealership this is easy with a scanner they can run a sweep test to se if the gauges are responding.you don't want the engine to over heat if the gauge is not working. next problem the dome light should be easy to fixe does the dome light work with the dome switch?remove the bulb and with the doors open and switch on check for voltage, if voltage check connection and or replace bulb. if no voltage check fuses for voltage.last will need to have the dtc po243 checked out by a repair shop. i hope this will help.
How do you replace a headlight switch in a grand prix
how do you replace a headlight switch in a 07 grand prix gtp. head lights do not come on. all other lights work. fuses are good. amd so are the bulbs. was told that the headlights themselves were not getting a charge. and was told that it was the headlight switch.
Fuel gauge erratic
Yes the tank has to come out. It really doesn't require any special tools. You should have everything you need at the ag dealer. Try to get as much fuel out of the tank before you start so it is easier to work with.
2answers
Lights flashing, seatbelt alarm sounding, outside temp. guage not working...
The body control module is the cause of your weird problems. Replace it.
Top Pontiac Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
