Question about Acer TravelMate 2300 Notebook
Fujitsu simens bios password removal? - Acer TravelMate 2300 Notebook
  • 520 Answers
Get your self a free version download of a program called spotmau.
once downloaded extract the files and write them to a boot disk(all the instructions are part of the package)
you can then use the created disk to remove all passwords.
anymore details dont hesitate to ask but first download spotmau extract and read the txt files it tells you exactly how to create the disk and how to use .of course you need the full software to use all of the programs ability but for what you need the free version has..
Posted on Jan 06, 2009
Fijustu ah530 corei 5 bios password
BIOS on a Fujitsu C-Series LifeBook b> Resetting the BIOS system of a computer can help revitalize the computer's usage. Oftentimes computers are "broken" when they are misconfigured in the BIOS menu of the computer before it boots up. When the settings are improperly selected, the BIOS prevents the computer from working properly. To get the computer back up and running again, the BIOS needs to be reset. The Fujitsu LifeBook C2111 has its BIOS system located on the motherboard beneath the keyboard.
Turn the Fujitsu laptop over with the computer powered off. Remove the AC adapter and push the battery release latch in and pull the laptop battery out of the Fujitsu. Remove the screw holding the hard drive in place and slide the cover off of the laptop. Remove the two screws underneath the cover that holds the hard drive onto its bracket. Slide the hard drive out of the laptop. Turn the computer back over and lay the screen down so that it is parallel to the surface on which the laptop is resting. Remove the small screw above and to the left of the keyboard with the Phillips screwdriver. Push the keyboard toward the screen until it disengages. Fold the keyboard over the screen and rest it there with the keys facing the screen. You will now see the motherboard of the Fujitsu C2111. Locate the small, round lithium-ion battery on the motherboard and remove it. This is the BIOS battery that stores all of the settings and password of the BIOS when the computer loses power. Hold the power button in on the computer to drain the BIOS system and leave the battery out of the laptop for at least 30 minutes. Place the BIOS battery back into the motherboard and reattach the keyboard. Tighten the keyboard screw that you removed earlier, and turn the Fujitsu back over and reattach the hard drive along with the covers for the hard drive and RAM. Push the computer battery back into place and attach the power cable to the computer. Turn the Fujitsu back on and the BIOS menu will be reset.
or b> Start the computer and press the "F2" key while the system boots, if the computer is currently off. If already on, restart the computer and press the "F2" key while the system boots. The BIOS setup utility will appear. Press the right arrow on the keyboard and scroll over to the "Exit" tab. Press "Enter." A drop-down menu will appear. Scroll down to "Default Settings" using the down arrow key and press "Enter." A dialog box will appear, asking if you are sure you want to load the default settings. Scroll over and select "OK" using the arrow keys and press "Enter." All BIOS settings will reset to the default value. Scroll back to the "Exit" tab using the arrow keys and press "Enter." Scroll down and select "Save Changes and Power Off." Press "Enter." The computer will save the default BIOS settings and power down. Fujitsu Lifebook T Series b> Restart your Fujitsu Lifebook T Series computer. Press "F2" as soon as the computer starts booting. Enter your current BIOS password if prompted. Use your right arrow key to select the "Security" menu. Use your down arrow key to select the password you want to reset. Press "Enter" to select the password. Enter the current password when prompted. Enter your new password or a blank password if you want to clear the password. A blank password resets the BIOS password completely, meaning you do not have to enter a password to enter the BIOS or boot your computer. Press "Enter" to save your password settings.
Repeat the process if you have multiple passwords set. Press "F10" to save all settings and exit the BIOS.
Jan 30, 2013 | Fujitsu LifeBook AH530 NoteBook
Password Bios
you can restart it, and use F2..and reset bios password in that screen
Mar 23, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Fujitsu siemens s7110 laptop bios password
if youve forgotten the bios password you will need to remove the main battery, the power cord and disconnect the cmos battery to clear the bios password
its better to have a tech do this for you
Dec 07, 2011 | Fujitsu Siemens LifeBook S7110 Notebook
I forgit bios password for fujitsu s7110 how can i remove password
You need the bios master password for your Notebook which you can get at http://www.unlockbiosrecovery.com/Unlock_Fujitsu_Bios.php for $20 and they guarantee it to remove the current bios password. I use them often in my work repairing laptops.
Jun 29, 2011 | Fujitsu Siemens LifeBook S7110 Notebook
I am trying to recover a Tseries t4210 fujitsu lifebook, but unfortunatly it has a bios password set and the previous owner has now left the company. Can you help in removeing the bios password...
To reset the BIOS password read the information from this link.
Before you open it up I would suggest trying Hiren's Boot CD and Kill CMOS to wipe the BIOS.
Feb 10, 2011 | Fujitsu LifeBook T4210 Tablet PC
How can I remove S7211 BIOS password
Find the original sales-receipt, to prove that you, and not a thief, is in possession of your laptop. Telephone Fujitsu, and ask for Technical Support -- once they verify that you are the owner, they can remove the BIOS-password.
Jul 17, 2010 | Fujitsu LifeBook S7211 Notebook
Fujitsu amilo simens Pi1536 and Pi1556 bios password chip locatio
Hi ,
Replacing the existing BIOS chip with a new one you can buy from your specialized electronic shop or your computer supplier. It's a quick operation if the chip is inserted on a base and not soldered to the motherboard, otherwise you'll have to unsolder it and then put the new one. In this case would be more convenient to solder a base on which you'll then plug the new chip, in the eventuality that you'll have to change it again. If you can't find the BIOS chip specifically made for your motherboard, you should buy one of the same type (probably one of the ones shown above) and look in your motherboard manufacturer's website to see if there's the BIOS image to download. Then you should copy that image on the chip you bought with an EPROM programmer.
Important
Whether is the method you use, when you flash the BIOS not only the password, but also all the other configuration data will be reset to the factory defaults, so when you are booting for the first time after a BIOS flash, you should enter the CMOS configuration menu (as explained before) and fix up some things.
Also, when you boot Windows, it may happen that it finds some new device, because of the new configuration of the BIOS, in this case you'll probably need the Windows installation CD because Windows may ask you for some external files. If Windows doesn't see the CD-ROM try to eject and re-insert the CD-ROM again. If Windows can't find the CD-ROM drive and you set it properly from the BIOS config, just reboot with the reset key, and in the next run Windows should find it. However most files needed by the system while installing new hardware could also be found in C:WINDOWS, C:WINDOWSSYSTEM, or C:WINDOWSINF .
ERNZ
Jan 16, 2010 | Fujitsu AMILO PC Laptops
Sir how can get my fujitsu simens desktop
Need a bit more information or you can try this link but you will need to know your information.
Hope this helps.
http://support.ts.fujitsu.com/com/support/downloads.html
Oct 20, 2009 | Computers & Internet
Forgot Bios setup password
Go to your friend. Download and burn this cd http://www.9down.com/Hiren-s-BootCD-9-8-Keyboard-Patch-73110/
Boot your pc from it and use BIOS / CMOS Tools from it.
Aug 15, 2008 | Fujitsu 18C1 Air Conditioner
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
