I have sharp register and when I plug out all the memory deleted
    Master:
  • 545 Answers
There is probably a CMOS battery somewhere in the register. It is probably dead. Replacing it should hold any settings between uses.
Posted on Nov 10, 2012
Return Sharp XE-A102 cash register to factory settings
MASTER RESET
Master reset: Clears all the memory and initializes each preset parameter. The master reset should be performed by using the following procedure.
1. Turn off the power (Power OFF). (See Note 1.)
2. Remove the memory back up battery from ECR.
3. Turn the mode switch to any position other than Power OFF.
4. Turn on the power (Power ON). (See Note 2.) When the master rest is completed, the buzzer sounds three times.
5. Install the memory back up batteries back into the ECR. The master reset can also be accomplished in the following case. (See Note 3.)
Note 1) Power OFF: Means disconnecting the AC power supply to the machine. (Specifically, unplugging the machine.)
Note 2) Power ON: Means connecting the AC power to the machine. (Specifically, plugging in the machine.)
Note 3) In case a power failure occurs when the machine has no battery installed, the master reset operation is automatically performed after the power has been restored.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 05, 2016 | Sharp XE-A102 Cash Register
How repar this problem u2 - 23 sharp arm - 451 u
SRAM memory individual data check
sum error (ICU)
Check sum error for every data in the
SRAM memory of the MFPC section
(Communication management table,
sender registration data, etcSRAM trouble
Control circuit runaway due to noises
ICU PWB SRAM access circuit trouble
.)Automatically initialize the data related
to the check sum error by turning OFF/
ON the power.
Since the registered data are deleted,
register the data again.
Use SIM16 to cancel U2 trouble.
Replace the ICU PWB.
Mar 12, 2015 | Sharp Office Equipment & Supplies
Delete memory
Turn your key to half past position and press JF button and have someone to plug in the machine for you while still pressing jf
Mar 19, 2014 | Sharp XE-A402 Electronic Cash Register
How do I reset the GT1 through GT3 on a Sharp XE-A23S electronic cash register
In some countries it is illegal to do that. However the easiest way is to take out the batteries while main is off
Mar 22, 2013 | Sharp XE-A23S Cash Register
My sharp ER_3100 wont operate it shows 00000000
The ER-3100 has a memory-protection battery soldered to the main board. It charges whenever the register is on, and when the register is off, it can hold the totals and programming for over a month.
But the ER-3100 is about 20 years old, and you battery has lost its ability to hold a charge. You need to have the battery replaced and the entire machine's memory cleared, then programmed. Don't do it. You need a new cash register. All the replacement machines are much cheaper, much faster, and much quieter than your old ER-3100.
Nov 25, 2011 | Sharp XE-A402 Electronic Cash Register
I having a problem with my sharp up 700 cash register i purchased second hand and trying to program and it has got stuck in one of the menus and just states lacking memory
hi,im not an expert on tills,but inside you will find a re-chargeable battery pack,hidden under a cover.try disconnecting it for a few minutes and then re connect.it serves to hold its memory when un plugged,and this should reset the till to factory.i did this to a sharp till with similar issues around six months ago and it worked afterwards.cannot remember the model,but it was from the late 80s-early 90s
good luck!
steve
Jul 31, 2011 | Sharp Televison & Video
I have sharp er-a420 it was in my garage for two years. I like to reprogram my register. I think I need to reset my register, I do not know how. Manager?s key does not do anything. When I plug it in on the...
Most Sharp register, including the ER-A420, have a rechargeable battery mounted inside to hold all memory when the power goes out. It should last a few months, but two years is a bit much. This might get it going:
  1. Unplug from AC POWER.
  2. Turn the key to PGM.
  3. Hold down both paper feed keys (at top-left of keyboard).
  4. While holding those two buttons down, plug the power back in.
  5. Turn the key back to REG.
  6. Enter 1 CASH # to sign on as Cashier 1.
  7. Try a sale.
There is a strong chance this won't do the job, because the memory has been randomized by total loss of power when the battery died. Worse yet, the battery may be too far gone to ever take a solid charge again. If so, you probably need the help of a Sharp register dealer to replace the battery, totally clear all memory and reprogram it. It's probably worth the money; the -420 is an excellent little register.
Dec 10, 2009 | Sharp XE-A402 Electronic Cash Register
Clearing memory 0n sharp XE-A203
save your program data if you wish keep it on a sd card
remove the batteries and unplug. wait 5 minutes,, put key in, turn to reg and plug in.
you should get 3 beeps... all is set to default now and ready for programing
Jul 04, 2009 | Sharp XE-A404 PC Desktop
Plugged in barcode scanner. it blinks continously. won't scan
You might try turning the register off, confirming the scanner is pluged in and the screws tight then turning the register back on. You might also chek that none of the pins on the scanner plug have been bend.
May 24, 2009 | Sharp Office Equipment & Supplies
UX-B800SE Fax
I had the same "Full Memory" problem & called Sharp. You need to unplug the fax, then hold (press down) on both the "Start/Memory" & the "Stop" buttons at the same time. While holding them down, plug the fax back in. After it's plugged in, you may need to press the start button again. That should clear it.
Aug 02, 2008 | Sharp UX-B800H Fax
Computers & Internet Logo
11 people viewed this question
David Payne
David Payne
