Question about Tasco Optics
How to remove turret caps
Tasco 3-9x40 scope
fps353535
  • 99 Answers
SOURCE: RIFLE SCOPE WARRANTY
Here is the contact info for them. ask them :)
Please rate this as fixya :)
Posted on Apr 11, 2009
longbow243
  • 103 Answers
SOURCE: Tasco Rifle scope repairs
Try calling Customer Service at 1-800-423-3537. They should be able to assist you with your needs.
Posted on Sep 02, 2009
SOURCE: Tasco scope issues with elevation adjustments
Take the lens caps ff.Then run a new Leupold under it..
Posted on Oct 16, 2009
  • 2418 Answers
SOURCE: How do you sight it true for the rifles prior to
You can get a base line by bore sighting the scope. Bore sight kits are a bit pricy, might be best to take it to a gun range an start at 15 yards shoot a few move out to 25 the 50 then 100. Yes your scope should be sighted for one gun one round, with a cold barrel. Let it cool between shots.
Posted on Oct 18, 2009
miket756
  • 2702 Answers
SOURCE: I have a 25 year old Redfield 6X18 scope, with an
bullet drop compensation,,,,compleat hog wash!
no such thing in a scope, only a realy pricy one like £1500.00p worth and there not that good! but there coming soon! driven by a lazer for range finding,,,
still your scope has clouded up becouse its leaking
water has got into it, it could be repaired but its not cheap to do, it needs a complet strip down all the class cleand and new seals then a re-gas and it should be as good as new for another 25 years or so,
any good scope with mill dot will work for you, you just need to relurn the bullet drop over again,,and with the years of shooting you have had that should come easy as falling over,,,why not just get a good prised 3/9x40 mill dot and try that out insted, you will be plesently pleased with todays mid priced range scopes treet your self, and save money at the same time
Posted on Nov 20, 2009
Testimonial: "Both Leupold & Nikon DO have bullet drop compensation reticles, which are similar in principal to the mil-dot. The BDC scopes are becoming very popul"
Tasco scope warranty
Call Tasco.
May 29, 2013 | Optics
I have a tasco 3x9x50 world class rifle scope. The scope caps are stuck to the adjustment screws in top and side of scope. I am unable to unscrew the caps without unscrewing the adjustments as well. The...
Try some PB Blaster. Wet a q tip and apply to the area at the base of the turret caps. Wait a few minutes and reapply. Then using a small pair of vice grips attempt to twist the turret covers off. A cotton cloth will help keep the gripping surfaces of the pliers from scratching too bad. Hope this helps.
Jan 20, 2011 | Tasco 3-9x40 World Class Riflescope 30/30...
I have tasco #62TR rifle scope. I has stadia crosshairs and an adjustable top turret with various ranges for elk, deer, and antelope. However I cannot find any paperwork describing these features, and I...
Sight in rifle and put the on top turret with zero facing back.do not let knob"click".Aim at animal and adjust power(3-9etc)until body is bracketed by both crosshairs.Look in little window in eyepiece for type of animal.Click top turret to proper yardage(200,300etc).This allows for bullet drop.I've had one on a .270 for 30 yrs and never used this feature.
Dec 05, 2010 | Tasco 3-9x Variable Riflescope
Elevation turret stripped out. Entire turrent turns with no adjustment . Turret came off when reinstalling cover. Was not forcing cover tight and had just started to tighten.
ok,,,you have strong fingers then????
try a drop of supper glue on the striped out turret thred,,,as the scope is a right off anyhow you have nothing to loose do you?
Sep 05, 2010 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
On the adjustment turrets, after loosening the set screws, how do you get it to go down so the yardage lines up?
after you sight the rifle in at say 100 yd. lift the turret and line up the 100 yard mark on the turret to the mark, then push the turret down onto the scope and set the screw. some times the turret takes a lot of pressure to push back on.
Mar 29, 2010 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
I tried to remove adjustment caps from my scope to zero and the entire adjustment assemblies unscrewed.i can not remove cap.
this is what happens when there done up to tight,
get a soft jaw vice and put the thred of the turret into the SOFT JAW VICE!!! (lined with leather),,,,
very gently grip the threds and undo the cap,,,
when refitting the bottom bit to the scope put a small blob of grees on the bearing part,,,oh,,by the way!!,,,
it should be regased! or it could fog up on you when it gets cold,,, only just nip up the turret caps next time
Nov 16, 2009 | Tasco 3-9x40 World Class Riflescope 30/30...
How do you sight it true for the rifles prior to using the windage and elevation turrets. All other scopes I,ve seen with range compensators have the ability to be sighted in. I can't figure out how to...
Oct 14, 2009 | Tasco 3-9x32 .22 Riflescope W/ Rings,...
Jan 16, 2009 | Zeiss CONQUEST 3-9X40 MATTE Z PLEX
Sep 22, 2008 | Zeiss CONQUEST 3-9X40 MATTE Z PLEX
Optics Logo
Top Tasco Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Tasco Optic Expert? Answer questions, earn points and help others
