Question about Lenovo G555 Laptop
Intermitent not powering up - Lenovo G555 Laptop
  • 1 more comment
  • max carson
    max carson Nov 08, 2012
    A bit vague.Can you be more specific.To give an informed solution I need more information
  • Georgie Cruz
    Georgie Cruz Nov 09, 2012
    the note book g555 do not power up reseated hard disk memory and start once but then fails again in the morning and now wont power up is there a master reset for the motherboard or
  • Georgie Cruz
    a procedure to wake up from sleep or hbernate when power up ????
  • Lenovo Master
  • 7,627 Answers
Unplug from AC, remove battery, plug into AC, start normally. Is the power /charger cord damaged? The AC jack in the laptop been pulled, yanked, tugged, ..etc. Can you get another known good cord to isolate the problem?
Posted on Nov 10, 2012
Intermitant drive power on my ctm hs 740 mobility scooter
The problem is going to be your motor. After extensive usage, the motor will give up internally and some times it will burn and melt the possitive/negative cables at its housing and it will give you issues with the batteries and the module.
Luis CTM: 909-590-1388
Oct 29, 2011 | Ctm HS-2800 Power Wheelchair
1993 Grand marquis radio sound system amplifier trunk mount intermitent reception - radio powered up -volume. tuning. working fine but intermitent soiund received from source to speakers.
you sound like you have a loose wire if your using the stock head unit you must of had to conn.alot of wire go back through follow from the head unit.If I were you get a audio control x-over.it will kick up the pre amp power.
Dec 18, 2010 | JBL Car Audio & Video
My truck will not turn over! It intermitantly
THIS IS MOST LIKLY DUE TO A FAULTY ELEC. CONNECTION TO THE STARTERS POWER
Nov 29, 2009 | 2008 Dodge Ram Pickup 2500
Power window intermitent operation
sounds like you have a bad connection at the switch!!!!!
Apr 29, 2009 | 2001 Lincoln Town Car
Power steering fails
I had the same problem, there is a cooling fan for the power steering pump that went out and caused some damage to the pump. The intermitent problem finally got worse and I had the pump replaced read: expensive about $1000. See if they have a rebuilt pump available.
Apr 14, 2009 | 2003 Mini Cooper
Power steering goes out intermittingly. Switch
I would start by doing a power steering fluid flush.
Mar 05, 2009 | 2006 Saturn ION
1999 Honda Passport 4x4 auto intermitent high pitch winding noise
try checking the tension on all the belts(fan/water pump, power steering, alternator). If loose, they'll whine.
Feb 26, 2009 | 1999 Honda Passport
Piaggio Vespa 50cc - Intermitantly losing power
i think the compression is low.......better check the status of the piston rings
Jan 27, 2009 | Peg Perego Vespa Scooter
Intermitant powering up
Yes, it is most likely the cradle. My unit did the same thing. Picked up a new cradle and it works.
Apr 07, 2008 | Magellan RoadMate 700 GPS Receiver
Lenovo G555 Laptop Logo
43 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
