Washing machine stuck both lights on will not was drain
Electric went off in a middle of a cycle now washing machine will do nothing the lock lights are both on and there is water in the drum tried turning machine on and off to reset it did not do anything turned of by mains still nothing played with buttons nothing can not drain the water will not wash will not spin just seems stuck
    Problem Solver:
  • 8 Answers
Have you tried unplugging the machine from the power totally for 5 minutes or so and then re-plugging in to reset its computer and clear old info?
Posted on Nov 08, 2012
  • leanne barnard Nov 08, 2012
    i have unplugged it and plugged it back in and nothing i will unplug it again and leave for a bit longer i will let you know thanks
  • kathy tallen
    kathy tallen Nov 08, 2012
    The only other thing I can think of is maybe the drain hose is kinked as you said it wouldn't drain , check that and straighten if it is so the water can go out.
docjohn174
  • 943 Answers
SOURCE: frigidaire affinity front loading washer won't drain
HI .THANKS FOR YOUR QUESTION. THE PROBLEM IS WITH THE WATER PUMP.REMOVE 2 SCREWS AT BOTTOM OF FRONT PANEL . PUMP ON RIGHT .REMOVE HOSES AND CLEAN OUT THANKS THE APPLIANCE DOC.
Posted on Oct 04, 2008
barkencoa
  • 3463 Answers
SOURCE: Hotpoint WT540 1400 spin Washing Machine stuck on cycle
Could be a sticking water level switch, which controls the water level, or a blockage in the hose to the switch, or a trapped or split hose to the switch. the hose in question is about 6mm in diam,and goes from the sump hose to the pressure switch,if u remove the hose from the preesure switch chamber, check for a blockage there, and blow down the hose to see if it is clear, u should hear the switch click if it is clear, if no click and hose is clear, then I wud say the switch is faulty.
Plz rate my comments.
Thanks
Posted on Jan 01, 2009
  • 686 Answers
SOURCE: Washing Machine is not draining in rinse cycle to go to spin cycl
you both seem to have bad lid switches. A bad lid switch will prevent draining and spinning.
Posted on Apr 04, 2009
barkencoa
  • 3463 Answers
SOURCE: washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Posted on Jan 19, 2010
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Posted on Mar 21, 2010
A GE stackable washer/dryer that is stuck on spin?
Good Day,
your machine is normal is washing cycle?
if yes.do the same
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.
Nov 02, 2013 | Washing Machines
Why wont my amana washer start at all?
My washer will notwork it will not let the lid lock are fill with water
Jan 20, 2013 | Amana NTW4501XQ Top Load Washer
Beko aa class 1200 rpm washing machine will not drain **** on cycle
Possible that the program controller is not outputting to the drain .Check this link to repair the drain pump
Jun 28, 2012 | Washing Machines
My magtag 5000 series washer is flashing error code F21, It was in the middle of a wash cycle and now the door is locked and it won't open. How do I at least get the door open. I have unplugged the
Unplug the washer. Then plug it back in and press the button that turns it off. This should unlock the door. Same thing happened on mine and there was a kink in the drain hose. Once I unkinked the hose, unplugged it, plugged it back in, turned it off, then I was able to run a drain & spin cycle to get the water out of the load that was in the washer. I then ran a full wash cycle (they'd gotten stuck in the first drain & spin cycle of a wash) and everything seems to be fine now.
Dec 04, 2011 | Maytag Washing Machines
Duet front load washer door locked & will not cont wash cycle
you can use a wet dry shop vac and attach it to the end of the drain hose and remove all the water in the unit this should unlock your door then you can check the drain pump for anything that may be restricting or blocking the drain pump
Jun 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
The machine went through a cycle and stopped in the middle of a rinse cycle. Trying to restart, the red lock symbol kept lighting up and would hear the lid lock mechanism activate. Tried switching machine...
if the lid lock is activating then testing it electrically wont help. you say that the lid lock is working when you manually put the lid lock in the closed position., is that correct?if it is, does the machine work on the spin cycle once you have manually activated the lid lock? have you checked for damage to lid? please reply 4 more help.
May 23, 2010 | Fisher and Paykel Washing Machines
Washing machine will not spin or drain
look at my post "eco smart won't drain, smells hot". It could be something stuck in very lowest part fo drainage area. you have to remove the motor on bottom of washer to see into this area and remove blockage.
Oct 12, 2008 | Fisher and Paykel GWL11 Top Load Washer
Kenmore he2 front load washer
remove bottom panel open pump port and ck for foreign objects lean washer toward rear wall this will help help keep water toward rear and reduce flooding floor might try opening door first and dipping out as much water as possible with bottom panel removed reach up to lock area there is a tear shaped plastic peace pull it down to release door
Jun 02, 2008 | Washing Machines
No Drain light flashing on washing machine
ckd for something stuck in pump newer models have a low torque electric pump easily stalled by lint or even tooth pick
Jun 01, 2008 | Westinghouse Washing Machines
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
