Question about Koss KS2503 System
No power Our system stopped turning on. All cords are secured, but no power. I read that there is a fuse, but where is it?thank you!
0 characters
1 Points
Won't read, play, or store music.
Performing a product reset To reset your system, follow these steps:
  1. Turn your system off. Wait until "Saving your music information" disappears from the display
  2. Unplug the Acoustimass® module power cord from the power outlet
  3. Wait 60 seconds
  4. Plug the Acoustimass module power cord into a working power outlet
  5. Turn the system on
Note: After the reset, wait several minutes before playing stored music (stored music may not be immediately available depending on how many CDs have been stored). All other sources are available, immediately after the system is turned on.
Feb 06, 2016 | Bose 3 2 1 GSX System
Agent in sri lanka
There is one or two fuses inside the unit. Open the unit very carefully, look for the fuses; they are usually located near where the power cord enters the unit. Get the same fuses. If this keeps happening, then it needs to be serviced.
Oct 05, 2013 | JVC Home Theater Systems
Red light is on in the back of my t300 tower speakers
That is the standby mode but if its not kicking out of standby mode it could be a fuse issue
The T300 uses a 2.5A fuse.
To replace the fuse:
1. Unplug the AC cord from the AC power source,
then remove the AC power cord from the speaker's
power connector.
2. Remove the fuse cap with a small, flat blade screwdriver
(see diagram 2).
3. Remove the fuse from the fuse cap
(see diagram 3).
4. Replace the fuse inside fuse cap with another metric
5X20mm size fuse
5. Replace the fuse inside the cap, replace the fuse
and cap in the power connector (see diagram 5).
6. Connect the AC power cord to the speaker and
raise it upright.
7. Connect the power cord to an AC power outlet
Jun 01, 2011 | Cambridge Soundworks ton Theater T300 Home...
The home theather just stop working in the middle of a movie
Hello Sounds like the power board has blown. If you want you could take the cover off and look to see if there is a glass fuse it would be near were the power cord attaches to the circuit board. See if it is blown, if so replace, you may have had a weak fuse. But more than likely you have a defective power board, and the system will need to be service, or more economically replaced.
Thanks the Projector Guy
Apr 21, 2010 | Philips Home Theater Systems
RCA RT2870 home theater system 'welcome' screen
Well, I just returned the unit. RCA replied with the following solution:
Let the unit sit with the AC power cord out of the wall for a couple of
hours. Then hit the power button 10-15 times (with the AC power cord still
out of the wall socket!) and then try again.
Oct 02, 2009 | RCA RT2870 Theater System
Disc is stuck in machine
When the try is stuck:
On a Lifestyle system with a tray that won't open, try this:
  1. Turn off the power.
  2. Unplug the power cord.
  3. Wait at least 5 minutes.
  4. Plug the power cord back in.
  6. Hit the Open/Close button.
This worked perfectly for me!
Dec 24, 2007 | Bose Lifestyle 38 System
No power!
okay, this seems like either the fuse hase blown in the actual mains plug, or the mass fuse inside the device, it looks like this very small glass fuse, same size as an ordinary fuse, its just seethrough. see if you can get a replacement for it, you may need 2 open the unit to check if it has blown, it will be black or a "burnt" colour from inside! if you dont want to open it, take it to any electronics store, they are bound to check for you, but these fuses don't cost more that $1 or 50pence!
hope this helps
Dec 22, 2007 | Panasonic SC-HT730 System
Picture but no sound...
just follow the power cord to the back if no fuses near there on the out side that is insude same way follow the power cord and thats right there
Dec 20, 2007 | Philips HTS3450 System
No power
I have a TH-C30. I had the same problem where the unit just stopped working - no standby light and no recognition of power at all. After checking this forum and another, I opened the unit, found the ceramic fuse where the power comes in and went to Radio Shack. They have a T1AL250V fuse pack that is a 1 amp, 250 volt, 5 X 20 mm SLOW BLOW glass fuse which is a better fuse for this common problem. Their RS number is 270-1063 and a pack of 4 costs about $3. Put new fuse in and the problem was solved.
The repair took minutes - 3 screws on the back and two screws on each side. Lift the cover from the back (it is slip-hinged on the front) and replace the ceramic fuse. It slips out with a little help and the new one snaps in place.
Jul 21, 2007 | JVC TH-C30 System
Koss KS2503 System Logo
19 people viewed this question
Top Koss Home Theater Systems Experts
Steven Wander
Steven Wander
isaac johny
isaac johny
Are you a Koss Home Theater System Expert? Answer questions, earn points and help others
