Question about GE Spacemaker JVM1640SJ Microwave Oven
What is current ge microwave model compared to old model jvm64 003
3 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: Compatible replacement
GE Customer Service is here. They can tell you if they have a comparable "drop-in" replacement.
You can usually find helpful exploded view diagrams and order parts & accessories by entering your full model number here.
Posted on Nov 27, 2008
walesarumi
  • 6993 Answers
SOURCE: GE microwave over the range, model #jvm1740sm1ss has no power.it's only two year old.what could be the cause?
the problem of this unit is power related.
First, remove the unit's power cord from the wall, wait for about 30mins, then plug it back in. It may cool by then and might power on. If it doesn't power on, plug it into another outlet, to make sure there electricity entering into the unit.
If plugging into another power outlet doesn't power it on then the unit is most likely having a power problem.
When electric current comes from the power outlet into the cooker, it goes straight into the power supply board which then circulates the current into the unit. So if the cooker doesn't power on, the first thing is to make sure there is power entering into the machine.
So check the power cord, if it is a 3-pin plug, it must have a fuse in it. check the fuse if it is not blown. if fuse is intact, then power supply board should be checked.
If any machine or electronics device doesn't power on, it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter and continuity tester in order to read the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards.
Posted on Nov 08, 2011
Jvm230wl I want to replace my over the range GE JVM230WL model but I'm not sure the exact dimensions. It appears to be a snug fit in the bracket so the measurements need to be manufacture specific. Also,...
GE Customer Service is here. They may be able to tell you if there is a "drop-in" replacement available for your model.
Otherwise, you'll have to take down the old bracket then mount another model in the space.
Jan 15, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
I need to replace my ge microwave zmc1095. what is a comparable microwave?
You can call GE customer service to see if they have "drop-in" replacement.
Otherwise, you can refer to your owner's manual for the specifications to compare to new ones.
Jan 15, 2013 | GE JVM1790SK Convection/Microwave Oven
The unit seems extremely quiet and fills with steam when cooking. I'm concerned the exhaust fan on the microwave isn't working properly. I just got it so I can only compare it to other microwaves.
How old is the oven ???, Is the food saturated with water ???, Is the exhaust clear from any obstacle ??? Do you feel air coming out the exhaust when it's running ??? (compared to when it's not) if it's a new model it is NORMAL, newer (expensive) models tend to keep moisture in the oven... they are built that way to prevent drying out food (on the plate rim) or (if it's fresh from the box) check for forgotten PACKING material that could prevent the oven from exhausting properly... you could also call the manufacturer/GE to check with them as well...
Cheers!
Feb 09, 2011 | GE EVM1750 Microwave Oven
If I had a GE model# JVM1650WH02 and want to switch to Model# JVM1750DPWW. Do the hole match on top when I am mounting to the cabinet above the oven?
I had a GE JVM1651WB 005 from 2001 that died a few days ago. I replaced it with GE JVM1750DPWW today. The 3 old holes from the cabinet to the microwave fit perfectly, so did the old mounting bracket. I only had to make a hole for the plug and chord in the cabinet because the location changed by a few inches diagonally compared to the old one.
Dec 20, 2010 | Microwave Ovens
GE countertop microwave shows "F3" on display, won't work
F3 on a GE means you have a shorted membrane keypad.
There are two ways to fix this model, either replace the membrane keypad which is a lot of work (handy guide with pictures) or to replace the complete controller.
It's probably not going to be economical even to repair it yourself if you or a friend want to. It depends on the model:
JES1334WD001
JES1334WD01
JES1334WD02
JES1334WD03
JES1334WD04
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
I looked up parts prices for the -02 verison.
ref # 38 part number WB27X10554 membrane keypad $69.71 here (compared to $112.50 direct from GE!)
ref # 42 part number WB07X11076 complete controller assembly $131.01 here (compared to $196.25 direct from GE!)
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Jun 02, 2010 | GE Microwave Ovens
GE Spacemaker Microwave, Model #JVM1540SN1SS, buttons don't work
The membrane keypad has failed.
The keypad itself is not available as a separate part, so the control panel frame with keypad would have to be replaced.
This is actually a pretty simple DIY job.
You can part number WB56X10826 from the Pros here for $114.62 plus shipping (that compares to $166.50 from GE!).
You can also find helpful exploded view diagrams at that link.
Then disconnect your keypad strip as shown in the photo below, then remove the screws that hold your circuit board in the old frame.
Then carefully (since the display is made of glass) move your circuit board to the new frame, and reassembly is the reverse of disassembly.
May 27, 2010 | GE Microwave Ovens
We have a GE microwave model # JE 18600 SB 001 installed with a trim kit that stopped working. Can it be replaced with GE model # JEB 1860 SMSS?
You can download GE owner's manuals and installation instructions here. You can download for both models and compare the two.
Or you can ask GE Customer Support. Contact info is here.
But your oven may be pretty simple to fix yourself or with help from a friend.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit and symptoms) for free DIY help and information.
prototech@usa.net
Nov 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Nov 26, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
The top vent broke
I called GE and got a new model since the JVM 1860 is discontinued.
Sep 13, 2008 | GE JVM1860 Microwave Oven
Ge spacemaker JVM140H001
Are you sure yours might be economical to repair? What's wrong with it?
Please write back with more details if you need further help.
GE Customer Service should be able to take your current model and recommend comparable replacements. Contact them here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 17, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
74 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
