Question about Samsung Heating & Cooling
Samsung inverter ac error code E1 99
CU MODEL MHO70FXEA4
2 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: we live in a remote
You can get the service manual on the link below. It tells you what the code means on the manual and how to fix. Open the link in a new window to download it.
http://www.coolzoneairconditioning.com/upload/CS-CUE9-12GKR.pdf
Good Luck
Posted on Aug 29, 2010
What dose it mean AE6 error code in Samsung wash machine
SAMSUNG WASHER FAULT CODES: AE or AE6
SAMSUNG WASHER ERROR DEFINITION = communication errors sub and main PBAs - main and inverter PBAs
AE and AE6 represent communication errors between the sub and main PBAs or the main and inverter PBAs.
HOW TO REPAIR/CLEAR ERROR?: If either of these errors is displayed, troubleshooting is needed or service is required.
http://removeandreplace.com/2016/06/15/samsung-washer-quick-troubleshooting-guide-error-code-definitions/
Feb 17, 2017 | Samsung Washing Machines
Showing code 8E
This error code means the ice maker sensor is bad. On Samsung the sensor is part of the actual ice maker which you can find here.
Ice Maker For Samsung Refrigerator Model RF323TEDBSR
Sep 26, 2015 | Samsung RF323TEDBSR 31.6 cu. ft. French...
ERROR E03 WHATS IS MEAN ON MY CONVERTER 600 WATTS ELIMINATOR
Hi, here is the error codes that I could find for you, it seems you are overloading the inverter. That means you cannot connect a kettle or other heavy load to the output. See all error codes below, hoep this helps.
Problem: The AC load will not operate, error code shows on digital
display and alarm is sounding.
Error Possible Cause Solution
E01 Low voltage shutdown because battery is discharged.
Recharge battery. Shorten cables or use heavier cables.
E02 Over-voltage shutdown because of high input voltage.
Verify the charging system is properly regulated and the battery
is 12 V nominal.
E03 The AC product(s) connected are rated at more than the
inverter's continuous power rating; overload shutdown has
occurred. Use a product with a power rating within the inverter's continuous power rating (see Table 3).
E04 The inverter has overheated due to poor ventilation.
Overheating shutdown has occurred.Turn inverter off and allow to cool for 15 minutes. Clear blocked fan or remove objects covering unit. Move the inverter to a cooler place. Reduce load if continuous
operation is required.
E05 The AC products connected have a surge power that exceeds
the Digital Inverter's surge capability or the AC products connected are short-circuited and shutdown has occurred.The products exceed the inverter's surge capability. Use a product with a starting surge power within the Digital Inverter's capability.
Nov 14, 2014 | Cameras
What is an F E Code?
Download Center Download Software Firmware Drivers Manuals Samsung
you dont have all of your model number there is a manual here on samsung website it will also give you options to search error codes
Jun 06, 2014 | Samsung 26 cu ft French Door Refrigerator...
Replacing fuse in samsung microwave model number shm9187
there should be a fuse inside on the AC line and it may be on the inverter(power) board of the unit.
Nov 02, 2012 | Samsung 1.8 Cu. Ft. Over-the-Range...
I have samsung and it displays l5
If it is E2 15 then it may be a switch error (Main Relay error) Check for stuck button switches or power button switch for sticking. May need to replace the main PBA. Verify the error and provide the model number to verify the error code specific to your model.
Aug 28, 2012 | Samsung WF210ANW 3.5 Cu. Ft. White Front...
I have a Panasonic air conditioner model CU-E12EKU (inverter). The unit stop working and the timer indicator is blinking. I checked for this error and followed the instructions in the Operating Manual,...
Not sure if yours has a letter 'H' before the 16 but if it does, it's the:
- Outdoor Current Transformer open circuit.
which means that your outdoor controller board is faulty.
Sep 08, 2011 | Panasonic Heating & Cooling
Teco AC displaying H5 error code... service mechanic looking for a hand
Try this link, as you didn't indicat what model you have. There are manuals in pdf form you can download. They will have a fault code listing if you can determine what model you have
http://www.tecowestinghouse.com/products/Drives/ga7200.html
Jul 03, 2010 | Inverter Yaskawa F7 Drive
Heating & Cooling Logo
183 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
