Question about Refrigerators
I have a samsung fridge, the white water filter hose in the back is shaking like crazy.... what could be the problem? ice build up?
It has french doors, freezer on bottom no condensation or drippinmg water, no build up of ice is seen. I see the white flex filter tube jumping around and hear it sucking in water
  • branbran_13
    branbran_13 Nov 09, 2012
    it to little pressure...... and causing more issues i have noticed, i think a plumbing problem??
    Top Expert:
  • Refrigerators Master
  • 9,472 Answers
It is either ice buildup or high pressure in the line.
Posted on Nov 09, 2012
Samsung rf217acpn/xaa fridge not staying cold and ice build up.
Be sure the drain is clear these are well known for drain blockage. the area behind the shelves is where you would find the evaporator and drain hole.
"Always disconnect power before trying to repair any appliance."
Jul 11, 2017 | Samsung 19.7 Cu. Ft. French Door...
I replaced my water filter. Now I have now water dispensing and no ice being produced
Did you turn the tap back on? Has the hose kinked in the back of the fridge where the filter is? Is the filter back in its place properly (If mounted inside the fridge)
Sep 18, 2014 | Samsung Refrigerators
I would like to not use the filter.do i need a bypass plug to water filter on ffhb2740ps ?
Yes, you can get them on Amazon. for around $ 17.00 get the number off the filter before ordering one or two as the case maybe
Aug 26, 2014 | Frigidaire FFHB2740PP 26.7 cu. ft. French...
Why Icing on bottom freezer
Your drain hose in the bottom back of the freezer is clogged and Iced up and all the defrost water is staying in the freezer and building up. You need to take the freezer back panel off, remove all the ice, defrost the drain, clean, flush with hot water and test the drain line to reach the drain pan under the fridge.
Aug 18, 2014 | Whirlpool Whirpool 26 cu. ft. French Door...
Electrolux EW28BS71IS French Door Fridge no water and no ice
First check that you have good water pressure to the water valve. If you do, then the problem is in your refrigerator. And the most likely fault is the solenoid controled water valve which is a one in two out valve. Follow the water line from you house input and the first place it connects is that valve.
Jan 10, 2012 | Electrolux Refrigerators
I have a samsung french door refrigerator that is only 20 months old and it just started making a very loud humming noise that is coming from the back/top of the fridge. It stops when you open the fridge...
Hi David,
There's a big chance that the evaporators fan touching ice and that's why you hear that noise, if you have an ice build up you gonna have to defrost the fridge and test components to see which one has failed.
Thanks
samedayappliancerepair.ca
Jul 07, 2017 | Samsung RFG237AAWP Bottom Freezer French...
Samsung fridge filter leaking
HI,
your drain is clogged.you may have a catch for your drain where you see leak coming from.that may pull off and you can see if their is trash build up in it.you are going to need to take the panel off the back of freezer.inside back of freezer you will see screws.they will need to come out,if you have ice maker that will need to be removed also.once back panel is off you will see your coils,beneath the coils it will most likely have a sheet of ice.tturn machine off and take a hair dryer and defrost the ice.once ice is gone take a cup of hot water and run thru drain to see if unclogged.repeat if drain is not clear.the ice in drain tube will eventually unclog.I use a steamer.much quicker.
thanks,
Mar 22, 2009 | Samsung Refrigerators
Samsung twin door fridge water leaking onto floor
I have a Samsung side by side - model RS253BAWW.
Water was leaking onto floor from main refrigerator, not freezer. It was determined to be a blocked defrost drain.
The repair technician removed the trays and food from fridge, remove the screws from the panel at back, disconnected everything and remove panel.
The stainless tray at bottom of fridge as well as panel itself had solid ice blockage.
He placed panel in sink and used something similar to a blow dryer with narrow hose on it to defrost both the panel and drain in fridge. Took him maybe 15 minutes and charged $99 total for the visit.
In future I will do this myself now that I know how but thought it may be useful information to others who are having similar problems.
Jan 09, 2009 | GE Profile PFS22 33" Artica French Door...
Q: Does the water for the ice maker go thru the in-fridge filter?
the water should go thru the filter first then to everything else.
Jan 02, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Refrigerators Logo
103 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
