Question about Whirlpool Calypso GVW9959K Top Load Washer
Washer gets stuck during cycles and will not finish
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
Where is it getting stuck?
Posted on Nov 09, 2012
SOURCE: Duet washer leaks during use; rinse cycle?
I am having the same problem with my Duet and would like to know if you will send me the link? nitewind44620@yahoo.com
I have found socks in the boot and I thought that solved the problem which was a tip by someone, but my wife says its still is leaking from time to time. Would like to see what this entails on the change and the cost of the seal. Thanks for help in advance.
Posted on Jan 28, 2008
  • 409 Answers
SOURCE: Something stuck in drum, spinning cycle loud hammering/clacking sound
hi there,
sounds like you may have something caught between the tumbler and the cabinet. since the drum has holes in it, can you have a look if you can see anything that's come of clothing, like a bra wire. it's usually something bigger.
Posted on Sep 30, 2008
robocop
  • 90 Answers
SOURCE: whirlpool washer wont spin during high spin cycle
Try www.Repairclinic.com.
Posted on Jan 19, 2009
SOURCE: Washer moves during the spin cycle
Due to strong vibration during spinning definitely the machine will stop. All you have to do is to check your load if equally distributed from the tub. To eliminate the vibration and the movement of your washer you need to align the four legs of your washer using level tools. Just put the level on the top of the four sides (front side, left side, right side and backside) then make necessary adjustment if needed on the 4 leg of the washer. Also check the water level of the balancer and the mounting position from the top of the tub.
Posted on Feb 27, 2009
  • 106 Answers
SOURCE: Whirlpool Duet stuck on spin cycle
Press 'end of cycle' for over 3 seconds. Perhaps you have to check your filter, maybe clogged.
Posted on Mar 01, 2009
Rl on the control panel
The "rl" (remove load) error code appears when you are running the "Clean Washericon1.png" cycle. You must not have a load of clothes in the washer during this cycle. Remove the clothes from the drum, and restart the cycle. The "Sud" error indicates that the detergent is over-sudsing. The Duet washer automatically combats this by reducing the amount of suds in the washing machine. Let the washer finish the suds-reduction steps. Use less detergent during the next wash cycle.
Oct 21, 2012 | Whirlpool Duet GHW9150P Front Load Washer
For some reason my GE GBVH6260 washer cycles are getting hung up on either the wash or rinse cycle. Some days it will stay stuck in the wash cycle & some days it will stay stuck in the rinse cycle for...
Most likely its your water inlet valve..(cold side is not letting water in). Very common problem that usually manifests during rinse cycle since rinse uses always cold water.
According to your model # , part # is WH13X10023
Jul 10, 2017 | Washing Machines
Water building up during the dry cycle and clothes getting wetter
1) Make sure wash cycle is 100% finished (sometimes dryer will start before - usu on synthetic cycle & allows water to continue flowing in)
2) Manually start the dry cycle after you ensure wash cycle is finished and push in the wash cycle button.
Hope that helps! If not, you may need a new control module (I did - hope you don't!)
Apr 19, 2010 | Haier XQG65-11SU Front Load Washer / Dryer
Door stuck
try unplugging and plug back in to reset
Nov 17, 2009 | Hotpoint First Edition FEW12 Front Load...
Motor makes noise shortly after starting, makes normal sound level during main body of wash, then makes noise again during what I'm guessing is the rinse cycle. Not sure if it is a pump or motor problem....
Make sure the sprayer arm is turning freely, check for something stuck in the base of the sprayer arm (food or utinsel) preventing it from turning.
Sep 22, 2009 | Dishwashers
Duet ht something stuck
try a magnet ?..see if you can get it back out the way it went in..good luck doing this without disassembly
Nov 24, 2008 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Fisher and Paykal GWL 10 US - Stops before rinse
52. (00110100) Eco - Diverter Top-up Fault diverter valve made be stuck in half open position ,may be a mechanical obstuction or the wax filled solenoid that actuates it may be faulty .located under machine beside pump .
Jun 17, 2008 | Fisher and Paykel GWL11 Top Load Washer
90 Series Top Load Washer shakes during spin cycle
The Guide Plate underneath is out of alignment,, You might have to call me on this one. The only reason I am sure of this is because when my delivery guys would deliver a direct drive washer such as your, sometimes when the machine is laid down to far on its side, it gets out of alignment. Easy fix,, Just hard to explain.
Mar 24, 2008 | Kenmore 22422 Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
11 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
