Question about Vector Maxx SST Power Inverter
I have to power 1800 w for 12hr a day! I currently have Vector Max SST 3000w 20 Duralast 31-950 950 Cold Crankin Amps 195 Reserve Capacity Schumacher se-3000 Charger Do i need to change or add anything to get the bank to work? Right now it doesnt last 12 hours a day. I need it to run cosistantly. I was think i may need another type of charger. What do you think the problem could be?
    New Friend:
Get a duralast 900 recharger and starter from autozone.com duralast charrge lasts for 3 months of charging and starting cars boats ect. also it has a built on light and an additoional accs attachable flexible light.
Posted on Jan 23, 2013
  • 3 Answers
I think the problem might be your battery setup.
First of all, these batteries are not deep-cycle batteries they may not tolerate this kind of usage. Secondly, if you have 20 batteries connected in parallel they could end up working  against each other (draining each other) all the time.
You might do better with 2 very large 6 volt deep-cycle golf cart or fork lift batteries.
Posted on Jan 11, 2009
What is the cold cranking amps for 2004 ford escape?
petrol around 450 amps
diesel around 600 amps
Jan 28, 2018 | Ford Cars & Trucks
Gen set blows fuse
no
a fuse is there to protect the circuit and the genset
check why the de-icer is pulling so many amps as the problem may be in that unit
a 10 amp outlet has a maximum current capacity of 10 amps as that is the current allowable from the gen set and wire capacity
even if you had an outlet with 15 amp rating , it would still be blowing fuses as the 16 amps is above the allowable current draw
you would need a 20 amp outlet ( difficult to get unless it is in a house power board and are normally reserved for hot water systems , stoves and other high current usage units and are normally then not outlets but hard wired in to a circuit breaker
Aug 10, 2016 | Kohler Electrical Supplies
Do I need to put a inline fuse or does the vector sst 1200 have a fuse or breaker in it
It probably does, but an in-line fuse is still the safest way to go, connected as close as possible to the voltage source as possible. The internal overcurrent protection device (aka, fuse or breaker) in the inverter will prevent the DEVICE from melting if it malfunctions. An in-line fuse will protect EVERYTHING if the WIRING malfunctions.
May 05, 2014 | Vector ® Maxx SST 1200 - watt Power...
What battery do i need for a 911 Carrera 2004?
Compare CCA...(Cold Cranking Amps) for the most reserve power. Try not to settle for less than 1000 CCA...There are limited true battery manufacturers...The most popular sellers based on Value are Costco, Autozone Duralast Gold, Walmart Maxx, Interstate, and AC Delco...you can limit your search to a factory brand from your Porsche dealer or compare others at a much higher price for less performance and guarantee. All of these will more than satisfy the reserve power needs of your Carrera...Hope this helps. (For selling value, the factory battery is usually best on high value cars like yours:)
Feb 23, 2011 | 2004 Porsche 911
(Vector 400 Watt sst Power inverter) When I plug the Inverter into the Cigarette lighter of my RV, and the TV 26" into the inverter It won't work.
I am assuming that the inverter works with other devices. This being the case, i am thinking that the television start up current is drawing too much power too quick for the inverter to handle and this is what is shutting down the inverter.
Feb 05, 2011 | Vector VEC024B MAXX SST Power Inverter
I have a Veco24B 400 Watt DC to AC inverter and the fuse that is suppose to be located in the cigarette lighter adapter is missing and I would like to know the size of fuse that is required.
I would put a 20 amp fuse in. The wiring for the cigarette lighter is usually around 15 - 20 Amps. The wiring also is not rated for more than 20A. I hope this helps. JOe
Dec 22, 2010 | Vector VEC024B MAXX SST Power Inverter
What battry size do I use for a ford expedition xlt 2001
This one is $104...... Super Start - Battery Part Number: 65-72J Line: SSB
  • UPC: 721112782478
  • Battery Spec: 675 CCA
  • 845 CA
  • 130 AH Reserve Capacity
Warranty Info 72 Month P/R Warr 2yr Free Replacement
Detailed Description
  • Cold Cranking Amps: 675
  • Cranking Amps: 845
  • Reserve Capacity: 130
  • Length: 12"
  • Width: 7-7/16"
  • Height: 7-5/8"
Dec 17, 2010 | 2001 Ford Expedition
Need to replace the battery in my 2006 530xi. What is the exact battery I need and what cost should I expect?
I need a little more information to answer your question.
If your car has the 3.0L 6 cylinder engine;
Part Number: 48-72
Cold Cranking Amps: 730/Cranking Amps: 915/Reserve Capacity: 130
If your car is has the 4.7L V8
Part Number: 49-72
950 CCA/760 EN CA/100 AH Reserve Capacity
Both have a 72 Month P/R Warr 2yr Free Replacement warranty.
These are taken from the http://www.oreillyauto.com web site. However, I would recommend that you go to a quality battery vender.
Nov 21, 2010 | 2006 BMW 5 Series
Battery size group?Avalon 04, 3.0
Group Size: 35
Voltage: 12
Cold Cranking Amps (CCA) @ 0°F: 720
Cranking Amps @ 32°F: 910
Reserve Capacity (minutes): 90
Terminal Type: SAE top post
Height (in.): 9-5/16
Width (in.): 6-13/16
Length (in.): 7-5/8
Weight (lbs.): 32
Hope this helps
Oct 15, 2010 | 2004 Toyota Avalon
What size battery does a 1994 cadillac deville elegance needs on the optima brand?
According to Optima's battery selector, you need...
Part Number: 34/78 (9004-003) RedTop®; Battery; BOXED; Group 34/78; Cold Crank Amps 800; Crank Amps 1000; Reserve Capacity 110; Ampere Hour 50; Dual Terminal; L-10 in.; W-6 7/8 in.; H-7 13/16 in.;
Aug 11, 2009 | 1994 Cadillac DeVille
Vector Maxx SST Power Inverter Logo
248 people viewed this question
Top Vector Electronics - Others Experts
Craig Butler
Craig Butler
Matt Olenzek
Matt Olenzek
Are you a Vector Electronics - Other Expert? Answer questions, earn points and help others
